Old Apr 15, 2012, 10:44 PM
OTTOFLYS is offline
Find More Posts by OTTOFLYS
Grand Rapids MI.
Joined Feb 2011
Originally Posted by Sammy70 View Post
Why such the small battery?
With my 1300mah lipos I believe mine is at 220mm and flys great.
Good luck!
1150 is the biggest thing i have thats in the small catagory LOL
I have about a dozen 2200's or huge 4s
I may end up carving out room for the 2200 mah and going with a bit more in the power dept
Haven't even flown it yet but if I like it I'll probably do that and see what kind of speeds I can get out of it
on second thought I could just strap 2 800's in it ???
OTTOFLYS is offline Find More Posts by OTTOFLYS
Old Apr 16, 2012, 04:57 AM
kid at 55 is offline
Find More Posts by kid at 55
Where did that tree come from
kid at 55's Avatar
United States, SC, Lancaster
Joined Nov 2010
Tail heavy using what CG location?
As mentioned a few times before, I fly mine with anything from a 1300mah to 2200mah lipo and she flys great regardless. With the 1300mah my CG is quite a bit back from "stock" and I have to change the elev. trim maybe 3 clicks and she still flys just great....
Mine around 220 to 220.5 MM with the 1300 mAh.
kid at 55 is offline Find More Posts by kid at 55
Old Apr 16, 2012, 06:01 AM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
I've flown mine with 1550-2200 3S packs and not noticed a big change in CG overall.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Apr 16, 2012, 07:03 AM
OTTOFLYS is offline
Grand Rapids MI.
Joined Feb 2011
I think I'm going to hold off on carving out more foam and going with a 2200 if it doesn't make that much differance. Like I said I haven't even flown it yet, and unfortunanly probably not going to today either . The rain is done but the wind is gusty as heck. Steady wind I can handle but its not easy to maiden anything in 20-30mph gusts
-Otto
Old Apr 16, 2012, 04:17 PM
kid at 55's Avatar
Joined Nov 2010
OK Got my CG in range. Have my elevon with about a 1/8 of an inch gap with a straight edge on the bottom of the wing. How much travel and expo do I need ?
Old Apr 16, 2012, 08:31 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Everyone will have a different answer to those questions.
I have dual rates at something like 60% & 100%, with about 40% expo on all surfaces and both rate settings.
After flying you can adjust accordingly to your tastes...
Sammy70 is offline Find More Posts by Sammy70
Old Apr 17, 2012, 05:36 PM
bluemeane is offline
Find More Posts by bluemeane
bluemeane's Avatar
Joined Apr 2007
If you mean slow down for landing, don't worry, it slows down and lands with about zero airspeed--very easy...
I mean slow down and float it around a park 5 feet off the ground
bluemeane is offline Find More Posts by bluemeane
Old Apr 18, 2012, 05:07 AM
Diane@lazertoyz is offline
Find More Posts by Diane@lazertoyz
Diane@lazertoyz's Avatar
United States, OH, Eastlake
Joined Jan 2007
Popwings & mini popwings in stock!
We have them in stock - ready to go! 6 of each left I think-
Diane
Lazertoyz
Diane@lazertoyz is offline Find More Posts by Diane@lazertoyz
Old Apr 18, 2012, 07:03 AM
xrx1113 is offline
Find More Posts by xrx1113
xrx1113's Avatar
United States, FL, Lehigh Acres
Joined Aug 2011
i love my mini pop , i keep it in the truck .
xrx1113 is offline Find More Posts by xrx1113
Old Apr 19, 2012, 06:56 AM
OTTOFLYS is offline
Grand Rapids MI.
