Old Apr 22, 2011, 09:12 AM
Shuedog is offline
Find More Posts by Shuedog
It's just a new plane honey!!!
Shuedog's Avatar
Joined Oct 2008
HobbyPartz Customer service
Received a new Gen Ace 6s 5300 lipo. 1st balance charge cell # 5 3.88. Any luck with returns to thie company? Sent e-mail called was on hold for 30 minutes. Had great luck with the Gen Ace lipos. Just checking it any one has any experence with returns.
RS
Shuedog is offline Find More Posts by Shuedog
Old Apr 22, 2011, 09:43 AM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
They have customer service?
I give them a lot of buisness but if you have questions or a problem they are very difficult to get a hold of. I don't agree with this way of doing buisness but they suggest making a post over on the vendor pages for HobbyPartz and they are quicker to respond.
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Apr 22, 2011, 11:29 AM
Fast Guy is offline
Find More Posts by Fast Guy
Canada, ON, Thunder Bay District
Joined Apr 2007
I have contacted them by email several times and they responded with in the hour. Forget about the telephone though. I have 10 Gens Ace batteries and just ordered another 9. Very pleased with them. Bought Hyperion before this.
Fast Guy is offline Find More Posts by Fast Guy
Old Apr 22, 2011, 02:43 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
What was the voltages of all of the cells before charging it?
Really the first thing to do when one receives a new LiPoly is to checj each cell's voltage. If any cell is below 3.7 then the vendor should be contacted unless it is HK as they say that this voltage is fine.
Charles
Old Apr 22, 2011, 03:16 PM
Shuedog is offline
Shuedog's Avatar
Joined Oct 2008
Charles
g
Charles,
I did not check before the 1st balance charge. The problem I have is my charger keeps running trying to bring up the 5th cell to 4.20. I tried to discharge, re charge. No luck. Thanks for your help and reply.
Old Apr 22, 2011, 03:17 PM
Shuedog is offline
Shuedog's Avatar
Joined Oct 2008
[QUOTE=Fast Guy;18038560]I have contacted them by email several times and they responded with in the hour. Forget about the telephone though. I have 10 Gens Ace batteries and just ordered another 9. Very pleased with them. Bought Hyperion before this.[/QUOTE
I have some other gen ace packs they have been geat. This was my 1st 6 cell. I will contact them my email.
Old Apr 22, 2011, 03:21 PM
hpiguy is offline
Find More Posts by hpiguy
If it's R/C, it's all good.
hpiguy's Avatar
USA, WI, Wausau
Joined Jul 2005
They have a forum on here in the vendors section.
I was shipped two defective ESCs recently. I tried to call and was on hold for half an hour, then got disconnected. I started a thread in the vendor section they have here and they replaced them both at no cost to me within a week.
I'd call that excellent service.
hpiguy is offline Find More Posts by hpiguy
Old Apr 22, 2011, 03:26 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
My SOP after receipt of a new lipoly...
Task #1 - Check voltages of each cell within pack.
Task #2 - Check internal resistance of each cell within pack.
Task #3 - If all is good with #1 and #2, charge at 1C, perform 1C discharge to check usable capacity.
Task #4 - If capacity checks out ok, change to my preferred connector, charge, perform break-in cycles, use pack.
If any disagreeable variance in #1, #2, or #3 is noted, vendor gets contacted the day I receive the pack. I never perform any pack mods (connector swap, etc.) until I know the pack will perform as expected. This makes it MUCH easier to return.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Apr 22, 2011, 03:28 PM
So. Cal.
Have you attempted to charge the low cell via the balance tap as a 1S? IMO, this is by far the easiest, safest, and most efficient way to bring a low cell up. Discharging when one cell is significantly lower than the others can irreparably damage the pack. Don't do this.
Mark
Old Apr 22, 2011, 03:33 PM
planebldr is offline
Find More Posts by planebldr
planebldr's Avatar
Brillion,WI 54110
Joined Jul 2009
I had to return a Blue lipo once because it was leaking and had a puffed cell. I just used their live online chat and was given a RMA# right away and was pretty easy. http://www.hobbypartz.com/forum.html A little way down on the LH side "live help"
planebldr is offline Find More Posts by planebldr
hpiguy is offline
hpiguy's Avatar
USA, WI, Wausau
Joined Jul 2005
Maybe this won't work but can you run the pack on Storage mode on your charger until it draws them all down to 3.80, then balance charge from there?
Old Apr 22, 2011, 03:35 PM
So. Cal.
Most chargers do not balance in storage mode. I would not attempt this as it very well may overdischarge and damage the low cell. It's best to charge the low cell via the balance tap.
Mark
Old Apr 22, 2011, 03:36 PM
planebldr's Avatar
Brillion,WI 54110
Joined Jul 2009
I also made a charge lead that allows me to charge just one cell by itself. Probably not "good" to do...but it has saved a pack in the past.
Old Apr 22, 2011, 03:37 PM
hpiguy is offline
hpiguy's Avatar
USA, WI, Wausau
Joined Jul 2005
Mark
No problem. I didn't know that. My B6 Ultimate will discharge each cell to 3.80 even if they are off from each other.
How else could it store the cells if it doesn't balance during storage? Do some do it by total pack voltage?
Old Apr 22, 2011, 03:46 PM
So. Cal.
All of my chargers simply discharge until the aggregate pack voltage is ~3.85 x number of cells. Balancing during storage discharge is inadvisable as it can then create an imbalance when the pack is subsequently charged (where cell-to-cell balance is critical). This can be dangerous of the cells within the pack are not well-matched with respect to capacity.
Mark
Discussion Nitro Planes Customer Service pooralan Nitro Planes 2 Jan 27, 2014 02:38 PM
Question Hobby Shop Warehouse Customer Service stekeye Vendor Talk 7 Jun 09, 2011 08:55 PM
Discussion HobbyPartz "Customer service" TexasFlyr HobbyPartz.com 0 Feb 25, 2011 12:42 PM
Rant Disappointed with Hobbypartz Customer Service typhoonmaster HobbyPartz.com 10 Jan 28, 2011 11:34 AM
Discussion hobbypartz crappy customer service b-29er Vendor Talk 20 Dec 23, 2010 03:35 PM
