Old Apr 23, 2011, 02:06 PM
simages is offline
Find More Posts by simages
AMA# SIMAGES
simages's Avatar
United States, NY, Cold Spring
Joined Dec 2006
Build Log
Stevens AeroModel - Swift (100)
My latest purchase from SA is the Swift (100) 21" and my next build. I like the idea of having all control surfaces besides getting hooked on the Spektrum BNF. I'm a Futaba guy however; I'm really liking my DX7 and looking forward to trying this AR6400LBL Ultra Microlite along with the AS2000 servos.
simages is offline Find More Posts by simages
Latest blog entry: Strega MK2 "P-51 Mustang" by...
Old Apr 23, 2011, 02:55 PM
rafe_b is offline
Find More Posts by rafe_b
Joined Jan 2009
Very nice, looking forward to the build and maiden report. She looks like a grown-up LittleRod.
rafe_b is offline Find More Posts by rafe_b
Old Apr 23, 2011, 09:49 PM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Oddly enough, this full sized small single seater appears to have been inspired by Stevens new kit ...
http://www.google.com/search?q=compe...w=1339&bih=574
Will give you a few ideas for colour schemes and other such stuff
D
Dereck is offline Find More Posts by Dereck
Old Apr 23, 2011, 10:08 PM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
D
Thanks - I'm thinking red and white, but those are a few more possibilities...
Keith
Old Apr 24, 2011, 12:01 PM
Stevens AeroModel is offline
Find More Posts by Stevens AeroModel
Truss-Loc Monkey
Stevens AeroModel's Avatar
Colorado Springs, CO
Joined Feb 2002
Lol certainly the other way around. We started in on the Comper but soon agreed it looked a bit to..... well.... British. A few curves here and there and once again there was harmony at the "skunked" works of the SA workshop.
Bill
D
Stevens AeroModel is offline Find More Posts by Stevens AeroModel
Old Apr 24, 2011, 12:21 PM
Dereck is offline
Joined Dec 1996
Okay - who's doing one with a dummy radial?
D
Old Apr 24, 2011, 02:37 PM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Keith
Or maybe the PT 19 color scheme or a PT 20
Old Apr 26, 2011, 11:23 AM
JRuggiero is offline
Find More Posts by JRuggiero
Blacksburg, VA 24060 USA
Joined Feb 2000
Stevens,
"We started in on the Comper but soon agreed it looked a bit to..... well.... British."
Though I'm a Yank, bred and true, I would take offence (offense, on this pond side) .
Jim R.
JRuggiero is offline Find More Posts by JRuggiero
Old May 06, 2011, 10:23 AM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
I just have to.......
Start the build..... It's just too hard to sit on my hands Derek....
Ordered some LiPos today with a weight of 17g and that's with a balance plug which I have to have on my lipos.
Thunder Power RC - 250mAh 2S 7.4V 20C ProLite V2
Wire Gauge: 20AWG
Weight: 0.60 oz (17g)
Length: 1.57 in (40mm)
Width: 0.83 in (21mm)
Height: 0.43 in (11mm)
Maximum Burst Discharge : 40C
Maximum Continuous Current : 5A
Old May 06, 2011, 01:29 PM
Dereck is offline
Joined Dec 1996
Build? What's with this building business?
I thought you got a bag of bits and a sachet of glue. Open the bag of bits, open and pour the glue into the bag, shake vigourously and test glide the complete model across the living room five minutes later...
Regards
Dereck
Who just cut out 12 tapered wing ribs for a 200% full size model - and survived with no cuts, which is pretty good, all things considered...
Old May 06, 2011, 01:47 PM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
I thought you got a bag of bits and a sachet of glue. Open the bag of bits, open and pour the glue into the bag, shake vigourously and test glide the complete model across the living room five minutes later...... Regards Dereck
You can almost do that with these SA kits!
Who just cut out 12 tapered wing ribs for a 200% full size model - and survived with no cuts, which is pretty good, all things considered... Regards Dereck
I usually CA my fingers before I cut myself however; my wife put a box of band-aids on my table while grinning..... what a gal!