Joined Feb 2011
So it officail, the tiger motor is well.......Junk in my opinion. Finally got around to a maiden and absolutely love the popwing. Bench tested it prior to to flight and with a 25c 3s pack and using a 7x5E prop it pull 90 Watts at 8 amps with no issues. With that beeing said, pack # 4 flight the motor locked as if it overamped. CRASH and a nose job, pissed but easily fixxed with welders glue. Put the motor back on the meter with the same settup and its pulling 14A and cuts out after WOT for 10-15 seconds. I set it aside for a rewind at a later date. Put an Emax Cf 2822 on it using the same prop and batteries and it friggin ripps. Balanced out a bit better and has a ton more power. I love it, NOW
just my 2 cents but save your self some headaches junk the T-motor right out of the gate and use something else.
Otto
I'll post info on the T-motor after a rewind
Old Apr 19, 2012, 07:27 AM
Sammy70 is offline
Sammy70's Avatar
Central Ohio
Joined Feb 2008
What motor is that exactly? The stock motor for the larger Popwing?
If so, I've got at least two dozen flights on my stock motor (2208 1370Kv) swinging a 7x6 prop and it's been great. Not blazing fast, but probably 55-60mph flat and level.
Next for mine will be a 2210 or 2212 in the 2000Kv range...
Old Apr 19, 2012, 12:29 PM
GregSilver is offline
Find More Posts by GregSilver
GregSilver's Avatar
United States, FL, Plantation
Joined Nov 2005
Originally Posted by Sonny Cheeba View Post
Got mine just about built..... Running a Graysons Hobbies V2 Super Jet motor, with a Turnigy Plush 40a ESC, good ole Orange Rx, Tower pro metal gear servos, and Nano Techs 3s 2200mah with a 6/5 Prop...... I'm pretty sure this setup will get this thing moving pretty fast..... Any suggestions out there on how to configure the CG since its a much heavier setup then the "recommended"???
Thanks all,
Sonny
Sonny, the CG doesnt change. You balance it at the same point no matter what the weight is at the end of the build.
GregSilver is offline Find More Posts by GregSilver
Old Apr 19, 2012, 02:10 PM
OTTOFLYS is offline
Grand Rapids MI.
Joined Feb 2011
Yes Sir that exact motor. Maybe I got a lemon ,dunno. I do know that 4 packs deep it cooked something inside. And it rocks with the 2822 Emax motor. Like I said I will eventually find the issue when I dig into it to do a rewind.
I am going to try out a differant setup soon....prob this http://www.graysonhobby.com/catalog/...mbo-p-414.html
Or maybe thier supermegajet although it would take a solid 2200+ mah pack to balance out that heavy of a motor (76g) it would haul A##
http://www.graysonhobby.com/catalog/...esc-p-645.html
Old Apr 19, 2012, 03:17 PM
Syner01 is offline
Find More Posts by Syner01
United States, NJ, Lodi
Joined Jan 2012
I ordered the Grayson and a regular popwing. Will let you know how I make out.
Syner01 is offline Find More Posts by Syner01
Old Apr 19, 2012, 04:13 PM
OTTOFLYS is offline
Grand Rapids MI.
Joined Feb 2011
Just had an issue with the emax motor aswell. I do believe I have a bad RX and am experiencing my first encounters with Brown outs. Range tested it and its all over the place??? 1 time it will work to 30 paces b4 cuttout then the next try I only make it 10-12 paces b4 it looses signal, and won't re connect till I'm standing on top of it again. So I may have to retract my first statement about the T-motor, time and testing will tell???
Syner please keep us posted, I really want to try it aswell but your the guinea pig for now LOL
Question Techone models?? lectroglide Scratchbuilt Indoor and Micro Models 5 Aug 07, 2011 01:54 PM
Sold Techone Energy EPP Foamy Wattsup23 Aircraft - Electric - Airplanes (FS/W) 9 Mar 31, 2011 03:28 AM
Sold Techone Piaget 3D EPP New in box $45 shipped! Lindy757 Aircraft - Electric - Airplanes (FS/W) 2 Mar 17, 2011 11:01 PM
Discussion TechOne F3P??? cglynn Indoor Pattern/F3P 6 Mar 11, 2011 01:24 PM
Question techone malibu 2 or techone aeolus? genesis96 Indoor Pattern/F3P 16 Jan 19, 2011 01:02 PM
