Old Apr 22, 2011, 07:23 AM
kahn10 is offline
Find More Posts by kahn10
Joined Nov 2006
converting a coax esc/reciever to a single rotor
hey .. i was wondering if anyone had any ideas on converting a nine eagles reciever/esc to a single rotor set up.basically i was hoping i could block the gyro feed to the main rotor as the gyro uses both motors
kahn10 is offline Find More Posts by kahn10
Old Apr 24, 2011, 01:59 AM
mjsas is offline
Find More Posts by mjsas
Joined Nov 2007
I assume you are talking about something like a 4 in 1 unit with a receiver, gyro, mixer and two motor outputs. Circuit wise they are very close to the units used on something like an Esky FP helicopter with a main motor and tail motor. I have noticed that there are a large number of 3 in 1 units for the E-Flite Blade CX2 for sale on Ebay. (E-FLITE EFLH1023 Control Unit Mixer/ESCs/Gyro CX2) These look just like the 3 in 1 I have on a FP helicopter (gyro, mixer and ESC - no receiver). I have wondered if they are identical units.
There is no reason the circuits could not be the same but with different microcode. Also there is no reason that the gyro needs to control both motors on a co-axial, controlling one motor would be enough. In that case the same 4 in 1 would work on either a co-axial or FP.
I suggest that you test your 4 in 1 to verify that the gyro controls one or both motors. If it only controls one motor, then no modifications would be needed to use it on a FP helicopter.
If the gyro controls both motors you need the servo signal for the main motor which could be used as an input to an external ESC for the main motor. If only the PPM signal is available, then it gets harder.
Also the output from the Nine Eagle ESC's would have to be big enough to power the motors on the FP helicopter. Otherwise a booster circuit would be needed.
mjsas is offline Find More Posts by mjsas
Old Apr 26, 2011, 06:21 AM
kahn10 is offline
Joined Nov 2006
gyro definitely affects both motors....sooooooo..............can i sidetrack the channel three signal before it gets to the gyro and feed it to another esc then use that to power the main rotor,leaving the 4in1 to run the tail and servo's? i realize a photo would be extremely helpfull
Discussion Double Horse 9104 Helicopter 3 channel Single Rotor Copter killbucket Beginner Training Area (Heli-Electric) 1127 Apr 29, 2014 02:18 AM
Discussion Recommendations for a single rotor beginner Microbaba Beginner Training Area (Heli-Electric) 156 May 03, 2011 01:06 PM
Discussion 26" Double Horse 9104 Helicopter 3 channel Single Rotor RC Helicopter Red n Blue thercguy Electric Heli Talk 3 Apr 21, 2011 11:26 PM
Discussion Help with single rotor newbie flying. Microbaba Beginner Training Area (Aircraft-Electric) 1 Apr 01, 2011 10:29 AM
Coax heli to single rotor heli success? wab25 Coaxial Helicopters 7 Dec 24, 2005 12:27 AM
