Old Nov 15, 2012, 10:16 AM
MOfroggy is offline
Find More Posts by MOfroggy
East Texas
Joined Nov 2008
Originally Posted by whirlcap View Post
You can use two sticks/pencils etc for checking CG. There is a small acceptable CG range and it does state that in the manual. I made a couple sharpie pen dots and use my finger tips usually. The rx and ESC sit pretty much on the center of CG and you balance your motor weight with the size battery that get the CG right. For me, with a similar motor, a 3s 800 mah was just right. Small CG adjustments can always be done with a small weight Velcro'd to the battery or attach something to the motor mount if that end is light. I also use a mix of battery sizes I have on hand and use weights with the smaller ones to keep the balance right.
I put two dots of hot melt glue on the COG line outboard from center. That way I don't have turn it over and look for the ink dots.
Joe
MOfroggy is offline Find More Posts by MOfroggy
Old Nov 15, 2012, 10:28 AM
fishycomics is offline
Find More Posts by fishycomics
Joined Oct 2006
Great tip. When I mark the wing I willies then likely place a black dot
fishycomics is offline Find More Posts by fishycomics
Reply With Quote  (Disabled)
Old Nov 15, 2012, 07:40 PM
Joined Oct 2006
Had some time. to work on the wing, and I was successful in getting all controls working. I will now need to put all together real neat, and wait for my charger to arrive. Once I get all neatly together, I will work on the CG, and I ready to fly.
Thank oyu Whirlcap, thank you Bluhammer, and thanks to vparanorma.
I used ar600 rx, rather a orange as I do not want to cut out foam today.
added note:
135-142mm = 5.59 inches, and that brings it just in front of the servos, going to be tricky. I think she will be tail heavy, so adding some weight, if a penny, nickel, dime, washer, to the nose, or in pairs to each side, and with goop no less?
Making a jig, rig, and centering it on the pen points, and placing the weight on top, and then transferring to bottom, will be fun? That is my plan?
I had to relook at the rx, and I got the wires all tucked neatly as can be, just again a canopy to work on? And having only the jst plug out, will be fun.
that is all to report.
Old Nov 19, 2012, 07:45 AM
BlueDevil is offline
Find More Posts by BlueDevil
Mt. Airy, NC
BlueDevil's Avatar
Joined Aug 2004
LED's and Bomb Drop for 600mm Mini Pop
Hey folks.. TOO many threads to look through so I'm hoping someone could make a suggestion..
I have the 600mm Mini Pop Wing and would like to add LED's for night flying and maybe a bomb drop.
So first.. could someone point me to the LED's that would work for that wing.. I would like to be able to use the 3S batteries I'm using to power them.. either with a Y adapter or by using the balance plug.
As for the bomb drop.. I'm sure I could just mount a servo and plug into the AUX on my RX but wondered what the best route would be for releasing.. since I'm sure many of you have done this..
Thanks in advance for any info!
BlueDevil is offline Find More Posts by BlueDevil
Old Nov 19, 2012, 10:18 AM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
I just completed lights on my Mini (Bonsai) running 3s last week.
Used the led strips and the balance to jst connector below.
I went with: Bottom - Green Right, Red Left (standard nav scheme)
Top - White and blue (white is the Brightest by far)
I used Foam-Tac to glue them down and dabs of Foam-Tac to hold down the wires and connectors. Hot glue should work just as well and faster.
I would suggest running some strips along the tops of the winglets for even better orientation. I still have to add those on to mine. On my first night flying session, I mildly crashed 3 times. With only top and bottom, when it's flying flat toward you, it gets tough to keep up. You can't see any light at all in that case and your brain has to play catch up when it shows up again. Winglet lights should solve that. I think I'm going with matching green and red on them.
There are solder pads at the ends of the led strings for adding on. Just solder some wire between the long strips and the winglets.
LEDs (of course out of stock right now)
http://www.hobbyking.com/hobbyking/s...00mm_Red_.html
http://www.hobbyking.com/hobbyking/s...mm_Green_.html
http://www.hobbyking.com/hobbyking/s...mm_White_.html
http://www.hobbyking.com/hobbyking/s...0mm_Blue_.html
Balance to JST connector (4 or 6 jst)
http://www.hobbyking.com/hobbyking/s...dproduct=23133
http://www.hobbyking.com/hobbyking/s...dproduct=23347
Optional LED strips (would need cutting to length)
http://www.hobbyking.com/hobbyking/s...Red_1mtr_.html
http://www.hobbyking.com/hobbyking/s...een_1mtr_.html
http://www.hobbyking.com/hobbyking/s...ite_1mtr_.html
http://www.hobbyking.com/hobbyking/s...lue_1mtr_.html
IFlyRCs is offline Find More Posts by IFlyRCs
Old Nov 19, 2012, 11:18 AM
Jim_W is offline
Find More Posts by Jim_W
Jim
North Alabama
Joined Mar 2004
Jeff at www.headsuprc.com has the LED strips to. Fast shipping to!
