Old Apr 22, 2011, 01:41 PM
Joined Apr 2011
Hacker A50 12S + CC ICE lite 100 + 5S lipo
knocking throughout the entire throttle range terribly.
How to solve it ?
kkhlam is offline Find More Posts by kkhlam
Old Apr 22, 2011, 03:38 PM
A man with too many toys
United States
Joined Feb 2001
How to solve it ?
PWM = 8
Timing = low
If that does not fix it you might try turning off data logger – sometimes that helps.
RC Man is offline Find More Posts by RC Man
Old Apr 22, 2011, 08:12 PM
Joined Apr 2011
thanks for response.
it still doesn't work.....all items are brand new and there is a error signal referring that it is motor locked/jammed.
There is nothing wrong with the brand new motor apparently, I can rotate it freely by hand.
I tried to remove the prop/spinner but it is still the same
Old Apr 22, 2011, 11:02 PM
Joined Apr 2011
it is highly suspected that the brand new motor is defective as i cross check with other ESC and motor which shows that the CC ESC workswith another motor (in small size comparatively) but the motor keeps knocking with other ESC
Old Apr 23, 2011, 04:57 AM
United States
Joined Feb 2001
Try a smaller prop. Unloading the motor sometimes helps. If that does not work you should call tech support on Monday. Sometimes other firmware versions work better with some problem motors and the guys at tech support should be able to help you determine if it’s a motor problem or just an ESC setting.
For Sale Hacker A50-12S $80 shipped BIG LACY Aircraft - Electric - Power Systems (FS/W) 0 Apr 18, 2011 01:18 PM
Sold Hacker A50-12L & CC ICE 100 - $250.00 shipped fltekdiver Aircraft - Electric - Power Systems (FS/W) 1 Apr 16, 2011 05:25 PM
Sold Hacker A50-12S gliders Aircraft - Electric - Power Systems (FS/W) 4 Apr 02, 2011 01:47 PM
Discussion Phoenix Ice Lite 100 with Hacker A40-14s sfluck Power Systems 1 Apr 01, 2011 01:07 PM
Wanted Hacker A50-12S & CC ICE 100A Jon Craig Aircraft - Electric - Power Systems (FS/W) 0 Sep 22, 2010 05:37 PM
