Old Apr 21, 2012, 09:53 PM
OTTOFLYS is offline
Find More Posts by OTTOFLYS
Grand Rapids MI.
Joined Feb 2011
I know nothing bout reflex but what I do know is:
Emax Cf2822 swinging an 8x5 master airscrew specs are in.
on 3s 25C
13.5 Amps
156 watts
680 grams thrust
large popwing in a dive with mild tail wind= friggin awsome, speeds.....well I guessed 65, but the old boys at the field today all said 70-75+ without a doubt. Where can I get a radar gun?
Syner you gotta get the grayson setup going and let us know LOL I feel the need to make this thing GO FASTER
OTTOFLYS is offline Find More Posts by OTTOFLYS
Old Apr 21, 2012, 09:59 PM
Syner01 is offline
Find More Posts by Syner01
United States, NJ, Lodi
Joined Jan 2012
Halfway through build now. Just glued in servos. Just letting all glue from different parts dry. Tomorrow is raining by me so I should finish tomorrow and look to maiden Monday. Motor/esc Grayson combo arrived also so very soon I should have some video.
on 3s 25C
13.5 Amps
156 watts
680 grams thrust
Syner01 is offline Find More Posts by Syner01
Old Apr 21, 2012, 10:06 PM
OTTOFLYS is offline
Grand Rapids MI.
Joined Feb 2011
SAWEET can't wait.
my camera is a piece so no video here, but I'm looking at a gopro so I can get some of this stuff on film
good luck bro
Old Apr 21, 2012, 10:36 PM
Syner01 is offline
Joined Jan 2012
Helmet cam bro. I'd rather see the planes 3rd person than 1st.
SAWEET can't wait.
good luck bro
Old Apr 21, 2012, 10:55 PM
OTTOFLYS is offline
Grand Rapids MI.
Joined Feb 2011
I know I hate on board
I tried with the hat cam deal with my MD80 but I can never get it at the correct angle its always sky or ground. LOL I'll get it dialed in eventually
Old Apr 22, 2012, 08:11 AM
Carnifax is offline
Find More Posts by Carnifax
Carnifax's Avatar
Cleveland
Joined Jun 2002
This is a very fun plane to fly. I had mine out yesterday in "big wind". Flying with a 3s 2100 adds just the right amount of weight to help out stability. I was pleasantly surprised at how well this handles the upwind passes. I would dare say its almost as stable into the wind as downwind but maybe its a matter of perception. In the end its really just a cool, fun plane to fly.
Carnifax is offline Find More Posts by Carnifax
Old Apr 22, 2012, 04:49 PM
OTTOFLYS is offline
Grand Rapids MI.
Joined Feb 2011
Crash
So I got a bit of video today in the wind
sorry bout the garb at the begining, I don't have any way to edit right now. skip ahead to 1 minute
camera definantly doesn't do it justice as far as the speed but it show the capability of this plane in high winds
Unfortunantly enough my last pass and touch and go/motor removal was just out of the frame but skip ahead to about 7 minutes for the good part
I pulled up just enough to only tag the back half on the ground. the nose is 100% intact LOL sure makes an interesting sound where it hits
Popwing Flying in the wind (CRASH) (7 min 53 sec)
Old Apr 22, 2012, 06:13 PM
Syner01 is offline
Joined Jan 2012
What'd you have a tornado passing through? That wind sounded like it was ripping.
Speed wise I think my minipopwing moves faster and faster rolls but again with that much wind it is hard to tell. You're getting some decent vertical though.
Lol I was saying aggghhh at the exact same moment as you when it hit.
I thought the kid was filming but he was on the bike at the end. Do you have a helmet cam?
Some thick ca and accelerator should help you fix that mount.
What size prop are you running?
http://www.youtube.com/watch?v=2z2eT...ature=youtu.be
Old Apr 22, 2012, 07:52 PM
OTTOFLYS is offline
Grand Rapids MI.
Joined Feb 2011
Ya I was using an MD80 cam like these
http://www.ebay.com/itm/Mini-DV-MD80...item3cc5439d06
strapped to my hat with an elastic band from a work light.
I was using a 8x5 master airscrew prop with an Emax Cf2822 motor.
look at post #181 for the watt meter data on that setup. I believe that motor is max of 16 amps
I think you are correct about the speeds and roll rate. From the videos I've seen of the mini, it rolls much faster than the full sized wing.
Although there are a couple of us now working on go fast setups....I have an idea that I might try hehe all I can say right now is ah..... 3200kv and its also requires a 60 amp esc and if that isn't going to work I have a stryker settup I may try!
Old Apr 22, 2012, 08:40 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Ah, the infamous "one more pass" syndrome!!
Sammy70 is offline Find More Posts by Sammy70
Old Apr 25, 2012, 09:34 PM
Syner01 is offline
Joined Jan 2012
ok Otto, since you were such a good sport i am going to show my maiden video. i also had a little 'accident' at the end. for speed it is not a good video because i didn't have recommended 6x4 prop size so i was using 5.25x6.25 prop. also 1300mah battery i could not get cg so i carved out battery tray and used 2200mah 3s and it balanced fine after that. the right props came in today so i will be able to test properly soon. here you go:
LazerToyz Popwing (3 min 29 sec)
Old Apr 25, 2012, 09:54 PM
OTTOFLYS is offline
Grand Rapids MI.
Joined Feb 2011
OHHHH that was a pretty go hit, nosed Er in hard. Hopefully all was ok. Looks like you got yoourself a nice flying plane. I'm sure you'll love the other prop, it should have a bit more torque on the bottom end and also be more responsive to throttle input.
Nice Job Syner
Otto
Just a heads up I got my new setup on and running tonight.
pulls 50 amps and 430 watts on 3s and who knows what 4s will do!!!!
I'll keep you filled in fosho
Old Apr 26, 2012, 01:57 AM
Syner01 is offline
Joined Jan 2012
Anyone know the "wing area" of the popwing and minipopwing? Not wingspan. Wing area.
Old Apr 26, 2012, 04:55 PM
potshot is offline
Find More Posts by potshot
Vertical approach specialist
potshot's Avatar
Northeastern Illinois
Joined Mar 2009
I measured my Popwing and laid it out in AutoCAD. With elevons the total area is 397.6 sq. in. and without the elevons it's 334.9.
Sorry, don't have the mini.
potshot is offline Find More Posts by potshot
Old Apr 26, 2012, 08:23 PM
OTTOFLYS is offline
Grand Rapids MI.
Joined Feb 2011
My new settup/idea didn't fair so well BL15 (3200KV) out of a Pz Habu edf with a custom made mount and a 4.75" square prop....
Hauls A##
then I saw the magical white smoke LOL kinda like a real jet
Hunting for a new motor as we speak
Question Techone models?? lectroglide Scratchbuilt Indoor and Micro Models 5 Aug 07, 2011 01:54 PM
Sold Techone Energy EPP Foamy Wattsup23 Aircraft - Electric - Airplanes (FS/W) 9 Mar 31, 2011 03:28 AM
Sold Techone Piaget 3D EPP New in box $45 shipped! Lindy757 Aircraft - Electric - Airplanes (FS/W) 2 Mar 17, 2011 11:01 PM
Discussion TechOne F3P??? cglynn Indoor Pattern/F3P 6 Mar 11, 2011 01:24 PM
Question techone malibu 2 or techone aeolus? genesis96 Indoor Pattern/F3P 16 Jan 19, 2011 01:02 PM
