This thread is privately moderated by obuggy, who may elect to delete unwanted replies.
Old Jul 11, 2011, 01:35 AM
Mheeli is offline
Find More Posts by Mheeli
Mheeli's Avatar
Bangkok, Thailand
Joined Jul 2002
Turnigy nano-tech 3000mah 6S 25~50C Lipo Pack for $37.58
http://www.hobbyking.com/buddy.asp?c...A-FE4FBDF0941B
Mheeli is offline Find More Posts by Mheeli
Old Jul 11, 2011, 06:26 AM
arrior is offline
Find More Posts by arrior
Joined Feb 2010
Valid till 19.07.2011
hexTronik DT700 Brushless Outrunner 700kv You Save 1.52Usd
Turnigy nano-tech 2650mah 2S 25~50C Lipo Pack You Save 2.96Usd
Turnigy nano-tech 460mah 3S 25~40C Lipo Pack You Save 1.36Usd
NTM Prop Drive 35-48 Series 900KV / 815W motor You Save 6.89 (Valid till 16.07.2011)
arrior is offline Find More Posts by arrior
Old Jul 11, 2011, 07:30 AM
aucifer is offline
Find More Posts by aucifer
Joined Jun 2011
P1.4x40mm Nylon Prop - Sea Fire & Surge Cursher You Save 0.90Usd
http://www.hobbyking.com/buddy.asp?c...B-34DD25288C47
aucifer is offline Find More Posts by aucifer
Old Jul 11, 2011, 03:32 PM
techman28 is offline
Find More Posts by techman28
Joined Nov 2010
Female EC3 <-> Male XT60 (3pcs/bag) - For connecting XT60 Lipos to an ESC with an EC3 connector
http://www.hobbyking.com/buddy.asp?c...6-D012DC9A0B98
techman28 is offline Find More Posts by techman28
Old Jul 11, 2011, 05:20 PM
CrashingDutchman is offline
Find More Posts by CrashingDutchman
CrashingDutchman's Avatar
The Netherlands, Utrecht, Amersfoort
Your buddy code is not valid, it should be 36 characters long.
CrashingDutchman is offline Find More Posts by CrashingDutchman
Old Jul 12, 2011, 05:08 AM
rcflyair is offline
Find More Posts by rcflyair
rcflyair's Avatar
United States, OK, Ada
Joined Jun 2007
Nanotech 300mah lipos for Blade mcpx
Here's a buddy code for Nanotech 300mah lipos for the blade mcpx
http://www.hobbyking.com/buddy.asp?code=7268B8CE-1F5C-43F8-B1EF-3FD34E862CB7
rcflyair is offline Find More Posts by rcflyair
Old Jul 12, 2011, 09:51 AM
George Tanner is offline
Find More Posts by George Tanner
George Tanner's Avatar
Joined Jun 2011
Hello Guys,
Available until 26/07.
Zippy Flightmax 1100mAh 6.6v LiFePo4 2S1P Re
http://www.hobbyking.com/buddy.asp?c...3-797F8838E983
JR to EH Adapter wire (2pcs/bag)
http://www.hobbyking.com/buddy.asp?c...1-D0E3F69CB567
Nylon Arm 2.8 x 6 x 6mm (10pcs)
http://www.hobbyking.com/buddy.asp?c...1-1C7210908519
Regards,
George Tanner is offline Find More Posts by George Tanner
Old Jul 12, 2011, 10:22 AM
control flyer is offline
Find More Posts by control flyer
Kuwait
Joined Jul 2010
Hi,
Some buddy codes upto 28/07/2011 someone may be interested...
GT450PRO Main Shaft (118x5mm)
http://www.hobbyking.com/buddy.asp?c...4-DD5D3BB43E97
TP 450-Size 2415-09T Brushless Heli Motor 2700kv
http://www.hobbyking.com/buddy.asp?c...E-DE4DD52185EB
Turnigy 4mm Heat Shrink Tube Blue (1mtr)
http://www.hobbyking.com/buddy.asp?c...6-6BAABFFD2E60
GT450PRO Plsatic Tail Blade
http://www.hobbyking.com/buddy.asp?c...1-1BD28F96DB45
450 Class Plastic Main Blade(for scale helicopters)
http://www.hobbyking.com/buddy.asp?c...4-C2212AF1DF98
Turnigy R/C LED Lighting System
http://www.hobbyking.com/buddy.asp?c...C-02436CAB9E60
WOODIE 325mm Wood Main Blades (Baked finish)
http://www.hobbyking.com/buddy.asp?c...D-24BEBDC03203
HK450V2 Pinion Gear 3.17mm 11T/13T (Align part)
http://www.hobbyking.com/buddy.asp?c...7-4233EA02597F
HK450V2 Tail Rotor Grip
http://www.hobbyking.com/buddy.asp?c...7-69FFCBB109D0
Main Rotor Blade Assembly Tool (5mm)
http://www.hobbyking.com/buddy.asp?c...3-4A9C395F0F03
Hobby King Digital Servo 2.2kg / 12.5g / .11
http://www.hobbyking.com/buddy.asp?c...1-37BBB533B2D1
Regards,
DoD
control flyer is offline Find More Posts by control flyer
Old Jul 12, 2011, 03:09 PM
Welgar is offline
Find More Posts by Welgar
Joined Jul 2011
Turnigy 9X 2.4GHz 8Ch Receiver (V2)
