Old Apr 22, 2011, 10:27 AM
ExPat
Aero Andy's Avatar
Spain, Murcia, Mazarrón
Joined Apr 2010
Spitfire......EPP full fuse 20"ws.....**VIDEO ADDED**
I've started building this Spitfire to take a 18-11 10g motor. It will be Cox warbird size, but I want it to be able to take a few knocks so I'm using 6mm EPP, the terrain is pretty rugged here, so there's no nice green fields to land in. I decided on full fuse because I want to be able to hide all the gear away inside the fuselage, I think it looks cleaner that way.
Anyway, here's a few photos so far.
Andy
EPP Spitfire (3 min 0 sec)
Aero Andy is offline Find More Posts by Aero Andy
Old Apr 23, 2011, 01:16 PM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Quick update.
Firewall and 10g motor fitted, along with tail section.
Andy
Old Apr 23, 2011, 05:22 PM
Joined Nov 2010
Andy
Your spitfire looks good. Keep us posted with progress pictures.
bluecrane is offline Find More Posts by bluecrane
Old Apr 23, 2011, 06:57 PM
Rhys - Forever Learning
Rhondda. South Wales, UK
Joined Feb 2007
Looking good so far
How did you make the fuz?
rhysduk is offline Find More Posts by rhysduk
Old Apr 24, 2011, 12:26 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Originally Posted by rhysduk View Post
Looking good so far
To make the fuse I made two elongated "tear drop" shaped tubes, one larger and one smaller. By rolling the EPP at the top and pinching together the bottom with hot glue, you end up with a tear drop shape. I then added a 35mm wide flat strip of EPP along the fuse length with a BBQ skewer glued to it, this rounded the top section more and made the whole thing rigid. The cockpit is polystyrene stuck on top of the smaller tube and sanded to shape.
Regards
Andy.
Old Apr 24, 2011, 04:48 AM
Joined Feb 2007
Excellent idea thats both quick (i assume) and cheap! very nice.. Do you have any other photo's of the fuselage build?
Are you building this from an existing Spit or do you have plans? Noticed you mentioned it Cox size though.
PS: Where in Spain are you? From the videos it looks like Gran Alacant but its all the same out there
Old Apr 24, 2011, 08:00 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Hi Rhys
Sorry I forgot to take pictures at the very start, but I'll be doing a P-40 after this one, so I'll do a proper build log. I already have a few Gravity Cox warbirds, so getting the size right was easy, no plans though, just doing it by eye from a photo I printed out. I'll put together some plans for the next one though.
Hopefully maiden it tomorrow before I spray it, I'll let you know how it flies.
I'm in Mazarron, Murcia. Just 70km south of Alicante, so you were spot on with Gran Alicant, good guess.
All the best
Andy
Old Apr 24, 2011, 11:26 AM
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Awesome work as usual Andy. Looks great.
Eagle34 is offline Find More Posts by Eagle34
Latest blog entry: Landing by Ben Fisher
Old Apr 24, 2011, 12:33 PM
Lawn dart pilot/builder
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
very slick ... i love those wee 10g motors .
great way to do a fuze .
Prime_8 is offline Find More Posts by Prime_8
Old Apr 24, 2011, 05:18 PM
Crashing but learning...
Wildweasel09's Avatar
Brazil, São Paulo, Sao Paulo
Joined May 2009
Very good Andy!
Subscribed.
Wildweasel09 is offline Find More Posts by Wildweasel09
Old Apr 26, 2011, 12:50 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Thanks Guys, glad you like the idea of the rolled fuze.
Ok, well I've maidened it, and it flew all right, but not great. So I've made some changes, and now it flies perfectly. Here's what I altered.
Changed the kf airfoil for a simple under camber wing.
Cut along under the length of the fuze and widened the underneath by 12mm, this gave the wing more stability and I was able to push the gear farther forward to get the CG right.
Added more surface area to the elevator to gain better authority.
Now it flies as it should, I'll get a video sorted over the next day or two. In the mean time I've sprayed it up and I'll post some pictures later.
As a prototype I'm really pleased with it, but I'll be doing another build incorporating these alterations from the start.
Andy
Old Apr 28, 2011, 12:10 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Here's the finished Spitfire, all painted up.
Andy
Old Apr 28, 2011, 12:42 AM
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
looks good man.
Old Apr 28, 2011, 03:10 AM
Joined Feb 2007
Looking very nice Andy
Just noticed the belly of the bird, surely you're going to be putting skids or wheels on it? That aileron servo will get ruined other wise
Old Apr 28, 2011, 08:18 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Hi Rhys
That's a good point, I think I'll quickly glue a couple of under wing scoops on this one, as it was just a trial build. The next Spitfire will be a proper build from plans I'll sketch up, and post, and I'll be adding landing gear on that one.
Cheers
Andy
Question P40b short or full kit approx 50" wingspan? trumps Scale Electric Planes 0 Mar 14, 2011 06:19 AM
Discussion Looking for ~16-20" Wingspan Epp Kit outngo Foamies (Kits) 3 Sep 27, 2009 08:41 PM
Discussion 13 inch wingspan full fuse Shinden canard pusher jingjingjing Indoor and Micro Models 12 Nov 29, 2008 01:10 PM
Discussion i cant find a full fuse p-51 or spitfire justwanttofly Foamies (Scratchbuilt) 3 Sep 10, 2008 04:48 AM
Discussion 5.5 inch wingspan full fuse plane my first attempt/build log 3dFlyer88 Indoor and Micro Models 1 Sep 08, 2007 03:21 PM