Jim_W is offline Find More Posts by Jim_W
Old Nov 19, 2012, 11:26 AM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
Yep, they have the long ones.
The HK 200mm ones worked great on the mini.
You could get the long ones and use the extra length for the winglets.
Old Nov 19, 2012, 01:54 PM
Mt. Airy, NC
BlueDevil's Avatar
Joined Aug 2004
AWESOME! Thanks for the links!!
Old Nov 19, 2012, 05:22 PM
Schoolya is offline
Find More Posts by Schoolya
Schoolya's Avatar
United States, FL, Mayo
Joined Jul 2012
Here is a video of my flying my popwing at the school yard this afternoon. Be sure to go to youtube so you can up the quality. I tired to catch it in the end, but missed it and hit my wife. No harm was done. It was a "accident"
Flying popwing in 10-15 mph winds (1 min 44 sec)
Schoolya is offline Find More Posts by Schoolya
Old Nov 19, 2012, 05:32 PM
Indetrucks is offline
Find More Posts by Indetrucks
Indetrucks's Avatar
United States, CA, Torrance
Joined Aug 2012
Originally Posted by Schoolya View Post
Here is a video of my flying my popwing at the school yard this afternoon. Be sure to go to youtube so you can up the quality. I tired to catch it in the end, but missed it and hit my wife. No harm was done. It was a "accident" http://youtu.be/WexMsj_leo4
I like how fast it is. That the mini or regular pop-wing?
What motor / batter / prop combo are you using?
Indetrucks is offline Find More Posts by Indetrucks
Old Nov 19, 2012, 06:01 PM
Schoolya is offline
Schoolya's Avatar
Joined Jul 2012
heads up rc powerup zoom 400 with a 40 amp hurc esc, 6 x 3e prop and a 3s 1550 rhino battery. and it is a regular popwing. One thing I have found that is key if you are going to go quick, get metal gear servos.
Old Nov 20, 2012, 07:33 AM
Indetrucks's Avatar
Joined Aug 2012
Thanks for the info, I have a mini which is pretty quick but didn't know ya could get a regular pop wing to reach the speeds you are
Wonder what a mini would do with your set-up?
Old Nov 21, 2012, 09:19 AM
Joined Oct 2006
Thanks Johnny Meg's not a problem. I was thinking for the longest, read up watched your clips and thought I give a crack at the wing. I loved the wing you had. I had to go with the lesser and take a stab at it.
If I was a total noob, pressed for time and more, Johnny Meg's is the one to get, all set up and perfect matched, cannot ask for more
( clearly understandable and legible , personal note)
Update
Maiden completed and posted
Last edited by fishycomics; Nov 21, 2012 at 05:47 PM. Reason: As noted being punctual
Old Nov 22, 2012, 09:16 AM
smitty919 is offline
Find More Posts by smitty919
smitty919's Avatar
manahawkin NJ
Joined Dec 2009
Well mine came in the mail yesterday and i spent last night getting it ready yup the dx6i set up was a mind cramp lol but all seems good cant wait to try it out...
smitty919 is offline Find More Posts by smitty919
Old Nov 22, 2012, 12:26 PM
smitty919's Avatar
manahawkin NJ
Joined Dec 2009
A bit windy today but took it out anyways to trim and maiden my first ever Wing....WOW awesome stuff not sure what took me so long to buy one..
This thing is what its all about we got sick speed we got easy flying we got great looks and just a all around blast...When i bought it from Johnnymeg i opted for a 2nd battery i should have got more lol.....I have a few 1300mah 3s battery so i gave them a shot i even like it better with the 1300man she is a bullet ....
Again WOW great job Johnnymeg on setting them up nicely....
Mini PopWing (1 min 38 sec)
Question Techone models?? lectroglide Scratchbuilt Indoor and Micro Models 5 Aug 07, 2011 01:54 PM
Sold Techone Energy EPP Foamy Wattsup23 Aircraft - Electric - Airplanes (FS/W) 9 Mar 31, 2011 03:28 AM
Sold Techone Piaget 3D EPP New in box $45 shipped! Lindy757 Aircraft - Electric - Airplanes (FS/W) 2 Mar 17, 2011 11:01 PM
Discussion TechOne F3P??? cglynn Indoor Pattern/F3P 6 Mar 11, 2011 01:24 PM
Question techone malibu 2 or techone aeolus? genesis96 Indoor Pattern/F3P 16 Jan 19, 2011 01:02 PM
