6 Ch corona Receiver, connectors and Car Prog card
Car ESC prog card
http://www.hobbyking.com/buddy.asp?c...F-4462B17D99B7 3.5 mm spring connector http://www.hobbyking.com/buddy.asp?c...6-344501902025 6 ch Corona receiver ver 2 DSSS http://www.hobbyking.com/buddy.asp?c...C-0012B11827CB Cheers Nick |
View Post |
| estojayasatu | |
A moderator felt this post violated the following rule: Off Topic Advertisement.
It is temporarily hidden while estojayasatu
edits it.
Show it to me anyway.
Joined May 2010
Find my codes here: http://hk.rc-international.info/swarm/mardi (valid until September 02, 2011)
Code:
JST Male 2 pin connector set (10pcs/set) Save US$: 0.38 JST Female 2 pin connector set (10pcs/set) Save US$: 0.23 7x3.5R Propellers (Counter Rotating) (5Pcs/Bag) Save US$: 0.75 6x3R Propellers (Counter Rotating) (5Pcs/Bag) Save US$: 0.79 |
Joined Aug 2011
These are some buddy codes for some stuff
Turnigy Plush 30 amp ESC: http://www.hobbyking.com/buddy.asp?c...C-40D47272707E Turnigy 1600mah 30c lipo pack: http://www.hobbyking.com/buddy.asp?c...B-A301B5EDDF7C Turnigy Indoor brushless outrunner 2300kv: http://www.hobbyking.com/buddy.asp?c...4-87C80EAF531B Turnigy Pure Silicon 12AWG wire (Black): http://www.hobbyking.com/buddy.asp?c...B-5731F85A1835 Turnigy pure silicon 12AWG wire (red): http://www.hobbyking.com/buddy.asp?c...A-9823FFB9DFDF Futaba Y servo lead 30cm length (5pcs): http://www.hobbyking.com/buddy.asp?c...D-588380289259 prop saver w/band 2mm (10pcs): http://www.hobbyking.com/buddy.asp?c...1-D5E8FFD0DAD3 Hope they all work |
They don't work at all. You didn't post the codes correctly, the code should be 36 characters long.
Please add your codes to my buddy code collection site: http://hk.rc-international.info/swarm (go to the 'Add Buddy Code' tab-page when you open the link). My site will automatically generate code for you that you can use in forums (see mardimardigras' post just above your post to see how it looks like). |
Hooray! We are very close to 3000 buddy codes. It might happen today, otherwise probably tomorrow. On average, we grow over 100 codes per day at the moment. The person who adds buddy code #3000* to our site will receive a $ 10 PayPal donation from us. If your buddy code is #3000, then you will be notified that you qualified for the donation and presented with a code that you should email to us through the contact page. *) Since codes older than 14 days are removed by the system automatically at midnight (GMT +1), it is possible that at that time the counter goes back to a number below 3000 and starts counting again. The donation is only valid the first time someone posts code #3000. |
GVA, Switzerland
Joined Sep 2010
Find my codes here: http://hk.rc-international.info/swarm/little (valid until September 03, 2011)
Code:
HobbyKing 4-6min Epoxy Glue Save US$: 0.07 JST Female 2 pin connector set (10pcs/set) Save US$: 0.23 3.3V 3A UBEC - 2~5S Lipoly (6-23v) Save US$: 0.24 |
The Netherlands
Joined Feb 2010
Find my codes here: http://hk.rc-international.info/swarm/klaassie (valid until September 04, 2011)
Code:
Turnigy Magnetic Precision Prop Balancer Save US$: 1.97 |
Joined Feb 2011
1) Watt Meter & Power Analyzer
http://www.hobbyking.com/buddy.asp?c...2-7E5F0810EA3D (Everybody needs to have 1 of these!) 2) KD 36-12M Brushless Outrunner 1370Kv http://www.hobbyking.com/buddy.asp?c...F-5984A556397A 3) Turnigy nano-tech 1800mah 3S 25~50C http://www.hobbyking.com/buddy.asp?c...3-0F45C03197D8 |
Joined Jun 2011
Turnigy Marine 180A Brushless Boat ESC
http://www.hobbyking.com/buddy.asp?c...B-C098BCAEB7CF Propeller 435 http://www.hobbyking.com/buddy.asp?c...9-EF34936A2677 5mm Drive dog http://www.hobbyking.com/buddy.asp?c...A-3883DC5345A9 |
Joined Dec 2009
Find my codes here: http://hk.rc-international.info/swarm/ausi1972 (valid until September 01, 2011)
Code:
Push Rod Sleeves (2pc/bag) Save US$: 0.44 JXF 9x4 / 229 x 102mm Poly Composite propeller (2pcs/bag) Save US$: 0.41 Fuel Nipples D9xd3x15mm Save US$: 0.29 Fuel Tank 120cc Save US$: 0.38 |
Salt Lake City
Joined Aug 2003
HK450Pro Tail Boom w/ Custom Laser Text
http://www.hobbyking.com/buddy.asp?c...6-69FF4B692D9A On Board Lipoly Low Voltage Alarm (2s~4s) http://www.hobbyking.com/buddy.asp?c...4-48C7B49910AD Pocket Glow Igniter Charger http://www.hobbyking.com/buddy.asp?c...C-69BBFE5F2607 Turnigy 4.7mm Ball End Reamer http://www.hobbyking.com/buddy.asp?c...F-4A1EDECF1A66 |
Find my codes here: http://hk.rc-international.info/swarm/1111mavrick (valid until September 4, 2011)
Code:
ZIPPY Flightmax 4000mAh 2S1P 25C Car Lipoly (ROAR Approved) Save US$: 0.87 P-51 PNP (1.2m) 2 Blade Prop 11x7 Save US$: 3.71 C Bracket Sleeve Spacer - 110BS Save US$: 0.10 JST-XH 4S Wire Extension 20cm (10pcs/bag) Save US$: 0.37 HXT Alloy Composite Firewall Mount (85/36mm) Save US$: 0.85 Hands free small item holder Save US$: 0.69 D4023-850 Out Runner Motor Save US$: 1.08 2 in 1 Magnetizer and Demagnetizer Tool Save US$: 0.40 On Board Lipoly Low Voltage Alarm (2s~4s) Save US$: 0.08 Propeller Adapter (Colet Type) 3MM Save US$: 0.31 Front/Rear Upper and Lower Susp.Arms Set - A2016T Save US$: 0.48 Hobby King Programming Card for Car ESC Save US$: 0.51 |
| Thread Tools | |
| Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor | lrplin | Hot Online Deals | 5 | May 18, 2011 01:38 PM |
| Discussion what do you use as umbilical cable to your ROV? | fluxno | ROV - Remotely Operated Vehicles | 3 | Apr 01, 2011 10:46 AM |
| Discussion Do you wish (When you started) there were as many choices | HX3D014 | Electric Heli Talk | 0 | Jan 09, 2007 04:40 AM |
| Cascade Charger that will charge your battery automatically as many packs as you wish | cadetman | Batteries and Chargers | 8 | Feb 08, 2005 02:12 AM |
