Old Apr 22, 2011, 08:19 PM
suarez is offline
Find More Posts by suarez
Wingfan
South Germany
Joined Jul 2006
Idea
Adressable RGB Led Strip useful in Arduino MWC Code?
hi,
i found this:
http://www.bliptronics.com/item.aspx?ItemID=83 Seller
http://cgi.ebay.de/ws/eBayISAPI.dll?...m=250796104515 Seller
http://led-headband.googlecode.com/files/nps6B3.pdf Datasheet
Then i saw there is support for arduino code:
http://code.google.com/p/ledstrip/
https://github.com/search?q=hl1606&t...&start_value=1
https://github.com/adafruit/HL1606-LED-Strip-PWM
http://what2day.posterous.com/last-s...before-the-bur
But i use the arduino pro mini and there are not enough Pins left.
then i thought to use a second pro mini to control the led stripe.
It would be nice to generate some state signals from the mwc to the other board, to generate useful patterns ore other funny things.
I hope my idea is good enough for a arduino pro to look at.
At last maybe the best sites about using it with arduino:
http://www.ladyada.net/products/digi...rip/index.html
http://bleaklow.com/2010/05/27/how_t...lly_works.html Warning about error in the datashit.
What do you think?
gruss
roland
suarez is offline Find More Posts by suarez
Discussion Arduino Code to read PPM timings Nase DIY Electronics 20 Oct 28, 2014 03:07 PM
Discussion Arduino code for BMP085 pressure sensor? 13brv3 DIY Electronics 23 Oct 24, 2011 11:07 AM
Discussion Anybody used the these ebay LED strip lights in post #5 tymbrewolf Night Flying 12 Apr 21, 2010 03:22 PM
Discussion How to Control a 2 Terminal RGB LED lazy-b DIY Electronics 8 Sep 01, 2006 12:15 AM
