Old Apr 21, 2011, 07:38 PM
wsmorton is offline
Find More Posts by wsmorton
United States, AZ, Prescott
Joined Aug 2006
FrSky Module Hack
Hi!
Just finished hacking my RD 6000 Super with the FrSky V8HT 2.4 Ghz Module. After some research on RCGroups and other places I decided to use a switch for the power to the module since I could not find any information to power off the RF section without taking out the crystal or going through the trainer port. I didn't want to use the trainer port so I decided to just take out the crystal each time I want to use the 2.4.
I don't have any extra FrSky receivers to do a range check. I have some on order and will use them with the new setup. I plan on using the 2.4 system mostly for DLG since the transmitter is nice and light with a LiFe battery and does most of want I want for mixing.
I'll let the pics take it from here.
Scotty
wsmorton is offline Find More Posts by wsmorton
Old Apr 21, 2011, 07:58 PM
Freakflyin is offline
Find More Posts by Freakflyin
Freakflyin's Avatar
USA, ME, Plymouth
Joined Aug 2006
Nice clean install Scotty! I really like the FrSky product too.
Freakflyin is offline Find More Posts by Freakflyin
Old May 22, 2011, 11:55 AM
lsippell is offline
Find More Posts by lsippell
central Arkansas
Joined Feb 2004
Problem with my installation
I just installed the DIYmoudleV8HT in my RD6000 following your pictures with the only change being that I put a servo connector in the wires going to the transmitter (gnd, v+ and PPM signal).
I have a problem. Though I can bind the transmitter and the receiver (V8R7) with no problem, it's that no other signal gets to the receiver, there is no servo movement unless I remove the RD6000's antenna.
Do you have to remove the RD6000 antenna to get yours to work? I'm kind of concerned that running it like this will overload then 72mhz transmitter and burn it out.
Louis
lsippell is offline Find More Posts by lsippell
Old May 22, 2011, 12:05 PM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
If the 72MHz part still powered?
Shouldn't... at least to save battery, is not other isues, as you described.
renatoa is online now Find More Posts by renatoa
Old May 22, 2011, 12:17 PM
skyzking is offline
Find More Posts by skyzking
smokin electrons...
skyzking's Avatar
Brisbane, Australia
Joined Jan 2007
nice setup...how did you figure where to place the signal wire? i have the corona dıy module and ım not sure where to connect the signal wire in my JR X-347?
skyzking is offline Find More Posts by skyzking
Old May 22, 2011, 12:48 PM
lsippell is offline
central Arkansas
Joined Feb 2004
How do you remove power from the 72MHz section?
Louis
Old May 22, 2011, 06:23 PM
7SP is offline
7SP
Find More Posts by 7SP
7SP
- Remove before flight -
7SP's Avatar
United States
Joined Dec 2006
IMHO: I would lose the big toggle switch to change from one to the other. It's not like rates or retracts and your going to need to switch it in mid-flight. Personally I would want the switch recessed and as difficult (nearly imposable) to accidentally change as possible. If you have to open up the unit to removed the crystal then the external switch would only serve to accidentally knock yourself out of the air.
7SP
7SP is offline Find More Posts by 7SP
Old May 23, 2011, 09:57 AM
Joined Sep 2007
Louis
Most radios of this class have clearly divided the mainboard in two blocks (the red line)
Left side is the "brain" that handle sticks, switches, display, and finally produce a single output, the PPM.
Right side is the RF block, that transmit to the antenna the signal.
If you watch along the red line, there are only 3 tracks the cross it.
One is PPM, already identified by you.
One of the other two should be the power for RF block, I drawed green circles where to check.
If the area in yellow elipse is the power switch, then you must check what PCB track comes from that area to the right side, crossing the red line, it's also a hint that it's a power line.
Old May 23, 2011, 01:12 PM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
Another solution. Sell RD6000 and buy RDS8000 2.4 which is not so expensive radio.
In countryside, 72MHz is still used. You will find a buyer.
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Old Jun 25, 2013, 11:39 AM
hlgcory is offline
Find More Posts by hlgcory
United States, CO, Windsor
Joined Apr 2012
Is this conversion still possible? I have an old RD6000 collecting dust and thought this would be a useful way to bring it back to life. I did some searching for the hack module and seems it is discontinued?
hlgcory is offline Find More Posts by hlgcory
Old Jun 25, 2013, 12:27 PM
Joined Sep 2007
The one way is discontinued, the two way still on sale.
http://www.alofthobbies.com/diy-telemetry-module.html
Old Jun 25, 2013, 12:39 PM
hlgcory is offline
Joined Apr 2012
Thanks for the quick reply. So this is a total noob question but what is the difference in the one and two way? The addition of telemetry?
Old Jun 25, 2013, 05:44 PM
gzkpez is offline
Find More Posts by gzkpez
Joined Jan 2006
Yes
gzkpez is offline Find More Posts by gzkpez
Discussion New FrSKY 2.4 Hack module in Airtronics Vision 8SP TexasThermalKing Radios 37 Mar 28, 2013 12:12 AM
Build Log Adding FRSKY diy hack module to my worn out dx7 Jabird Radios 4 Aug 14, 2011 02:27 PM
Discussion FrSky Telemetry module hack into 7CAP Mybrains Radios 26 Apr 07, 2011 10:01 PM
Discussion FrSky hack module - what cheapo Tx ? rotagen Radios 12 Nov 15, 2010 10:21 AM
Sold Tracker III and FrSky 2.4GHz Hack Module $100 shipped ek123 Aircraft - General - Radio Equipment (FS/W) 0 Sep 17, 2010 11:35 AM
