Old Apr 26, 2011, 03:56 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
Originally Posted by KAW_Concours View Post
I don't see why I should even set it to 4P. Might just as well leave it as 1P I guess.
When you set it to 4p, the mah display during the charge is divided by 4.
Gregor99 is offline Find More Posts by Gregor99
Old Apr 27, 2011, 09:14 AM
KAW_Concours is offline
Find More Posts by KAW_Concours
Joined Mar 2009
I would like to know what their logic is in setting it up this way. I have a preset for each lipo. So my 4S3250 I want to charge at 3C. The preset is set to 10 amp. Then I might be charging anywhere from 1 to 4 batteries. I tell it 4P and it brings the amps down to 2.5 amps. Then I have to bring it back to 10 amps per battery.
I do love the charger. I even bought a second one.
In the last 3 months I have tested about 15 PB batteries using the regen discharge.
KAW_Concours is offline Find More Posts by KAW_Concours
Old Apr 27, 2011, 11:56 AM
Tim Marks is offline
Find More Posts by Tim Marks
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
Hi:
As I mentioned, my preference is to set charge current at the PL8 directly when charging parallel. It takes 10 seconds. When you set the current during the Start Charge questions, it saves it down to the preset automatically. Admittedly, it is not as easy to do using the CCS because you can not alter the preset on the Start Charge screen there.
Tim Marks
Tim Marks is offline Find More Posts by Tim Marks
Old Apr 28, 2011, 06:20 AM
Joined Mar 2009
I agree it is easy. I did not even notice it was dividing the amps for 4 months. I don't use it much for Lipo's in the winter though.
I just think this could be better.
I don't know of anything that is 100% perfect.
Old Apr 30, 2011, 09:42 PM
SunDevilPilot is offline
Find More Posts by SunDevilPilot
SunDevilPilot's Avatar
United States, AZ, Gilbert
Joined Jun 2008
I just got my PowerLab 8 and am in the process of setting up the presets. At first I was a little confused by the division of the charge rates.
If I have the charger set to charge one 5000 mAh battery at 5 amps then I get a 1C charge. However, if I am paralleling two 5000 mAh batteries do I need to up the charge rate to 10 amps to maintain a 5 amp charge per pack?
As a small workaround I made several sets of presets. One preset is setup for a one pack charge and another is set to a two pack charge, one 5 amps and the other 10 amps (Assuming I am charging the 5000 mAh packs at 1C).
Thanks for any info.
SunDevilPilot
SunDevilPilot is offline Find More Posts by SunDevilPilot
Old Apr 30, 2011, 10:45 PM
BVH is offline
BVH
Find More Posts by BVH
BVH
BVH's Avatar
United States, CA, Pismo Beach
Joined Dec 2006
SunDevilPilot
Simple answer - Yes. The preset charge rate that you set is divided by the number of packs.
BVH is offline Find More Posts by BVH
Old May 01, 2011, 11:52 AM
Joined Jun 2008
Thanks, Just needed to be sure.
SunDevilPilot
Old Jul 28, 2011, 01:40 PM
lipper2000 is offline
Find More Posts by lipper2000
Joined May 2011
This still is not clear to me...I think an example in the manual would clear it up(one for now as well please)...
If I am using "generic faster lipo charge" with 2 batteries...do I change the preset to 2C if I have two batteries in parallel?
My packs are 6000mah...
lipper2000 is offline Find More Posts by lipper2000
Old Jul 28, 2011, 04:54 PM
Tim Marks's Avatar
Joined Mar 2008
Hi:
If you have 1 6000 mAh pack connected, and you want to charge it at 2C, either set the AUTO to 2C, or select a manual charge rate of 12A.
If you have 2 x 6000 mAh packs connected in parallel, and you want to charge at 2C, either set the AUTO to 2C, or select a manual charge rate of 24A. When you connect packs in parallel, you double the capacity.
Does this answer your question?
Tim Marks
Old Jul 29, 2011, 11:08 PM
Joined May 2011
Yes...that is what I have been doing and am glad it's right.
What is the point to using the "C"...does it calculate the current automatically?
Old Jul 30, 2011, 12:01 AM
Tim Marks's Avatar
Joined Mar 2008
Hi:
For information about AUTO charge, please check page 61 of the user guide:
http://revolectrix.fmadirect.com/sup.../item_1369.pdf
Tim Marks
Old Aug 03, 2011, 05:21 AM
2bob is offline
Find More Posts by 2bob
Joined Feb 2011
I'm used to setting the total charge rate for parallel charging having come from an icharger but the logic behind the number of packs setting seems strange.
If the pl8 divides the mah for display during charging (i.e. a per pack rate) then surely it should multiply the set charge rate as well otherwise it just leads to confusion?
2bob is offline Find More Posts by 2bob
Old Aug 03, 2011, 11:47 AM
Howard Matos is offline
Find More Posts by Howard Matos
AR-15 BRD!
Howard Matos's Avatar
Frederick, MD
Joined May 2002
Hi,
Customers have already requested a change to how parallel charge rate calculation works. Currently, it divides the set rate by the number of packs in parallel. But customers want it to multiply the preset’s charge rate by the number of packs in parallel. So, we like this idea. We’re going to change it. We hope to release a substantial firmware/CCS revision in 2 weeks or so. I think you will like how the new firmware will operate with regard to parallel charging. Please be patient for a little bit longer.
Howard Matos is offline Find More Posts by Howard Matos
Old Aug 03, 2011, 01:14 PM
2bob is offline
Joined Feb 2011
Originally Posted by Howard Matos View Post
Hi,
That's great news.
This is one of the main reasons why i've just bought a pl8 - there does seems to be a willingness to take suggestions from users on board and make changes where appropriate.
How about this one. I'll be using at least 6 parallel balance boards at once, how about making them interlock physically in order to bring some order to my charging station?
Old Aug 04, 2011, 09:42 AM
AR-15 BRD!
Frederick, MD
Joined May 2002
That's great news.
Hi,
That might be kind of tough from where we are now, but I have seen photos from customers who made up their own charging boards and mounted the Safe Parallel Adapters to it. Pretty slick too!
Discussion Parallel Charging Boards alphega Batteries and Chargers 2 Apr 27, 2011 04:14 PM
Discussion PowerLab 8 V2 - Safety Code 52 martinwinlow FMA Direct 3 Apr 24, 2011 03:39 AM
Discussion Chargers and parallel charging billbolz Batteries and Chargers 5 Apr 07, 2011 08:11 AM
Sold New ParaBoard-XH 30A parallel charging with T-plug stretch1100 Aircraft - Electric - Batteries & Chargers (FS/W) 3 Mar 22, 2011 11:29 AM
Question Parallel Charging and Voltage Difference? Brill 1 Batteries and Chargers 11 Mar 12, 2011 12:38 PM
