Old Sep 18, 2012, 07:53 AM
chippedprop is offline
Find More Posts by chippedprop
Joined Feb 2008
still thinking to increase wing tip fins in size as you can see it's on edge of unstable in the vid.
but still fun to fly
chippedprop is offline Find More Posts by chippedprop
Old Sep 18, 2012, 08:11 AM
slothumbs is offline
Find More Posts by slothumbs
Joined Aug 2012
Love the mini
I finally finished putting the mini together yesterday. I got it from Nitroplanes with motor and esc. I was expecting it to be mellow given the tiny size of the motor, but boy was I wrong. With 800mah 2S battery, it had plenty of juice and then some.
I did (or I think I did) have an issue with one of the servos. For some reason, the left one didn't seem to have the same range of motion as the right one. But, once I tweaked a bit my tx, the flight was good. I still need to tweak more, but I am super happy with the Wing. It is loads of fun. I am sure my buddy is going to get one soon and I am already thinking about the 900mm version.
slothumbs is offline Find More Posts by slothumbs
Old Sep 18, 2012, 09:45 AM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
slo, you using a DX6i ?
If yes, try this:
http://www.rcgroups.com/forums/showp...2&postcount=35
IFlyRCs is offline Find More Posts by IFlyRCs
Old Sep 18, 2012, 12:36 PM
ichiban is offline
Find More Posts by ichiban
Los Angeles
Joined Nov 2006
Originally Posted by microkid View Post
There are videos of me flying it and myy dad the cameraman doing maiden daytime and nightime flights and a review and where I got it..
My account is Airplanekid95 on youtube
It's polite to include a link to your video or channel.
Here's a link to his popiwngs maiden night flight.
Looks like you had a great birthday!
ichiban is offline Find More Posts by ichiban
Old Sep 18, 2012, 04:21 PM
Joined Aug 2012
If yes, try this:
Yes, I am using DX6i. Thanks for the link, I'll check it out to see if it helps with my issue.
Old Sep 18, 2012, 06:19 PM
microkid is offline
Find More Posts by microkid
flight investigator in service
Lakewood,Ohio
Joined Jan 2009
QUOTE=ichiban;22766894]It's polite to include a link to your video or channel.
Looks like you had a great birthday![/QUOTE]
Thanks very kindly you good man
Yeah the setup on those lights took forever 2 hours to get them shaped and lit up, hope you enjoy the new review video I just posted showing the electronics I have on it and radio I used. This plane is great watch my other airplane videos as well
microkid is offline Find More Posts by microkid
Old Sep 22, 2012, 06:34 PM
mycaptain is offline
Find More Posts by mycaptain
mycaptain's Avatar
United States, MI, Kalamazoo
Joined Jan 2012
900 Pop Wing CG?
Ahoy! I have a 900 Pop Wing with a Parkzone 1300ma battery in it. I had to add 45 grams of lead inside the EPP skid foam piece to get CG at 210mm from the nose of the plane. Does this sound right? It seems like a lot of weight to me, considering I'm already using a bigger battery than recommended. Getting ready to madian. Thanks, Capt'n Ron
mycaptain is offline Find More Posts by mycaptain
Old Sep 22, 2012, 07:11 PM
TronZy is offline
Find More Posts by TronZy
United States, VA, Winchester
Joined Aug 2012
If yes, try this:
Thank you, this worked for me.
TronZy is offline Find More Posts by TronZy
Old Sep 23, 2012, 04:20 PM
flyrtim is offline
Find More Posts by flyrtim
United States, NM, Santa Fe
Joined Aug 2011
mini pop wing dx6i set up dual ailerons
yes I have seen this post--but I still have some questions
Next, go to Mix 1 and set Elev -> Flap with both rates (D & U) at 100%.that was -100%, but you may have to use +100 percent
did you end up doing -100% or +100% ?
Now, if you want differential it should work perfectly
did you set up differential, if so how ?
If you go to Dual Rates and reduce your top rate down at least to 80% of full
am I supposed to do this change on Mix 1 setting or on the Dual rates setting? I am guessing it is on the dual rates
and I am suppseed to leave Mix 1 D + U rates both at 100%
when do you use the flaps ?
flyrtim is offline Find More Posts by flyrtim
Old Sep 23, 2012, 09:20 PM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
Plus 100
No
Dual Rates
Go down to maybe 60 Ail and Ele with around 25 expo to start,
That will make your maiden safer.
Then bring the rates up to meet your skill/comfort level.
Yes
No Flaps
Good luck... I know you'll have fun!
This little plane is a hoot if it has some power.
Old Sep 23, 2012, 09:58 PM
flyrtim is offline
Joined Aug 2011
IFlyRCs -- thanks a lot ! that clears things up
so, no flaps though flaps are set up in Mix 1 ?
I suppose just no need to lower elevons to lower flap position?
Old Sep 23, 2012, 10:45 PM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
The flap setting was only involved to make things move the right way and requiring only one mix to be used.
To my knowledge no one uses flaps with delta wings.
I have no idea if flaps would even function with this setup.
I don't think the flap switch will do anything if you flick it.
Old Sep 23, 2012, 11:42 PM
GRUMPEE is offline
Find More Posts by GRUMPEE
Mr. Magoo's Co-Pilot
GRUMPEE's Avatar
United States, CA, San Diego
Joined Sep 2009
It works. If someone wanted to add a little up elevator at launch:
With flap/gyro switch to up set flaps to desired value but leave elevator @ 0. After launch flip the switch down.
GRUMPEE is offline Find More Posts by GRUMPEE
Old Sep 24, 2012, 12:35 PM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
Thanks Grump,
That might be helpful for more effortless gliding too.
I'm almost constantly feeding up while gliding.
Old Sep 24, 2012, 07:17 PM
flyrtim is offline
Joined Aug 2011
okay I am having trouble
elevons/elevator working correctly--ailerons opposite
ailerons function opposite and hitting Reverse just makes them work on the elevator control. I have tried both configurations of ailerons in Aux and Ailerons in the receiver. I have specktrum ar6100e.
on wing tail mix I have dualaile ACT. Vtail INH Elevon INH.
MIX 1
elev>flap act
rate d +95% U + 95%
SW on TRIM ACT
UPDATE
PHEW I got everything to work by putting R aileron in Aux 1 and Reversing Elev, Aile, and Flap.
overdriving servos
also seems like servos are overdriving espcially when using extreme elevator with extreme aileron at same time even though in dual rates I have it them 70%. Do I need to do travel adjust or sub trim?
Question Techone models?? lectroglide Scratchbuilt Indoor and Micro Models 5 Aug 07, 2011 01:54 PM
Sold Techone Energy EPP Foamy Wattsup23 Aircraft - Electric - Airplanes (FS/W) 9 Mar 31, 2011 03:28 AM
Sold Techone Piaget 3D EPP New in box $45 shipped! Lindy757 Aircraft - Electric - Airplanes (FS/W) 2 Mar 17, 2011 11:01 PM
Discussion TechOne F3P??? cglynn Indoor Pattern/F3P 6 Mar 11, 2011 01:24 PM
Question techone malibu 2 or techone aeolus? genesis96 Indoor Pattern/F3P 16 Jan 19, 2011 01:02 PM
