Old Sep 25, 2012, 04:02 PM
zeezee is offline
Find More Posts by zeezee
Yea, I fly dusty planes..
zeezee's Avatar
United States, LA, Angie
Joined Apr 2009
I am looking to buy a used Popwing in good condition in a BNF setup so I can see if this is where i want to go in my continuing journey in RC. Currently flying a H9 P-51 and a Pawnee towplane. BNF would be 2.4/////Dave/ZEEZEE
zeezee is offline Find More Posts by zeezee
Old Sep 25, 2012, 04:14 PM
Hit N Run is offline
Find More Posts by Hit N Run
Fly it low.. and fly it fast!
Hit N Run's Avatar
United States, MA, Westport
Joined Nov 2011
Trust me, you want a Popwing! It's a great part of anyone's "journey" in RC flying. I have the Popwing and Mini Popwing and I love them both!
They go flying with me EVERY time I head to the flying field.
Hit N Run is offline Find More Posts by Hit N Run
Old Sep 25, 2012, 05:54 PM
ichiban is offline
Find More Posts by ichiban
Los Angeles
Joined Nov 2006
Johnnymeg sells newly built BNF fast mini popwings at a reasonable price. Check out his You Tube Channel for videos including mini pop FPV.
ichiban is offline Find More Posts by ichiban
Old Sep 25, 2012, 06:48 PM
microkid is offline
Find More Posts by microkid
flight investigator in service
Lakewood,Ohio
Joined Jan 2009
This plane is great for everyone to add to their fleet! Just ask me
Have a 2.4ghz reciever and spektrum to get the most out of your popwing, especially with dual rates for maiden and expierience flying! I did mymaiden on high rates and did great with how stable this flyer is and is more fun too
microkid is offline Find More Posts by microkid
Old Sep 26, 2012, 09:13 AM
Schoolya is offline
Find More Posts by Schoolya
Schoolya's Avatar
United States, FL, Mayo
Joined Jul 2012
My pop wing.
Here is some pictures of my second pop wing. Learned some stuff with the first one and changed it with this one. I think the winglets where flexing at 60+ mph, so I added some carbon rods to each for reinforcement(and also rounded the edges). I also added a rod under the motor mount because the wing seemed to act odd under heavy acceleration, and I think the motor mount may have been twisting the foam some. Also added 2 square carbon rods to the nose because after cutting out for a larger battery ( rhino 1550 3s) there is not much foam left for support in the nose. Cut battery compartment to top of wing, per someone else suggestion earlier in this thread, and glued some walmart flexible cutting board to the bottom. Electronics are Power up zoom 400 with emp 6x4e prop and a hurc 40amp esc. had to add a 1oz weight to the front to get cg right(which i hate doing). 75ish top speed, flies on rails, with none of the odd behavior of my first popwing.
Schoolya is offline Find More Posts by Schoolya
Old Sep 26, 2012, 09:55 AM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
Very nice. Thanks for the info.
Have you worked with flat carbon strips any? I'm starting to like those a lot.
Did you run a bead of CA and accelerator over all the stock carbon? It helps a bit.
IFlyRCs is offline Find More Posts by IFlyRCs
Old Sep 26, 2012, 12:46 PM
Schoolya is offline
Schoolya's Avatar
Joined Jul 2012
actually, I like goop or shoe goo's rubberyness for EPP, so I used that.
Old Sep 26, 2012, 12:59 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Originally Posted by Schoolya View Post
...had to add a 1oz weight to the front to get cg right(which i hate doing).
Where's your CG with & without the 1oz weight?
I have my CG back further than the recomended range and it flys great there.
You may be fine without the weight...
Sammy70 is offline Find More Posts by Sammy70
Old Sep 26, 2012, 02:25 PM
zeezee is offline
zeezee's Avatar
Joined Apr 2009
I have sent Johnnymeg a couple PM's to buy one but no responce, he must be a very happy busy man!!! That's what doing good work will do for you....I have my finger on the PPal button, I want a Popwing...........Dave/ZEEZEE
Old Sep 26, 2012, 03:07 PM
ichiban is offline
Los Angeles
Joined Nov 2006
He's an enterprising young man as well as helpful; his PM box is possibly full. You may want to post your request on his thread.
Old Sep 26, 2012, 03:25 PM
zeezee is offline
zeezee's Avatar
Joined Apr 2009
Thanks all, I just got ahold of him and am now a wing owner. Can someone tell me what size prop he supplys these with so I can order some more while I wait for my wing.. BTW...I do all my power and everything else shopping at HeadsUp RC.... Dave
Old Sep 26, 2012, 03:51 PM
ichiban is offline
Los Angeles
Joined Nov 2006
Good choice! In his first mini popwing video where he briefly shows his banzai wing (HobbyKings version of the mini popwing,) he mentions he's tried GWS 5x4.3 and GWS 5x3 props. He liked the 5x3 as it was more stable. However, I don't know if he's still using that prop with his builds.
Old Sep 26, 2012, 06:40 PM
bluecnc is offline
Find More Posts by bluecnc
Near-Earth object
United States, NC, Castle Hayne
Joined Sep 2012
My first wing.
After reading all the pages in this thread I felt confident that my maiden flight would be a success. And it was.
Thank you all who have come first. Your experience is invaluable.
My setup:
900 mm PopWing
T-Motor AS2208-15 KV:1260
TechOne 20 amp ESC
GWS 8-4 prop
11.1v 2200 mAh 25c battery
8 gram servos
All said, I pre-maidened the wing with a 1300 mAh battery which left the craft tail heavy, prompting me to purchase the 2200's. The extra weight corrected the COG. Another benefit of the large battery was 15 minute flights of wide open throttle.
The set-up that I had caused the popwing to be a little lethargic but it was perfect to start off. I have now upgraded to a 30 amp esc, 1100 kv Dynam motor and a APC 8-6 prop.
Haven't flown it yet. The new motor and prop are heavier which always changes the dynamics of flight but oh well.
Can't wait for the sun to come up. Are those batteries charged yet?
See you all at the field.
bluecnc is offline Find More Posts by bluecnc
Old Sep 26, 2012, 07:14 PM
Schoolya is offline
Schoolya's Avatar
Joined Jul 2012
I didn't measure, I just did it by how it felt in flight. Without the weight it was wiggly when going slow and wanted to stall in turns. With it, its perfect.
Old Sep 27, 2012, 10:55 AM
neato4u is offline
Find More Posts by neato4u
neato4u's Avatar
Malaysia
Joined Feb 2012
popwing with horyzon hd
Hey guys, this is my first time flying a flying wing and I must say the popwing ia a steady platform. I do need some time to get used to it.. Sometimes I just lost orientation of the plane
Anyway, here are my video trying to imitate trappy style hehe. I will try again with FPV stuffs onboard.
Popwing-LOS Trappy style (4 min 18 sec)
neato4u is offline Find More Posts by neato4u
Question Techone models?? lectroglide Scratchbuilt Indoor and Micro Models 5 Aug 07, 2011 01:54 PM
Sold Techone Energy EPP Foamy Wattsup23 Aircraft - Electric - Airplanes (FS/W) 9 Mar 31, 2011 03:28 AM
Sold Techone Piaget 3D EPP New in box $45 shipped! Lindy757 Aircraft - Electric - Airplanes (FS/W) 2 Mar 17, 2011 11:01 PM
Discussion TechOne F3P??? cglynn Indoor Pattern/F3P 6 Mar 11, 2011 01:24 PM
Question techone malibu 2 or techone aeolus? genesis96 Indoor Pattern/F3P 16 Jan 19, 2011 01:02 PM
