This thread is privately moderated by obuggy, who may elect to delete unwanted replies.
Old Oct 12, 2011, 02:44 PM
r0beert0 is offline
Find More Posts by r0beert0
<<x USMC
r0beert0's Avatar
United States, CA, Fontana
Joined Jun 2010
Time is running out,
valid until October 21, 2011!!
Master Airscrew propeller 9x5
This prop is hard to find in this size at local HS.
http://www.hobbyking.com/buddy.asp?c...F-7970197A8942
6" Servo Lead Extension (JR) 26AWG medium gauge wire
Great price for the number or extensions... you get 10pcs
http://www.hobbyking.com/buddy.asp?c...B-1253133EF601
r0beert0 is offline Find More Posts by r0beert0
Old Oct 13, 2011, 04:19 AM
Achsenknecht is offline
Find More Posts by Achsenknecht
Hitec HS-65 / Hex Screwdriver
Find my codes here: http://hk.rc-international.info/swarm/achsenknecht (valid until October 25, 2011)
Achsenknecht is offline Find More Posts by Achsenknecht
Old Oct 13, 2011, 06:55 AM
Vasques is offline
Find More Posts by Vasques
Brasil, BA, Lauro de Freitas
Joined Jul 2010
Extra BuddyCodes, you can save 29.29% for all of this items with http://rc-buddy.com/user/manjator
Glass Fiber Cloth 450x1000mm 18g/m2 (Super Thin)
Savings: 29.29 % / $0.29
PriceAfter: $0.70
Weight: 19 g
Vasques is offline Find More Posts by Vasques
Old Oct 13, 2011, 07:24 AM
13spyderz13 is offline
Find More Posts by 13spyderz13
Joined Oct 2011
Self-Tapping Screws 2x6 (bag of 100pc) = $1.21
http://www.hobbyking.com/buddy.asp?c...C-B0ED2D37D733
Linkage Stopper D1.8mm (10pcs) = $0.96
http://www.hobbyking.com/buddy.asp?c...E-B47B6D5B79CC
Valid until OCT 26th
13spyderz13 is offline Find More Posts by 13spyderz13
Old Oct 13, 2011, 11:17 AM
AlexGold is offline
Find More Posts by AlexGold
AlexGold's Avatar
Russian Federation, Voronezhskaya oblast, Voronezh
Joined Mar 2011
Valid untill October 27
Turnigy nano-tech 850mah 3S 25~40C Lipo Pack
[S]$9.04[/S] $6.53* (28%, -$2.51)
XR Type B Beechwood 3D/SF Propeller 13x4
[S]$4.78[/S] $3.64* (24%, -$1.14)
D05010MG 5.7g / .61kg / .07sec Digital Metal Gear Micro Servo
[S]$7.70[/S] $6.71* (13%, -$0.99)
Mini Ultra-light Horns 23x14x6mm (4pcs/set)
[S]$0.97[/S] $0.65* (33%, -$0.32)
Turnigy Ultra-light wood propeller 12x6
[S]$2.74[/S] $2.39* (13%, -$0.35)
Turnigy Ultra-light wood propeller 11x6
[S]$2.23[/S] $1.93* (13%, -$0.3)
Turnigy Type A Beech wood 12x4 propeller
[S]$2.44[/S] $1.78* (27%, -$0.66)
Turnigy Type C Light Wood propeller 12x6
[S]$2.84[/S] $2.17* (24%, -$0.67)
XR Type B Beechwood 3D/SF Propeller 12x6
[S]$3.60[/S] $2.74* (24%, -$0.86)
Carbon Fiber Tube (hollow) 10x750mm
[S]$3.95[/S] $2.68* (32%, -$1.27)
Turnigy AE-20A Brushless ESC
[S]$8.99[/S] $8.10* (10%, -$0.89)
2mm Gold Connectors 10 pairs (20pc)
[S]$1.98[/S] $1.32* (33%, -$0.66)
Turnigy Transmitter Glove (2.4Ghz/Neckstrap Ready)
[S]$12.99[/S] $9.84* (24%, -$3.15)
Glass Fiber Cloth 450x1000mm 48g/m2 (Ultra Thin)
[S]$0.89[/S] $0.70* (21%, -$0.19)
AC Hinge L20*W15*H0.3 (10pcs)
[S]$0.61[/S] $0.46* (25%, -$0.15)
Strong Rare-earth Magnets (10pcs/set)
[S]$4.02[/S] $2.46* (39%, -$1.56)
TURNIGY Transmitter Strap
[S]$0.99[/S] $0.73* (26%, -$0.26)
Hobby King 401B AVCS Digital Head Lock Gyro
[S]$11.99[/S] $11.34* (5%, -$0.65)
Turnigy Typhoon 450H 2218H Heli Motor 3450kv (450 class)
[S]$16.79[/S] $14.62* (13%, -$2.17)
Pinion Gear 3.17mm/0.5M 12T (1pc)
Curved ball link pliers 5mm
[S]$6.49[/S] $5.97* (8%, -$0.52)
Turnigy MG90S Metal Gear Servo 1.8kg / 13.4g / 0.10sec
[S]$4.99[/S] $4.51* (10%, -$0.48)
Main Rotor Blade Assembly Tool (5mm)
[S]$2.99[/S] $2.22* (26%, -$0.77)
D922MG Digital Metal Gear Servo 1.8kg/ 12g/ 0.07sec
[S]$9.99[/S] $9.02* (10%, -$0.97)
HobbyKing HK-190 2.4ghz 4Ch Fixed Pitch Helicopter (RTF-Mode 1)
[S]$39.95[/S] $32.45* (19%, -$7.5)
2.4Ghz Micro Coax Helicopter 4 Channel (RTF - Mode 1)
[S]$32.95[/S] $30.98* (6%, -$1.97)
AlexGold is offline Find More Posts by AlexGold
Old Oct 13, 2011, 01:12 PM
Firatp is offline
Find More Posts by Firatp
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
Hi,
If someone wants to buy an EXTRA 260 EP can use the budyy code below
