http://www.rcgroups.com/forums/showp...2&postcount=35
http://www.rcgroups.com/forums/showp...2&postcount=35 |
2212 size motor in the 1900-2200kv range will step it up. Like a good old 2212-6 swinging a 6x4, 6x5.5, etc.: https://www.bphobbies.com/view.asp?i...7&pid=B2632603 |
It has me stumped. There are other guys at my club with these and I haven't seen there's doing it. I've looked at their setup and it's basically the same way i'm doing it. Servo arm, to straight piece of pushrod with EZ connector, to control horn with another EZ connector. I've triple checked the EZ connectors and they are all socked down very well with ZERO play in them even if I yank on then very firmly. (I even used blue loctite "just for added measure") |
horn is glued in really well? Do you have rates turned way down in the radio? Did you re-hinge the ailerons? Can the ez-connectors rotate in the horns? is the straight rod (music wire) thick enough not to flex? You may just be hitting some perfect harmonic frequency. See if you can change the CG ever so slightly. That's about all I can think of.. |
Do you have rates turned way down in the radio? I have high rates at 75% and low rates at 45% Flies very well like this, yet the flutter happens on either "rate" Did you re-hinge the ailerons? Nope, they are "stock" Can the ez-connectors rotate in the horns? Yes is the straight rod (music wire) thick enough not to flex? It's thick enough that it take some serious effort to bend them by hand. |
Thanks Sammy! I appreciate it.
Don Quote:
Latest blog entry: D100
| Thread Tools | |
| Question Techone models?? | lectroglide | Indoor and Micro Models | 5 | Aug 07, 2011 01:54 PM |
| Sold Techone Energy EPP Foamy | Wattsup23 | Aircraft - Electric - Airplanes (FS/W) | 9 | Mar 31, 2011 03:28 AM |
| Sold Techone Piaget 3D EPP New in box $45 shipped! | Lindy757 | Aircraft - Electric - Airplanes (FS/W) | 2 | Mar 17, 2011 11:01 PM |
| Discussion TechOne F3P??? | cglynn | Indoor Pattern/F3P | 6 | Mar 11, 2011 01:24 PM |
| Question techone malibu 2 or techone aeolus? | genesis96 | Indoor Pattern/F3P | 16 | Jan 19, 2011 01:02 PM |
