Old Apr 19, 2012, 06:03 PM
OTTOFLYS is offline
Find More Posts by OTTOFLYS
Grand Rapids MI.
Joined Feb 2011
Learn somthing New everyday.....RX fixed it. Must have been glitchen quite a bit cuz it flies better now that it ever has, even after all the crashing an gluen the nose back togather LOL
Lesson learned!
OTTO
OTTOFLYS is offline Find More Posts by OTTOFLYS
Old Apr 19, 2012, 06:22 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
What Rx was it?
Sammy70 is offline Find More Posts by Sammy70
Old Apr 19, 2012, 10:00 PM
Syner01 is offline
Find More Posts by Syner01
United States, NJ, Lodi
Joined Jan 2012
was the RX blinking?
lol, i'll let you know about the grayson.
Originally Posted by OTTOFLYS View Post
Just had an issue with the emax motor aswell. I do believe I have a bad RX and am experiencing my first encounters with Brown outs. Range tested it and its all over the place??? 1 time it will work to 30 paces b4 cuttout then the next try I only make it 10-12 paces b4 it looses signal, and won't re connect till I'm standing on top of it again. So I may have to retract my first statement about the T-motor, time and testing will tell???
Syner please keep us posted, I really want to try it aswell but your the guinea pig for now LOL
Syner01 is offline Find More Posts by Syner01
Old Apr 19, 2012, 10:56 PM
OTTOFLYS is offline
Grand Rapids MI.
Joined Feb 2011
It was the spektum compatible from HeadsupRc http://www.headsuprc.com/servlet/the...hz-DSM2/Detail
It looks exactly the same as this one, that fixed my problem http://www.commonsenserc.com/product...oducts_id=2865
And no the light was not flashing it was on steady
I did find a small amount of clear Rtv silicone between the prongs of the open channels after I pulled it out. I like using it to mount receivers, but the excess ouzed out and may have caused the issue but I did't think silicone was a conductor.
The more I think about it, it was on the rudder channel and it always went dead sticks when banking a turn. I know I know....no rudder hear but, out of pure habit I still catch myself giving this thing rudder input.
Has anyone had issues with the headsup Rx or know if Clear RTV silcone is a conductor?
Old Apr 20, 2012, 05:08 AM
Syner01 is offline
Joined Jan 2012
I use this RX and it works great.
http://www.targethobby.com/spectrum-...p-4161774.html
Can't beat the price either.
I use the ar500 and ar6200 also from their page here. Never had any problems with them.
http://www.targethobby.com/transmitt...iver-c-72.html
You can see example here on how far I go out with them. Watch full screen on pc because I will be a pin dot after awhile if not full screen from being a bit far out.
Parkzone T28 HeadCam (5 min 46 sec)
Old Apr 20, 2012, 07:21 AM
OTTOFLYS is offline
Grand Rapids MI.
Joined Feb 2011
Wow those are cheap, are they the real deal or the nock offs? Great price either way.
Great video too.
I tested my wing and went as far I could see it and still had total control so I think the issue is handled, you can see it pretty good being as big as it is. The neighbor down the road came over to check it out, LOL he said I was banking my turns over his house. Thats exactly 1/4 mile away, so range is not a problem anymore.
What kind of flight times are people gettin out of em?
I use a couple differant batteries but one example for me is an 1150mah timer set at 8 1/2 minutes and I only pulled 550-650 mah out.
So I tried 850 mah packs and an added weight it the nose 8-8 1/2 minute flights and the charger show it drawing about the same amount out of the pack so its (not totally draining) spot on.
I LOVE THIS WING
Old Apr 20, 2012, 07:47 AM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Pretty sure they are knockoffs, I've used them though with no issue.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Apr 20, 2012, 10:14 AM
Syner01 is offline
Joined Jan 2012
indeed they are for that price. like you i have a couple dozen and haven't had any issue with any of them.
Old Apr 20, 2012, 10:16 AM
Syner01 is offline
Joined Jan 2012
on my minipopwing i can get up to 15 min on a battery if i throw in coasting half the time. if there are some decent winds i will fly around a bit then jump up high and ride the wind around w/no throttle until i get back down.
coasting like i am doing from 0:50 - 1:05 here. on some winds i can coast about 40-60 yards before having to hit the throttle.
you can see i am getting some good range in this vid also. i have gone probably double the farthest distance you see in the video with the mini. beyond that it's more of an orientation issue than rx range. the orange on one side and stripes on the other help but at some point it becomes just a dot and i have to turn back. the great thing about these though is if i lose orientation i can just cut the throttle and coast a bit until i figure it out. if i try that on say my rare bear i will be planting my prop in the ground real quick (ask me how i know lol).
Lazertoyz MiniPopWing (2 min 49 sec)
if i push WOT the whole time i get about 1/2 that time.
Great video too.
I LOVE THIS WING
Old Apr 20, 2012, 10:26 AM
Syner01 is offline
Joined Jan 2012
also i broke my 6x4E prop that came with the mini. in the meantime while waiting for replacements i have some 5.25x6.25. definitely not as good as the 6x4E. i have to use 1300 3s to get what i was getting on 6x4 w/800 2s. even then it is more speed than thrust (which makes total sense given the sizes). i have some 6x5 coming too that i will try once i get a hold of them. 6" definitely seems to be the sweet spot for the mini. just a matter of pitch preference/testing now.
Old Apr 21, 2012, 06:33 AM
kid at 55 is offline
Find More Posts by kid at 55
Where did that tree come from
kid at 55's Avatar
United States, SC, Lancaster
Joined Nov 2010
Maiden flight
Maiden my Popwing yesterday. First two launch was in the ground. Had to adjust my elevon up big time . Third time she took flight. Two right click and she was flying straight. I got three flights in with her and came home happy.
kid at 55 is offline Find More Posts by kid at 55
Old Apr 21, 2012, 09:45 AM
OTTOFLYS is offline
Grand Rapids MI.
Joined Feb 2011
Glad to hear you can home happy Kid, Mine did the dame thing on the maiden excapt it broke thre nose off. I was rather suprized at how high the elevon have to be to get it flyin right.
Old Apr 21, 2012, 01:43 PM
kid at 55's Avatar
Joined Nov 2010
Me too. It's a good thing it's made out of EPP.
Old Apr 21, 2012, 01:45 PM
Sammy70 is offline
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Most wings (and delta wing jets) need a decent amount of up reflex for level flight...
Old Apr 21, 2012, 06:20 PM
Syner01 is offline
Joined Jan 2012
For wings I thought it was just because the battery is up front. Is there some other reason? I am not that well versed in wing design but am curious to know.
Question Techone models?? lectroglide Scratchbuilt Indoor and Micro Models 5 Aug 07, 2011 02:54 PM
Sold Techone Energy EPP Foamy Wattsup23 Aircraft - Electric - Airplanes (FS/W) 9 Mar 31, 2011 04:28 AM
Sold Techone Piaget 3D EPP New in box $45 shipped! Lindy757 Aircraft - Electric - Airplanes (FS/W) 2 Mar 18, 2011 12:01 AM
Discussion TechOne F3P??? cglynn Indoor Pattern/F3P 6 Mar 11, 2011 02:24 PM
Question techone malibu 2 or techone aeolus? genesis96 Indoor Pattern/F3P 16 Jan 19, 2011 02:02 PM
