This thread is privately moderated by obuggy, who may elect to delete unwanted replies.
Old Aug 14, 2011, 10:40 AM
siglock is offline
Find More Posts by siglock
United States, WA, Spanaway
Joined Jul 2009
ttp://www.hobbyking.com/buddy.asp?code=DD5464F4-F074-46BE-8BB1-A2AE70B1DAC5
1300KV 24 Gram Blue Wonder Brushless Outrunner
siglock is offline Find More Posts by siglock
Old Aug 14, 2011, 10:41 AM
siglock is offline
Joined Jul 2009
http://www.hobbyking.com/buddy.asp?c...1-A2AE70B1DAC5
sorry, this is the correct link
Old Aug 14, 2011, 01:17 PM
CrashingDutchman is offline
Find More Posts by CrashingDutchman
CrashingDutchman's Avatar
The Netherlands, Utrecht, Amersfoort
@siglock, ror1 and lanc: You will a much bigger audience if you use one of the buddy code collection sites.
For your guys I have added to my buddy code collection site:
http://hk.rc-international.info/swarm/K9000wner
http://hk.rc-international.info/swarm/ror1
http://hk.rc-international.info/swarm/lanc
http://hk.rc-international.info/swarm/siglock
Good luck with earning Hobbyking points
CrashingDutchman is offline Find More Posts by CrashingDutchman
Old Aug 14, 2011, 03:16 PM
ror1 is offline
Find More Posts by ror1
FPV'r
ror1's Avatar
Canada, ON, Carleton Place
Joined May 2011
do you have script to add codes?
ror1 is offline Find More Posts by ror1
Old Aug 14, 2011, 04:02 PM
you can add them at http://hk.rc-international.info/swarm, then click the 'add buddy codes' tab page. Enter the buddy link that you get from Hobbyking and press the tab-key. The page will retrieve some data from Hobbyking and fill in the missing data. Check the data and correct where needed. The click the submit button.
Good luck and thanks for using the site.
Ps. Don't forget to thank the site sponsors too
Old Aug 14, 2011, 05:01 PM
bluemeane is offline
Find More Posts by bluemeane
bluemeane's Avatar
Joined Apr 2007
Code for Rhino 610mAh 2S 7.4v 20C Lipoly Pack's
http://www.hobbyking.com/buddy.asp?c...D-C8EC3700A4C4
Have at it.
Will have one for the new Nano Rx as well soon!!
bluemeane is offline Find More Posts by bluemeane
Old Aug 14, 2011, 07:30 PM
Refalovala is offline
Find More Posts by Refalovala
Joined Jun 2011
Hello everyone! I seem to have received a buddy code from buying this lipo but funny not my esc. Go figure. Anyhoo here's the info:
Spec.
Minimum Capacity: 3600mAh
Configuration: 4S1P / 14.8v / 4Cell
Constant Discharge: 20C
Peak Discharge (10sec): 30C
Pack Weight: 389g
Pack Size: 137 x 43 x 29mm
Charge Plug: JST-XH
Discharge Plug: 4mm Bullet-connector
And the link:
http://www.hobbyking.com/buddy.asp?c...A-51F7B42B376F
Im kind of new at this electric side of rc, have to admit it has evolved pretty nicely. Im putting this in an E Flite F-16 w/a Delta v480 4000kv motor and a Turnigy dlux 55A SBEC. Hope it will hold up to this battery.... I know that the esc will only give the motor the amps it ask for, so in theory the esc will only pull the same amount of amps from the lipo. That is I hope...
Almost forgot. You have 14 days from 8/12/11....
