This thread is privately moderated by obuggy, who may elect to delete unwanted replies.
Old Aug 16, 2011, 03:02 PM
dudy201 is offline
Find More Posts by dudy201
Joined Aug 2011
http://www.hobbyking.com/buddy.asp?c...F-FE649602A636
C10 Micro brushless outrunner 2900kv
http://www.hobbyking.com/buddy.asp?c...3-2537F21B5963
Hobbyking SS Series 40-50A ESC
Turnigy nano-tech 1300mah 3S 25~50C Lipo Pack
http://www.hobbyking.com/buddy.asp?c...E-55FDEEF223FE
PRODUCT ID: OR001-00310B
SF E-Prop 10x4.7 / 254x119.5mm w/ Adapters Black (5pcs/bag)
http://www.hobbyking.com/buddy.asp?c...2-2534DF01DD9C
Hextronik MG-14 14g/2.2kg/0.11sec aircraft servo
http://www.hobbyking.com/buddy.asp?c...9-AD8FCABDE7FD
D-MG16 Metal Gear 2.9kg/.08sec/18.8g
http://www.hobbyking.com/buddy.asp?c...F-A7A5D32A5347
GWS EP Propeller (DD-4040 102x102mm) (6pcs/set)
dudy201 is offline Find More Posts by dudy201
Old Aug 16, 2011, 03:10 PM
CrashingDutchman is offline
Find More Posts by CrashingDutchman
CrashingDutchman's Avatar
The Netherlands, Utrecht, Amersfoort
@FiveZigen, JettaManDan, queadlunnrau, dudy201: I have added your buddy codes to my buddy code collection site:
http://hk.rc-international.info/swarm/FiveZigen
http://hk.rc-international.info/swarm/JettaManDan
http://hk.rc-international.info/swarm/queadlunnrau
http://hk.rc-international.info/swarm/dudy201
Please consider to you my site (or similar sites) the next time, you get a much bigger audience. Furthermore, while posting the code on my site, you get code presented that you can easily copy/paste in this and other forums.
Example:
Find my codes here: http://hk.rc-international.info/swarm/dudy201 (valid until August 30, 2011)
CrashingDutchman is offline Find More Posts by CrashingDutchman
Old Aug 16, 2011, 05:29 PM
lanc is offline
Find More Posts by lanc
lanc's Avatar
Joined Sep 2009
Hobby King ECO6-10 200W 10A 6S bal/dis/cyc charger with acc
$4.38 savings
http://www.hobbyking.com/buddy.asp?c...6-C71C38A7C3AE
Master Airscrew 6 X 4 props ( 2 pack )
$.58 savings
http://www.hobbyking.com/buddy.asp?c...4-6B57E0068D01
lanc is offline Find More Posts by lanc
Old Aug 16, 2011, 05:30 PM
arrior is offline
Find More Posts by arrior
Joined Feb 2010
APC style propeller 8x4-E YOU SAVE 0.40 USD
arrior is offline Find More Posts by arrior
Old Aug 17, 2011, 10:14 AM
schumixmd is offline
Find More Posts by schumixmd
schumixmd's Avatar
Moldova
Joined Jun 2010
Find my codes here: http://hk.rc-international.info/swarm/schumixmd (valid until August 31, 2011)
schumixmd is offline Find More Posts by schumixmd
Old Aug 17, 2011, 12:43 PM
JettaManDan is offline
Find More Posts by JettaManDan
Crazy Foamie Builder
JettaManDan's Avatar
United States, MD, Lexington Park
Joined Jan 2010
Example:
Thanks for adding my stuff..i tried ot add it myself but it wouldn't let me..anything i am doing wrong?
JettaManDan is offline Find More Posts by JettaManDan
Old Aug 17, 2011, 12:50 PM
I am not sure what you are doing wrong, but the procedure is this:
- go to http://hk.rc-international.info/swarm
- select 'add buddy code' tab-page
- Enter buddy code
- press [tab]-key to leave buddy code field.
The site will now retrieve some information from Hobbyking. When the new page appears:
- check all data (buddy price, your buddy name -preferably forum name- and the date the buddy code expires.
- click submit button.
The code will then be added to the collection. The buddy codes you enter will be written in a text field, complete with correct codes, to copy/paste into forum messages.
Let me know if it still don't work for you.
Old Aug 17, 2011, 05:23 PM
jgalexander is offline
Find More Posts by jgalexander
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
- Enter buddy code
The site takes a while to autoload the info after I paste in the buddy code, about 10-15 seconds. Perhaps that's what was causing the other user an issue?
jgalexander is offline Find More Posts by jgalexander
Old Aug 18, 2011, 01:30 AM
If the Hobbyking site is busy, then indeed the loading can take a few seconds more than normally.
Old Aug 18, 2011, 02:04 AM
schumixmd's Avatar
Moldova
Joined Jun 2010
Hi CrashingDutchman
however it seems you have some problems with HK at the moment, because when I was adding last codes I get wrong figures.
you can check 2 servos BMS 761 and 705
and for the third your site failed to take the picture.
Old Aug 18, 2011, 05:11 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
TGS Sport 14x7E Precision propeller
http://www.hobbyking.com/buddy.asp?c...C-6756D46DCF3E
Master Airscrew propeller 15x6
http://www.hobbyking.com/buddy.asp?c...1-3AF13B8A0810
e_lm_70 is offline Find More Posts by e_lm_70
Old Aug 18, 2011, 07:03 AM
davecar is offline
Find More Posts by davecar
Joined May 2011
http://www.hobbyking.com/buddy.asp?c...1-FBFE6773278B
Description:
davecar is offline Find More Posts by davecar
Old Aug 18, 2011, 07:06 AM
davecar is offline
Joined May 2011
Nano Tech 160Mah 1S
http://www.hobbyking.com/buddy.asp?c...3-FA9F927381EB
Description:
Old Aug 18, 2011, 07:07 AM
davecar is offline
Joined May 2011
Low Voltage Alarm
http://www.hobbyking.com/buddy.asp?c...F-B040C41CF9B7
Description:
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 11 Feb 15, 2014 04:26 PM
Discussion what do you use as umbilical cable to your ROV? fluxno ROV - Remotely Operated Vehicles 3 Apr 01, 2011 11:46 AM
Discussion Do you wish (When you started) there were as many choices HX3D014 Electric Heli Talk 0 Jan 09, 2007 05:40 AM
Cascade Charger that will charge your battery automatically as many packs as you wish cadetman Batteries and Chargers 8 Feb 08, 2005 03:12 AM
