Old Oct 09, 2012, 03:28 PM
MOfroggy is offline
Find More Posts by MOfroggy
East Texas
Joined Nov 2008
1500 BW 3S Mini POP
Originally Posted by rmgmag View Post
I modified my mini-Pop similar to Johnnymeg's, it flies great with a 1,000mah 3S. Really fast, slows down fairly well. Flies much better with the 5x4.3 prop than any other prop, that's using the 3,000kv HK version of the Blue Wonder. Definitely a fun little plane. Best flying wing I've ever had.
What size ESC do you recommend for this setup? And what gr. servos did you use?
Joe
MOfroggy is offline Find More Posts by MOfroggy
Old Oct 09, 2012, 06:54 PM
ichiban is offline
Find More Posts by ichiban
Los Angeles
Joined Nov 2006
Joe
The setup called for either the 15-18A or 18-20A. I went with the 25-30A for more motor compatibility and lower price.
Most owners post 5 gram servos work fine. All of the owners who switched from 5 to 8 or 9 gram servos and posted, posted they are happy with the switch. I'm starting with 9 gram servos, HXT900.
ichiban is offline Find More Posts by ichiban
Old Oct 12, 2012, 02:00 PM
Orville2 is offline
Find More Posts by Orville2
Orville
United States, DC, Washington
Joined Jul 2011
900mm PopWing!
Got the kit last week from NitroPlanes (the one with all parts except receiver included), finished assembly last night and flew this morning. This flying wing is lots of fun and quite different than more conventional planes I've flown!
Couple of build points:
1-The instructions say auw of 300 to 350g, but all the parts alone (including my 4g Spektrum compatible receiver) weighed 297g without battery so you'd need an awfully light battery!
2-Assembled weight was 306g.
3-To get the CG to the recommened 210mm required a 1,550 mAH 3S lipo (140g), otherwise I'd just have to add lead! This gives about 16m FT for 70% discharge. This required enlarging the battery compartment.
4-The included propsaver O ring is too light weight -- the prop flew off in the first minute! A 13/16X5/8X13/32 O ring keeps it on much better!
5-I mounted the servos and connectors on top of the wing instead of the recommended bottom mount -- keeps them out of the grass! And, I used carbon fiber rods instead of the included steel, for greater stiffness.
6-If I were starting over I'd cut my own servo holes in the wing, closer to the flapperons, to help shift the CG forward.
7-I found the longest throws possible for servos and transmitter worked best -- this helps keep control of the plane in windy conditions a little better, and probably almost certainly requires some expo.
8-Launching requires more than half throttle or the plane will just dive into the ground!
9-The battery holder is not very well attached to the wing using just CA to hold it on -- It was exciting when the battery came off in flight taking the esc with it! I used the included plastic straps, intended to hold the receiver and esc, to instead hold the battery holder on the plane. I added a carbon fiber rod above the battery compartment as well, on top of the wing, under the plastic straps. This seems to work!
10-Finally, others have said the 900mm PW flys well in wind, but I found that in even a moderate 10mph breeze it gets knocked around a lot -- you can still fly it but not always in the direction you intended!
Orville2 is offline Find More Posts by Orville2
Old Oct 14, 2012, 12:47 AM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
Orville, you should get yourself a mini also!
IFlyRCs is offline Find More Posts by IFlyRCs
Old Oct 14, 2012, 06:51 AM
Hit N Run is offline
Find More Posts by Hit N Run
Fly it low.. and fly it fast!
Hit N Run's Avatar
United States, MA, Westport
Joined Nov 2011
Definitely! They're just as fun, and it's only right to have "the complete set".
Hit N Run is offline Find More Posts by Hit N Run
Old Oct 18, 2012, 10:01 PM
whirlcap is offline
Find More Posts by whirlcap
If it spins, wear it.
whirlcap's Avatar
Northern Nevada
Joined Jan 2011
Changed the motor back to the higher powered version on my mini now that I can fly it well. Shot a bit of video this morning. I should be able to keep up with the bigger Popwings next time we combat.
High Powered Mini Popwing (2 min 57 sec)
whirlcap is offline Find More Posts by whirlcap
Old Oct 18, 2012, 10:21 PM
whirlcap is offline
whirlcap's Avatar
Northern Nevada
Joined Jan 2011
This was a funny thing that happend also this morning, had a look around, all clear so I launched, then out of nowhere a bazillion birds are all over the sky. I cut the power way back and did my best to avoid them. Didn't have any close calls but it worried me for a moment.
