Old Sep 15, 2012, 08:49 PM
ichiban is offline
Find More Posts by ichiban
Los Angeles
Joined Nov 2006
Originally Posted by HoosierGuy View Post
My LEDS came and I hooked them up to a 3 cell. Wow, they really pop!
I was watching a flitetest video on leds and they said for jumpers you can use something called foam wire. I looked that up on google and found simple wire that gardeners use to tie up tomato plants and such. Is that all that is needed to connect my leds (jumpers)?
I have two strings of LEDs; one in the left and one in the right parts of the wing. The end of each string is folded back between the side edge of the wing and the fin. The start of each string is in the battery tray. Taking the wire from two JST connector pig tails, I soldered two wires (black and red) to the start of each LED string. I then soldered the two red wires to the positive terminal and the two black wires to the negative terminal of a male battery connector. This puts the two strings of LEDs in parallel so both strings get the same voltage. (Putting them in series is likely good enough.) Using a home made Y splitter I can connect the battery pack to only the ESC for day flying or both the ESC and LED system in parallel for night flying.
ichiban is offline Find More Posts by ichiban
Old Sep 16, 2012, 04:29 PM
HoosierGuy is offline
Find More Posts by HoosierGuy
HoosierGuy's Avatar
United States, IN
Joined Jan 2012
Got some Goop (never used it before) so I might put a coat of Goop on the leading edge of my 35 inch wing later tonight.
HoosierGuy is offline Find More Posts by HoosierGuy
Old Sep 16, 2012, 04:46 PM
Hit N Run is offline
Find More Posts by Hit N Run
Fly it low.. and fly it fast!
Hit N Run's Avatar
United States, MA, Westport
Joined Nov 2011
I just got back from flying my Popwing and Mini Popwing. It was a great day for flying!
Hit N Run is offline Find More Posts by Hit N Run
Old Sep 16, 2012, 05:03 PM
ichiban is offline
Los Angeles
Joined Nov 2006
I use Goop on the inside of my RC car bodies to strengthen the lexan and get longer use out of them. I started out with Goop on the edge of my mini popwing but it wasn't spreading out as easily as I wanted. I had some seal-all which is a silicone contact adhesive like Goop but with less viscosity. Each will do the job. And I tried using a credit card to spread but had better control using my finger.
Old Sep 17, 2012, 12:39 AM
HoosierGuy's Avatar
United States, IN
Joined Jan 2012
What are good wires to use as jumpers for LEDs? I have some Turnigy wires but they are too thick and I don't want to waste them if simple wires will do the job.
Old Sep 17, 2012, 02:03 AM
ichiban is offline
Los Angeles
Joined Nov 2006
If you got a roll of LEDs from nitroplanes it should have come with some leads on both ends of the LED strand. Otherwise, servo wire is sufficient so use a spare servo extension cable or the servo wire from a broken down junk servo. Servo wire gauge is typically 22 and 24. Careful not to tear the wires jacket when separating the servo wires.
Old Sep 17, 2012, 11:59 AM
Captain Ron is offline
Find More Posts by Captain Ron
STOP CALLING THEM "DRONES!!!"
Captain Ron's Avatar
Las Vegas, NV.
Joined May 2009
What I did was use an old ethernet cable. Cut the ends off then pull out all the wiring inside. That wire is small, light and easy to solder.
Captain Ron is offline Find More Posts by Captain Ron
Old Sep 17, 2012, 02:19 PM
chippedprop is offline
Find More Posts by chippedprop
Joined Feb 2008
OK
Here is some video (poor grade ) of the popwing
What's in it
MicroDan 2900 kv motor
40 amp esc...pulls 33amps
Master air screw 6x4
Hitec 82 mg servos
2.4 spectrum 4 ch.
TECHONE POPWING 1200mm (5 min 2 sec)
It's a hand full....but a lot of fun!!!!!!!!!
chippedprop is offline Find More Posts by chippedprop
Old Sep 17, 2012, 03:00 PM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
That's pretty awesome.
What battery balanced it out?
Stock elevons?
IFlyRCs is offline Find More Posts by IFlyRCs
Old Sep 17, 2012, 06:04 PM
DJO is offline
DJO
Find More Posts by DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
Maiden tomorrow, hopefully.
Dan
DJO is offline Find More Posts by DJO
Old Sep 17, 2012, 06:14 PM
HoosierGuy's Avatar
United States, IN
Joined Jan 2012
Flew my Pop Wing (35 inch) again this evening. Did a nice job flying. It was slightly windy. I tamed down the dual rates and flew it on very low rates. It still was a little twitchy when I gave it up or down elevator. Also, I had to fly it almost constantly puling the elevator stick back to keep the nose up.
Two kids down the road heard it (while feeding their pigs!) and came down to watch with their dogs. Dogs chased my wing around the field. lol.
Old Sep 17, 2012, 06:53 PM
HoosierGuy's Avatar
United States, IN
Joined Jan 2012
I've got to put a more powerful motor in my wing. After flying it two times it flies a little too slow or underpowered. It seems like I hit max throttle when my throttle stick is only 3/4 up and I get not more increase in power when I to full throttle.
I have this motor and I'm going to try it in my 35 inch Pop Wing:
http://www.ebay.com/itm/RC-2212-6-22...item27b91e2e9b
Old Sep 17, 2012, 10:44 PM
microkid is offline
Find More Posts by microkid
flight investigator in service
Lakewood,Ohio
Joined Jan 2009
Hey everyone
I just recently go a popwing and its a blast to fly!
I had it for 2 weeks and flown it a dozen times already.
There are videos of me flying it and myy dad the cameraman doing maiden daytime and nightime flights and a review and where I got it..
My account is Airplanekid95 on youtube
Happy flying!!
microkid is offline Find More Posts by microkid
Old Sep 17, 2012, 11:17 PM
ThatGuy123 is offline
Find More Posts by ThatGuy123
TAS Foamies was here!!!!!!!!
United States, CA, Thousand Oaks
Joined Jul 2011
Rebuilt my motor box on my mini popwing and I am going to try an apc .... Has anyone used one yet? If so what size and how well did it work?
ThatGuy123 is offline Find More Posts by ThatGuy123
Old Sep 18, 2012, 07:52 AM
Joined Feb 2008
Stock elevons?
turnigy 2200 plus I had to add 2 oz of nose weight due to upgrades
flight weight whopping 30 oz
next edition I'll not go over kill....reduce weight -increase speed- vert. and fun
Question Techone models?? lectroglide Scratchbuilt Indoor and Micro Models 5 Aug 07, 2011 01:54 PM
Sold Techone Energy EPP Foamy Wattsup23 Aircraft - Electric - Airplanes (FS/W) 9 Mar 31, 2011 03:28 AM
Sold Techone Piaget 3D EPP New in box $45 shipped! Lindy757 Aircraft - Electric - Airplanes (FS/W) 2 Mar 17, 2011 11:01 PM
Discussion TechOne F3P??? cglynn Indoor Pattern/F3P 6 Mar 11, 2011 01:24 PM
Question techone malibu 2 or techone aeolus? genesis96 Indoor Pattern/F3P 16 Jan 19, 2011 01:02 PM
