Old Sep 12, 2011, 11:25 PM
ldhflyguy is offline
Find More Posts by ldhflyguy
FlyGuy
ldhflyguy's Avatar
Batavia, IL, USA
Joined Oct 2007
Originally Posted by Tim Marks View Post
Hi:
If you have 1 6000 mAh pack connected, and you want to charge it at 2C, either set the AUTO to 2C, or select a manual charge rate of 12A.
If you have 2 x 6000 mAh packs connected in parallel, and you want to charge at 2C, either set the AUTO to 2C, or select a manual charge rate of 24A. When you connect packs in parallel, you double the capacity.
Does this answer your question?
Tim Marks
Hi Tim,
The above seems to be just what I need to know; however, I'm sure I've tried this and many variations of it and I can't get it to work that way. For instance if I try to parallel charge four 6S5000 mAh batteries with the charger set for 40 amps, I don't get 40 amps. I usually get around 24 - 28 amps. It's like the charger senses the the batteries' ratings and will only go a little over their ratings.
Please help me.
ldhflyguy is offline Find More Posts by ldhflyguy
Old Sep 13, 2011, 12:35 AM
Tim Marks is offline
Find More Posts by Tim Marks
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
Originally Posted by ldhflyguy View Post
Hi Tim,
Please help me.
Hi:
Here are some possibilities:
1) The batteries are not substantially discharged to a level that will allow Constant Current mode.
2) Your power supply is either not providing the power for which it is rated, or it is noisy. If available, connect 2 12v Lead Acid batteries in series and give that a try.
Tim Marks
Tim Marks is offline Find More Posts by Tim Marks
Old Sep 13, 2011, 02:57 PM
FlyGuy
ldhflyguy's Avatar
Batavia, IL, USA
Joined Oct 2007
Hi:
Tim Marks
Hey Tim,
Thanks for being my Hero!
I tried changing a few more settings via my laptop. Basically I tried uping the limits on settings that I thought could be the problem, but nothing seemed to help.
Your first sentence in your item #2 above got me to thinking. I remembered that when I first tested my new system, which includes a Mean Well 1500 W supply, that I had to lower the Supply Low Voltage Limit setting for my PL8 in order to get it to function correctly. TO SOLVE MY CURRENT PROBLEM, I FURTHER LOWERED THE Supply Low Voltage Limit from about 23.4 volts to 22.0 volts AND NOW EVERYTHING SEEMS TO WORK PERFECTLY.
Thanks again Tim. I hope others will benefit from what I've learned.
Old Sep 29, 2012, 08:46 AM
Eddie500 is offline
Find More Posts by Eddie500
Joined Nov 2011
Originally Posted by Howard Matos View Post
Hi,
Customers have already requested a change to how parallel charge rate calculation works. Currently, it divides the set rate by the number of packs in parallel. But customers want it to multiply the preset’s charge rate by the number of packs in parallel. So, we like this idea. We’re going to change it. We hope to release a substantial firmware/CCS revision in 2 weeks or so. I think you will like how the new firmware will operate with regard to parallel charging. Please be patient for a little bit longer.
I was wondering if this change was ever made? Right now it divides the charge rate by the number of packs you have in parallel.
Eddie500 is offline Find More Posts by Eddie500
Old Sep 29, 2012, 09:49 AM
Tim Marks's Avatar
Joined Mar 2008
Hi:
Yes, the change was made. Currently the PL do not divide the set charge rate by the #P entered during start of a charge. They multiply the preset's charge rate by the #P entered. I'm afraid your statement is not correct unless you are running old firmware.
Tim Marks
Old Sep 30, 2012, 10:15 AM
Eddie500 is offline
Joined Nov 2011
Hi:
Tim Marks
I think I know what I did wrong. I choose Generic Accurate charge. I choose this because it was the first option and while I was charging one battery it worked when I needed to charge a single battery at 10 amps.
But when I changed it to 4P, I expected it would charge at 40 amps, after selecting 10amp charge.
I did not think the 10 amp setting in Generic Accurate charge would limit a parallel to 10 amps also. So I assume this is what happened as I am charging on High Power now and it is working properly at 40 amps when I select 10 amps.
Old Sep 30, 2012, 10:47 AM
Tim Marks's Avatar
Joined Mar 2008
Hi:
That makes total sense. Yes, the PL will always limit the calculated parallel rate to the max the preset can output, which in the case of the Accurate Charge preset is 10A. Your solution is the correct one. Parallel Charging is one of the main reasons we have the High Power preset.
Tim Marks
Discussion Parallel Charging Boards alphega Batteries and Chargers 2 Apr 27, 2011 04:14 PM
Discussion PowerLab 8 V2 - Safety Code 52 martinwinlow FMA Direct 3 Apr 24, 2011 03:39 AM
Discussion Chargers and parallel charging billbolz Batteries and Chargers 5 Apr 07, 2011 08:11 AM
Sold New ParaBoard-XH 30A parallel charging with T-plug stretch1100 Aircraft - Electric - Batteries & Chargers (FS/W) 3 Mar 22, 2011 11:29 AM
Question Parallel Charging and Voltage Difference? Brill 1 Batteries and Chargers 11 Mar 12, 2011 12:38 PM