Swarmed By Birds (1 min 3 sec)
Old Oct 21, 2012, 09:06 AM
chippedprop is offline
Find More Posts by chippedprop
Joined Feb 2008
Hey Guys
Finished my second Popwing 1200
The first post 623 is the speedy one
On this one I wanted a slower one...longer flight times....faster then stock
I'll post a video this week with in my opinion is a great all around set up
Made a couple of changes to fix wing snap issues I had on first one---wing snap as in snap in two
Flying weight is 23.0 oz The video will detail upgrades
Chip
1200 Popwing (10 min 26 sec)
chippedprop is offline Find More Posts by chippedprop
Old Oct 21, 2012, 10:45 AM
neato4u is offline
Find More Posts by neato4u
neato4u's Avatar
Malaysia
Joined Feb 2012
Another one of my popwing fun flight video
Malaysian RC - Puncak Jalil Popwing (5 min 13 sec)
neato4u is offline Find More Posts by neato4u
Old Oct 21, 2012, 12:44 PM
wslco10 is offline
Find More Posts by wslco10
United States, CA, Thousand Oaks
Joined Apr 2009
Nice video, very sharp and clear. Looks like you are flying on a mountain top or hill that has been cleared for future building.
Bob
wslco10 is offline Find More Posts by wslco10
Old Oct 21, 2012, 03:28 PM
DJO is offline
DJO
Find More Posts by DJO
DJO
"Yo, that's a thermal"
DJO's Avatar
Joined Oct 2011
This is how you're SUPPOSED to fly a PopWing
LOS:
PopWing Baseball Field Insanity (2 min 20 sec)
FPV:
PopWing FPV Compilation I :: First Exposure (4 min 10 sec)
Dan
DJO is offline Find More Posts by DJO
Old Oct 21, 2012, 07:22 PM
microkid is offline
Find More Posts by microkid
flight investigator in service
Lakewood,Ohio
Joined Jan 2009
PopWing motor mount issue
Hey flyers today I was doing some flights in the night with my popwing and I was going to do my last flight when I noticed the motor was dangling from the plane with the flat piece of the motor mount still attached to the moto and noticed it fitted in like a jigsaw puzzle with the support part of the mount.
Should I glue that flat part with the motor attached to it back to the rest of the mount or just fit it right in?
Dave
microkid is offline Find More Posts by microkid
Old Oct 22, 2012, 10:02 AM
Bluhammer is offline
Find More Posts by Bluhammer
Bay Area Prop Buster
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
I know this is a Pop Wing thread but would you mind if I post a video of my crazy fast Assassin wing?
Blu
Bluhammer is offline Find More Posts by Bluhammer
Old Oct 22, 2012, 10:05 AM
MOfroggy is offline
East Texas
Joined Nov 2008
Dave
I fit mine back in when this happened and then I drilled small holes in all of the corners I could get to and zip tied them together with the smallest zip ties in my tool box. I then soaked ALL of the joints in CA and let it dry and then I put fillets of hot melt glue in all of the corners and everywhere the mount joined the foam too. I know this is a little overkill but my POP is way overpowered vs. stock and I have never had another problem in over 250 flights.
Old Oct 22, 2012, 10:27 AM
neato4u is offline
neato4u's Avatar
Malaysia
Joined Feb 2012
Bob
Thanks, yes it was cleared off since last year but nobody stops us from flying here as of yet. It is a very popular site for newbies because of it's large airfield. but for me, it's starting to be a bit too dusty to appreciate
Anyway, still fun to flies there with the rest of the usual friendly flyers. Although most of us has been discussing where else to fly if this site close.
Question Techone models?? lectroglide Scratchbuilt Indoor and Micro Models 5 Aug 07, 2011 01:54 PM
Sold Techone Energy EPP Foamy Wattsup23 Aircraft - Electric - Airplanes (FS/W) 9 Mar 31, 2011 03:28 AM
Sold Techone Piaget 3D EPP New in box $45 shipped! Lindy757 Aircraft - Electric - Airplanes (FS/W) 2 Mar 17, 2011 11:01 PM
Discussion TechOne F3P??? cglynn Indoor Pattern/F3P 6 Mar 11, 2011 01:24 PM
Question techone malibu 2 or techone aeolus? genesis96 Indoor Pattern/F3P 16 Jan 19, 2011 01:02 PM