http://www.hobbyking.com/hobbyking/s...idproduct=7726
http://www.hobbyking.com/buddy.asp?c...E-3681562109E8
Firatp is offline Find More Posts by Firatp
Old Oct 13, 2011, 01:26 PM
queadlunnrau is offline
Find More Posts by queadlunnrau
Luck is my skill
queadlunnrau's Avatar
United States, WA, Seattle
Joined Jun 2009
Some Buddy Codes
Rhino 360mAh 3S 11.1v 20C Lipoly Pack
Turnigy AA LSD 2200mah Low Self Discharge
queadlunnrau is offline Find More Posts by queadlunnrau
Old Oct 13, 2011, 06:57 PM
ShaneH is offline
Find More Posts by ShaneH
Australia, NSW, Central Coast
Joined Aug 2011
NTM Prop Drive Series 35-36A 1400Kv / 550W
http://www.hobbyking.com/buddy.asp?c...9-115ACF5813D6
NTM Prop Drive 35 Series Accessory Pack
http://www.hobbyking.com/buddy.asp?c...F-47161C9BA446
10X6 Propellers (5Pcs/Bag)
http://www.hobbyking.com/buddy.asp?c...0-4E8132AC49FF
HXT500 5g / .8kg / .10sec Micro Servo
http://www.hobbyking.com/buddy.asp?c...3-1B81D39356DE
Clear Foam Glue (Medium Cure) - Large 100ml
http://www.hobbyking.com/buddy.asp?c...B-8D3F2D21F972
Landing Gear for Micro Indoor Plane (1pair)
http://www.hobbyking.com/buddy.asp?c...7-4917F33806D1
3 Blade EP Propeller 9x7 / 229x178mm
http://www.hobbyking.com/buddy.asp?c...4-759C8A054DF1
Quanum 2.4Ghz Telemetry System Temp/Amp add-on
http://www.hobbyking.com/buddy.asp?c...3-DD4C0B877107
GWS EP Propeller (RD-6050 152x125mm) (6pcs/s
http://www.hobbyking.com/buddy.asp?c...8-1A922EF253F4
Prop Saver w/ Band 2mm (10pcs)
http://www.hobbyking.com/buddy.asp?c...3-42EFAC4239FF
ShaneH is offline Find More Posts by ShaneH
Old Oct 13, 2011, 07:22 PM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
Here are some Buddy Codes on the nice jet wheels they have. (Valid until Ocrober 26th)
This one is for the 63mm ones for $7.99 each
http://www.hobbyking.com/buddy.asp?c...9-B92CDD09E1C1
This one is for the 58mm ones for $8.23 each
http://www.hobbyking.com/buddy.asp?c...2-6EF292C77BA9
scatsob is offline Find More Posts by scatsob
Old Oct 13, 2011, 08:39 PM
runner2k is offline
Find More Posts by runner2k
runner2k's Avatar
Canada, ON, Toronto
Joined Jun 2011
I'm looking forward to buy these:
Quanun 2.4ghz telemetry system
http://www.hobbyking.com/hobbyking/s...dProduct=10343
EC3 plugs (10pairs/set)
http://www.hobbyking.com/hobbyking/s...idProduct=9625
Could anyone generate the discount code?
runner2k is offline Find More Posts by runner2k
Old Oct 13, 2011, 09:02 PM
mike99ca is offline
Find More Posts by mike99ca
Canada, ON, Toronto
Joined Aug 2011
Try this link for Quanun 2.4ghz telemetry system
http://hk.rc-international.info/budd...y-system-30252
Didn't find any for EC3 plugs
For thousands of buddy codes check http://hk.rc-international.info/home
mike99ca is offline Find More Posts by mike99ca
Old Oct 13, 2011, 09:14 PM
runner2k is offline
runner2k's Avatar
Canada, ON, Toronto
Joined Jun 2011
Thanks for the Help buddy!
The link does not work.
I live in Ontario-Canada as well and the buddy are dedicated to USA warehouse. We can't buy from USA warehouse right?
Thanks!
Old Oct 13, 2011, 09:55 PM
runner2k is offline
runner2k's Avatar
Canada, ON, Toronto
Joined Jun 2011
I found it!
Quanum 2.4Ghz Telemetry System (Volt/Amp/Temp/mAh) V2
http://www.hobbyking.com/hobbyking/s...E-1D10BA733EFD
Old Oct 14, 2011, 12:08 AM
runner2k is offline
runner2k's Avatar
Canada, ON, Toronto
Joined Jun 2011
Buddy codes:
EC3 plugs (10pairs/set) = $4,60 (orig. $4,94)
http://www.hobbyking.com/buddy.asp?c...9-554649FA80E9
JR Transmitter Neck Strap $2,78 (orig. $2,99)
http://www.hobbyking.com/buddy.asp?c...F-7AE9DE5443DA
Valid untill October 28th
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 11 Feb 15, 2014 03:26 PM
Discussion what do you use as umbilical cable to your ROV? fluxno ROV - Remotely Operated Vehicles 3 Apr 01, 2011 10:46 AM
Discussion Do you wish (When you started) there were as many choices HX3D014 Electric Heli Talk 0 Jan 09, 2007 04:40 AM
Cascade Charger that will charge your battery automatically as many packs as you wish cadetman Batteries and Chargers 8 Feb 08, 2005 02:12 AM
