Old Oct 26, 2011, 02:42 PM
wantoofly is offline
Find More Posts by wantoofly
wantoofly's Avatar
United States, TX, Navasota
Joined Apr 2009
Will do! I don't think it will be possible, just trade off weights and components. I havn't had any time lately but I'll be playing with it.
wantoofly is offline Find More Posts by wantoofly
Old Oct 26, 2011, 10:49 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Anyone have an idea of top speed on the 35" version with the stock motor/prop? 60-70mph?
Sammy70 is offline Find More Posts by Sammy70
Old Oct 26, 2011, 11:10 PM
Sammy70 is offline
Sammy70's Avatar
Central Ohio
Joined Feb 2008
The 35" version is the "Deal of the Day" at www.Commonsenserc.com until Thursday.
Wing kit, motor, prop, and 6ch clone Spektrum Rx for 79.95 shipped.
Old Oct 27, 2011, 07:53 AM
wantoofly's Avatar
Joined Apr 2009
Down wind and in a dive with a 1600mha 3s maybe?
Old Nov 10, 2011, 10:27 PM
Sammy70 is offline
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Cg???
What CG point are you guys running?
I've read some posts that say the manual recommended 200-212mm makes it too tail heavy, some say it's great there
I just finished mine (stock 2208 motor, 8g servos, etc.) and a quick check on my CG sticks and I can tell it's going to take a LOT more than a 1300mah 3s to get close to 200mm.
Old Nov 11, 2011, 06:30 AM
Vito is offline
Find More Posts by Vito
USA, PA, New Hope
Joined Nov 2001
I am flying a 1000mAH 3 cell that I had on hand. I needed to add a significant lead slug to the nose to get the recommended CG. I hate to add lead, but it flies fine. I bored a 3/8 inch hole in the nose and in a block of scrap wood. I poured molten lead into the block and when it solidified transferred it to the hole in the foam. That worked fine with minimal disturbance to the foam.
I agree that a larger battery gives you something for the weight, but the battery hole can only get so big before it compromises the structure of the nose.
The Popwing is the plane I fly the most. Always in the car when I go to the field.
Vito
Vito is offline Find More Posts by Vito
Old Nov 11, 2011, 11:13 AM
Sammy70 is offline
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Vito
So you do fly it with your CG at the 200-210mm then?
If not, what CG point did you end up liking?
Old Nov 11, 2011, 03:14 PM
Vito is offline
USA, PA, New Hope
Joined Nov 2001
I just measured 20 cm from the nose to the balance line that I use
Vito
Old Nov 11, 2011, 04:47 PM
Sammy70 is offline
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Vito
Thanks Vito. 20cm/200mm is what the manual calls for (although the manuals are rarely correct), so I'll start there and see how it goes.
Last question for you all:
How much control surface deflection are you guys using? I was thinking maybe 3/4" up/down?
Old Nov 23, 2011, 02:57 AM
xrx1113 is offline
Find More Posts by xrx1113
xrx1113's Avatar
United States, FL, Lehigh Acres
Joined Aug 2011
I got the mini last week love it will keep as my truck plane. Was very windy and i could still fly, wings are great.bop
xrx1113 is offline Find More Posts by xrx1113
Old Nov 23, 2011, 04:43 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
My Mini Popwing is ready for maiden, but my instructions seemed to have left town, where's the suggested CG?
I generally a slow builder, but what little assembly was required on this was impressive, nice kit.
Azarr
Azarr is offline Find More Posts by Azarr
Old Nov 24, 2011, 06:22 AM
aclinml is offline
Find More Posts by aclinml
Joined Jun 2008
Wing tip location???
Hey, guys. I just picked up the MINI from Common Sense on a sale. All the pictures I have seen of the plane from the TechOne site, and other hobby shops, show the wing tips pointing up from the end of the wing, BUT....the instructions in the manual that came with the plane, clearly show mounting the wing tips with them hanging DOWN from the end of the wing....
Which is correct???
aclinml is offline Find More Posts by aclinml
Old Nov 24, 2011, 06:26 AM
aclinml is offline
Joined Jun 2008
Azarr
Azarr, the instructions in the manual say 135 to 142mm from the center point of the wing.....
Let us know where you get your best results with!
Old Nov 24, 2011, 07:53 AM
Vito is offline
USA, PA, New Hope
Joined Nov 2001
Mike,
I built mine with the tips above the wing. Look at the pictures on the first page of this thread.
Vito
Old Nov 24, 2011, 08:28 AM
Azarr is offline
Azarr's Avatar
Joined Jan 2000
Might get to fly it Sat. It took a 730mah pack to get in the range. Hopefully the CG isn't off on the mini also.
Azarr
Question Techone models?? lectroglide Scratchbuilt Indoor and Micro Models 5 Aug 07, 2011 01:54 PM
Sold Techone Energy EPP Foamy Wattsup23 Aircraft - Electric - Airplanes (FS/W) 9 Mar 31, 2011 03:28 AM
Sold Techone Piaget 3D EPP New in box $45 shipped! Lindy757 Aircraft - Electric - Airplanes (FS/W) 2 Mar 17, 2011 11:01 PM
Discussion TechOne F3P??? cglynn Indoor Pattern/F3P 6 Mar 11, 2011 01:24 PM
Question techone malibu 2 or techone aeolus? genesis96 Indoor Pattern/F3P 16 Jan 19, 2011 01:02 PM