Refalovala is offline Find More Posts by Refalovala
Old Aug 14, 2011, 07:39 PM
bluemeane's Avatar
Joined Apr 2007
Find my codes here: http://hk.rc-international.info/swarm/jeff (valid until August 28, 2011)
Old Aug 14, 2011, 07:44 PM
cs373 is offline
Find More Posts by cs373
Joined Aug 2011
Hobby King Buddy Codes
Turnigy 2830 Brushless Motor 1000kv
http://www.hobbyking.com/buddy.asp?c...8-C490CAAF4287
TURNIGY Plush 30amp Speed Controller
http://www.hobbyking.com/buddy.asp?c...D-1CB4881175CA
Rhino 1250mAh 3S 11.1v 30C Lipoly Pack
http://www.hobbyking.com/buddy.asp?c...D-D9175972102A
Rhino 1050mAh 3S 11.1v 40C Lipoly Pack
http://www.hobbyking.com/buddy.asp?c...4-90766E89934D
14 days from Aug 14 2011
cs373 is offline Find More Posts by cs373
Old Aug 14, 2011, 08:41 PM
ror1 is offline
FPV'r
ror1's Avatar
Joined May 2011
Spec.
Pack Weight: 389g
Charge Plug: JST-XH
And the link:
NOTE: this is USA only
Old Aug 15, 2011, 02:36 AM
schumixmd is online now
Find More Posts by schumixmd
schumixmd's Avatar
Moldova
Joined Jun 2010
Hello Guys,
soemthing wrong with hk.rc-international.info/swarm - I cannot add my code there.
Here is FMA CoPilot CDP4
it is on backorder but it is worth waiting.
Valid starting now
schumixmd is online now Find More Posts by schumixmd
Old Aug 15, 2011, 07:08 AM
Originally Posted by schumixmd View Post
Hello Guys,
Valid starting now
I have added it for you manually: http://hk.rc-international.info/swarm/schumixmd
The FMA copilot is a product that is only available to VIP members. My software doesn't know how to handle this, so that is why you got the error page.
I will see if I can repair that for the next version.
Old Aug 15, 2011, 07:49 AM
davecar is offline
Find More Posts by davecar
Joined May 2011
Mega Charging Plug
http://www.hobbyking.com/buddy.asp?c...7-6E05F7583EF8
Description:
davecar is offline Find More Posts by davecar
Old Aug 15, 2011, 11:51 AM
Donaldsneffe is offline
Find More Posts by Donaldsneffe
Vienna calling...
Donaldsneffe's Avatar
Österreich, Wien
Joined Aug 2010
Find my codes here: http://hk.rc-international.info/swarm/donaldsneffe (valid until August 29, 2011)
Code:
Slow-Cure 30 Min Epoxy 4.5 oz                                    Save US$: 1.16
Walter
Donaldsneffe is offline Find More Posts by Donaldsneffe
Old Aug 15, 2011, 02:31 PM
I am sure you recognize this: You have added a few Hobbyking items to your shopping cart and the site says:
ADD MORE TO YOUR CART FOR $0.00 EXTRA IN SHIPPING!"
GLS Express Courier 10kg (Germany to Netherlands) $9.99 9167g left.
SingPost AirParcel 2kg / 7-21Days $37.11 1167g left.
International (Registered) Air Mail 751g - 1kg $17.95 166g left.
EMS Express to Netherlands(MAX 1kg) $29.95 166g left.
Air Parcel (NETHERLANDS) 500g - 1499g $24.36 666g left.
DPD-NL 4-7 Days 0-3kg (Germany to Netherlands) $12.30 2166g left.
To fill up your package, I have added the possibility to filter buddy code products on weight. Let's say you have 10 gram left, you type '10' in the textbox and click the 'Go'-button. All items that weigh less than or equal to 10 gram are shown. You can easily go through the pages and add the items you like to your order. Why filter on grams? Well, Hobbyking uses grams.
Have a look at it here: http://hk.rc-international.info/swarm
If you find anything strange with this new functionality, then please let me know in this thread, I am monitoring it on a daily basis. Please keep it short so we can stay on topic.
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 11 Feb 15, 2014 03:26 PM
Discussion what do you use as umbilical cable to your ROV? fluxno ROV - Remotely Operated Vehicles 3 Apr 01, 2011 10:46 AM
Discussion Do you wish (When you started) there were as many choices HX3D014 Electric Heli Talk 0 Jan 09, 2007 04:40 AM
Cascade Charger that will charge your battery automatically as many packs as you wish cadetman Batteries and Chargers 8 Feb 08, 2005 02:12 AM