Old May 08, 2011, 06:16 PM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Well........
That was easy!
Nice touch with the 11 page Photo Supplement "download"
I would recommend any of the Stevens AeroModel kits as a first time build!
Old May 10, 2011, 09:37 PM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Got started on covering
It was a little tougher to get aound this one...... I decided on white with red trim and will follow something like this scheme and it will evolve as I go.....
Old May 11, 2011, 06:58 AM
Dereck is offline
Joined Dec 1996
The FROG Linnet - a lovely model. The one I'm tinkering with is the 'Raven' from the same range, blown up to an IMAA Crushing 200%. Okay, that's all of 36" span
With painful childhod memories of cutting such kits out - dragging a razor blade through rock- hard fuzzy balsa around badly printed parts with all the patience a kid could raise - i could nearly go buy a small laser cut kit just to say I'd done it!
D
Old May 15, 2011, 09:31 PM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Well another wet weekend......
No problem did a little covering on the Swift, using th lines from the Ailerons and elevator.
Old May 15, 2011, 09:34 PM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Electronics started
finished the BL-1504 bullets and extended the AR6400LBL wiring. Pretty much sticking to the plans and instructions......
Had to clean up and reorganize the hobby room too, was getting hard to find everything.....
Old May 17, 2011, 12:19 PM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Now I have four projects to maiden....
Servos and control linkage went well and easy enough, although the CG is 1/8 behind the spar could use just a bit more weight in the front. Once again followed the plans and instructions.....
Old May 17, 2011, 02:36 PM
Thayer is offline
Find More Posts by Thayer
Owner - Flying Models
United States, CT
Joined Aug 2003
I would be wary of using that stand for models this small. The long plastic arms for measuring the CG location can throw off the actual weight and balance.
Didn't Bill already mark the underside of the wing? If so, simply remove the slides and go again.
Thayer
Thayer is offline Find More Posts by Thayer
Old May 17, 2011, 03:11 PM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Yes it's marked on the plans 1/8 inch from spar and checked it using pencils too.
Thayer
Old Jun 08, 2011, 10:49 PM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Silly Me.....
Had a problem with the throttle..... kept cutting out intermittently, discovered that it helps if you don't forget to set the esc throttle range......
It will fly I suppose.
Old Jun 21, 2011, 04:04 AM
vrex is offline
Find More Posts by vrex
Denver
Joined Mar 2004
I just bought one. His models are great! I build his Shaft and it flies great, it flew right off the building board need no trimming.
I also have his air boat, his Ring Rat (control line!) and his ehopper (a scale ultralight)
All great kits, I love the way they build, like a 3D jigsaw puzzle.
vrex is offline Find More Posts by vrex
Old Jun 21, 2011, 10:36 AM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
I know what you mean vrex...... I was thinking of the ultralight next because I have the perfect place to fly all around me especially park flyers! However; when the breeze turns to 10-20 mph not good for the light wings or light hearted.... like myself!
Still have to get the Swift100 airborne..... 2nd attempt not good.... it's not the plane well it's the both electronics and the RX tray. I didn't realize it but the balsa F27 where I mounted the 6400 split underneath and to the side. Needless to saying the rx moved around and didn't have good control. Probably pushed too hard when mounting it..... plus the battery tray was a bit weak for my grabby velcro. Hopefully, I can get out today or this evening and fly with the nesting swallows!
Old Jun 21, 2011, 10:35 PM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Something must be wrong with the AR6400 or one of the AS2000. I have a side yard with a large hill of wild flowers where I can land safely if needed...... So, I hand launched the Swift, but immediately got away from me right after launch, when nice... then it turned right, wings started to "rock" back and forth then just turned sharp and couldn't avoid the house. Nose hit and slightly bent the motor shaft...... glad I didn't go down to the park, otherwise I would have watched it float in the pond..... More to follow I suppose......
Old Jul 04, 2011, 06:30 PM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Whoo Whoo
Finally got to fly the Swift100 with a successful maiden...... followed by 2 more flights! I'll get video on the next few.
