Old Aug 28, 2012, 09:12 PM
cnims is offline
Find More Posts by cnims
cnims's Avatar
United States, TX, Coppell
Joined Dec 1996
The CG for the 1200mm version is between 195 - 205mm from the leading edge.
cnims is offline Find More Posts by cnims
Old Aug 30, 2012, 01:37 PM
millera1 is offline
Find More Posts by millera1
USA, LA, Sorrento
Joined Jul 2007
Picked up a mini and a 35" the mini is great fun in the back yard and down the street I got the NP combo for both and 800 mah 2cell and 1300 mah 3cell building the 35" now should have it in the air by the weekend the. Mini flys great @1/4 to1/2 throtel but when I punch it it's lacking umph would like to use the bats and esc I have is there a better motor in this weight class i could use
Andy
millera1 is offline Find More Posts by millera1
Old Sep 01, 2012, 03:20 PM
HoosierGuy is offline
Find More Posts by HoosierGuy
HoosierGuy's Avatar
United States, IN
Joined Jan 2012
My 35 inch Pop wing came yesterday. I'll start on it Sunday night. What's the best way to glue the two wing parts together? Hot glue or Shoo Goo or something else?
HoosierGuy is offline Find More Posts by HoosierGuy
Old Sep 01, 2012, 03:56 PM
Hit N Run is offline
Find More Posts by Hit N Run
Fly it low.. and fly it fast!
Hit N Run's Avatar
United States, MA, Westport
Joined Nov 2011
I used epoxy. Working really good. I crashed today at the flying field about 4 hours ago. It was pretty windy (15-20mph winds). As I was flying around back and forth between half and full throttle......... SNAP!!
The wing snapped right in half. BUT, it broke an inch to the left of where I originally glued the two halves together with 30 minute epoxy. So seeing that evidence, I would say epoxy will do the job pretty well.
Hit N Run is offline Find More Posts by Hit N Run
Old Sep 01, 2012, 04:55 PM
Sooby22 is offline
Find More Posts by Sooby22
Threadliest Catch
United States, MO, St. Robert
Joined Jun 2012
That is weird that it broke like that. I rough handle mine and crash it all of the time and it doesn't do that. Did you use the right kind of epoxy? I just used CA and activator for mine. Here is an example of us bashing it around and how I built it.
Nitroplanes.com 900mm Pop Wing Build (21 min 21 sec)
Nitroplanes.com Pop Wing Catch (3 min 21 sec)
Sooby22 is offline Find More Posts by Sooby22
Old Sep 01, 2012, 04:59 PM
Schoolya is offline
Find More Posts by Schoolya
Schoolya's Avatar
United States, FL, Mayo
Joined Jul 2012
the oddest thing about that crack is I see no rods installed across the split, as the instructions say to install. I have smacked mine into the ground and 70mph, and while it did rip the motor mount off and get a large crack between the 2 wings, the CF rods stopped a complete split.
Schoolya is offline Find More Posts by Schoolya
Old Sep 01, 2012, 05:01 PM
Sooby22 is offline
Threadliest Catch
Joined Jun 2012
Yeah, there is at least three CF rods that run across the middle section to prevent that from happening. I even mention that in the build video up above.
Old Sep 01, 2012, 05:15 PM
Hit N Run's Avatar
Joined Nov 2011
Yep, that's what it was.
I'll be fixing that mistake........
Old Sep 01, 2012, 11:21 PM
visualizerent is offline
Find More Posts by visualizerent
United States, CA, Nevada City
Joined Sep 2012
Anyone try mounting a GoPro Camera on the large Pop Wing?
I'm looking for an inexpensive wing for a stable GoPro platform.
JB
visualizerent is offline Find More Posts by visualizerent
Old Sep 02, 2012, 11:29 AM
Diane@lazertoyz is offline
Find More Posts by Diane@lazertoyz
Diane@lazertoyz's Avatar
United States, OH, Eastlake
Joined Jan 2007
a good subsitute is 1 x 6 flat works great- even stronger!
Diane
Lazertoyz
Diane@lazertoyz is offline Find More Posts by Diane@lazertoyz
Old Sep 02, 2012, 02:14 PM
ichiban is offline
Find More Posts by ichiban
Los Angeles
Joined Nov 2006
The cool thing I hear, you can have more epoxy and tape than foam and it will still fly well!
ichiban is offline Find More Posts by ichiban
Old Sep 02, 2012, 03:00 PM
Hit N Run's Avatar
Joined Nov 2011
Well thank god for that!
Old Sep 03, 2012, 04:19 PM
DJO is offline
DJO
Find More Posts by DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
Thinking of grabbing a mini popwing for fun both at the high school and a small baseball field... I used to have the HK Bonsai and it was awesome, do you think I could use a 800 mAH or 950 mAH 2S pack on these? Or would it be better with a 600 mAH one?
Never mind, I think I'll just grab a couple hundred of these...
http://www.hobbyking.com/hobbyking/s...dproduct=20649
Dan
DJO is offline Find More Posts by DJO
Old Sep 03, 2012, 05:55 PM
ichiban is offline
Los Angeles
Joined Nov 2006
Some fliers are using 3s (850mAh, 1000mAh, 1300mAh) so why not!
Old Sep 03, 2012, 05:57 PM
DJO is offline
DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
Well I will be just using the stock setup that comes ARF (PNP)... hmmm
Question Techone models?? lectroglide Scratchbuilt Indoor and Micro Models 5 Aug 07, 2011 01:54 PM
Sold Techone Energy EPP Foamy Wattsup23 Aircraft - Electric - Airplanes (FS/W) 9 Mar 31, 2011 03:28 AM
Sold Techone Piaget 3D EPP New in box $45 shipped! Lindy757 Aircraft - Electric - Airplanes (FS/W) 2 Mar 17, 2011 11:01 PM
Discussion TechOne F3P??? cglynn Indoor Pattern/F3P 6 Mar 11, 2011 01:24 PM
Question techone malibu 2 or techone aeolus? genesis96 Indoor Pattern/F3P 16 Jan 19, 2011 01:02 PM