I found the previous problem was no "full" elevator because the control wire (shrink wrap) was loose at the tail and I plugged the ailerons into the other plug on the AR6400.
Oh and the new motor fixed the bent shaft...
Love how it just glides in for a landing with cut throttle. Yes, another keeper for sure.
Thanks again SA
Old Jul 11, 2011, 11:27 AM
Truss-Loc Monkey
Joined Feb 2002
Wow, how'd I miss the progress on this one. That trim scheme is SHARP! nice work on the Swift, and I'm glad you got things worked out for the maiden. Definitely one of my favorite UM models.
-Bill
Old Jul 11, 2011, 12:35 PM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Originally Posted by Stevens AeroModel View Post
Wow, how'd I miss the progress on this one. That trim scheme is SHARP! nice work on the Swift, and I'm glad you got things worked out for the maiden. Definitely one of my favorite UM models. -Bill
Thanks again Bill... Have to tweak the D/R a bit as it's still really touchy.
I have to review my videos to see if the Swift100 flights came out. Seems like my Zi6 was set to VGA and not HD. Besides I want to put the keychain cam on board. Either way I'll post some video soon.
Old Jul 15, 2011, 03:29 PM
DropTank is offline
Find More Posts by DropTank
Is it Friday yet?
DropTank's Avatar
United States, NC, Raleigh
Joined Jun 2008
Your Swift looks really nice! What kind of covering did you use? Looking forward to the flight video.
DropTank is offline Find More Posts by DropTank
Old Jul 15, 2011, 05:14 PM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
I used AeroLite available from Stevens AeroModel and their AeroTrim. On the Swift the checker pattern was created using my injet Clear Glossy Vinyl from papilio.
Old Jul 16, 2011, 04:12 PM
DropTank is offline
Is it Friday yet?
DropTank's Avatar
Joined Jun 2008
Thanks for your reply. I am considering building one. Maybe a little later in the year.
Old Jul 17, 2011, 12:39 AM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Swift100 Flight video
Although I've had many successful flights, this was a maiden flight with a keychain cam on the wing, then move to center well, then to my hat....
Video is a little over 7 minutes and should give you an idea of the fun you can have with it. Got side tracked with the video and forgot to test the D/R .....
Swift100_Final_x264.mp4 (7 min 1 sec)
Last edited by simages; Jul 17, 2011 at 08:46 AM. Reason: anal retentive correction and YT upload failures....
Old Jul 17, 2011, 11:20 AM
DropTank is offline
Is it Friday yet?
DropTank's Avatar
Joined Jun 2008
Looks like a good flier! It's faster and more aerobatic than I thought it would be.
Old Jul 17, 2011, 11:25 AM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
For sure, I haven't hit the D/R yet, but hope to get out this evening to see the difference or it could just be my over controlling......
Old Jul 18, 2011, 10:13 AM
Joined Feb 2000
It appears to be "swift," indeed. Might be a handful flown indoors.
Jim R.
Old Jul 18, 2011, 11:03 AM
simages is offline
AMA# SIMAGES
simages's Avatar
Joined Dec 2006
Originally Posted by JRuggiero View Post
It appears to be "swift," indeed. Might be a handful flown indoors. Jim R.
You could make it float..... indoors....
Just added my Specsheet, better late than never.....
Build Log Stevens AeroModel - SkyBoy (600) simages Sport Planes 149 Dec 03, 2015 09:00 PM
Build Log Stevens AeroModels - SkyBuggy (100) simages Electric Plane Talk 33 Aug 16, 2013 09:56 AM
Discussion Stevens Aeromodel 1918 Hergt james1787 Scratchbuilt Indoor and Micro Models 58 May 21, 2012 08:02 AM
Sold Swift 16 $100 Shipped CONUS chrisab Aircraft - Electric - Helis (FS/W) 1 Mar 17, 2011 08:47 PM
Sold *BEAUTIFUL* Stevens Aeromodel ~RV-4~ 100% RTF...$140 SHIPPED2U! bighank13 Aircraft - Electric - Airplanes (FS/W) 3 Feb 09, 2009 06:09 AM