Code for Turnigy 9X 2.4GHz 8Ch Receiver (V2)
http://www.hobbyking.com/buddy.asp?c...5-D8D5C072503D
Welgar is offline Find More Posts by Welgar
Old Jul 13, 2011, 01:12 AM
Nick Milligan is offline
Find More Posts by Nick Milligan
SOARda involved
Canada, BC, Kamloops
Joined Jul 2009
Turnigy Long Shaft 4pc Hex driver set
http://www.hobbyking.com/buddy.asp?c...9-A93624E84FAF
Futaba/JR Connector caps (5pcs/set)
http://www.hobbyking.com/buddy.asp?c...C-9E3547A82FE5
Servo Terminals (Futaba) Gold Plated (10pair
http://www.hobbyking.com/buddy.asp?c...1-5F7FAE2CCA85
Servo Terminals (JR) Gold Plated (10pairs/se
http://www.hobbyking.com/buddy.asp?c...6-D7799EE5EA9F
Grub Screw set M3x3 10 Pack
http://www.hobbyking.com/buddy.asp?c...6-DB37EAE463BE
Wire Mesh Guard Black 8mm (1mtr)
http://www.hobbyking.com/buddy.asp?c...2-BEBA4E4622EF
Wire Mesh Guard Black 6mm (1mtr)
http://www.hobbyking.com/buddy.asp?c...A-42A13DB63079
Wire Mesh Guard Black 10mm (1mtr)
http://www.hobbyking.com/buddy.asp?c...B-50A9B8C5AD44
Turnigy Pure-Silicone Wire 16AWG (1mtr) Red
http://www.hobbyking.com/buddy.asp?c...E-2266020D4D2D
Turnigy Pure-Silicone Wire 16AWG (1mtr) BLAC
http://www.hobbyking.com/buddy.asp?c...6-F5C498A96D47
JST-XH 2S Wire Extension 20cm (10pcs/bag)
http://www.hobbyking.com/buddy.asp?c...C-2A4E34ECF83D
R/C Car ball joint W/ Locking Sleeve 3mm
http://www.hobbyking.com/buddy.asp?c...A-B59244539230
Nick Milligan is offline Find More Posts by Nick Milligan
Old Jul 13, 2011, 10:39 AM
aucifer is offline
Joined Jun 2011
Twin LED Kit - BLUE with Switch
http://www.hobbyking.com/buddy.asp?c...C-BFE6CB756140
http://www.hobbyking.com/hobbyking/s...B-34DD25288C47
Old Jul 13, 2011, 11:02 AM
gsnathan is offline
Find More Posts by gsnathan
Joined Feb 2011
Turnigy nano-tech 1800mah 2S 25~50C Lipo Pack
http://www.hobbyking.com/buddy.asp?c...1-7613179D0CC7
TURNIGY Plush 12amp (2A BEC) BESC
http://www.hobbyking.com/buddy.asp?c...1-CEE44203C215
Turnigy MG90S Metal Gear Servo 1.8kg / 13.4g
http://www.hobbyking.com/buddy.asp?c...2-91567E84C983
Turnigy nano-tech 1000mah 2S 25~50C Lipo Pack
http://www.hobbyking.com/buddy.asp?c...A-FBD52D99FD77
TURNIGY Plush 40amp Speed Controller
http://www.hobbyking.com/buddy.asp?c...D-879D8B935EB2
Turnigy nano-tech 2200mah 3S 25~50C Lipo Pack
http://www.hobbyking.com/buddy.asp?c...7-B5A6E3C405CC
Turnigy nano-tech 1000mah 3S 25~50C Lipo Pack
http://www.hobbyking.com/buddy.asp?c...7-614682C7DAD5
TURNIGY Plush 18amp Speed Controller
http://www.hobbyking.com/buddy.asp?c...7-0EA84A940EA4
http://www.hobbyking.com/buddy.asp?c...6-61CE04864DF0
gsnathan is offline Find More Posts by gsnathan
Old Jul 13, 2011, 01:57 PM
Guys, please don't forget to use one of the buddy code collection site. You get a much bigger audience there that in this thread.
My site is here: http://hk.rc-international.info/swarm. It automatically generates code (with links to product) that you can paste in easily in forums, in case you want.
Example:
Find my codes here: http://hk.rc-international.info/swarm/welgar (valid until July 27, 2011)
http://hk.rc-international.info/swarm/rcflyair
http://hk.rc-international.info/swarm/nick-milligan
Old Jul 13, 2011, 01:58 PM
@gsnathan: Your buddy codes are incomplete! They should be 36 digits long.
Edit: I corrected it for you (with help from your links in other thread)
Find my codes here: http://hk.rc-international.info/swarm/gsnathan (valid until July 27, 2011)
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 11 Feb 15, 2014 03:26 PM
Discussion what do you use as umbilical cable to your ROV? fluxno ROV - Remotely Operated Vehicles 3 Apr 01, 2011 10:46 AM
Discussion Do you wish (When you started) there were as many choices HX3D014 Electric Heli Talk 0 Jan 09, 2007 04:40 AM
Cascade Charger that will charge your battery automatically as many packs as you wish cadetman Batteries and Chargers 8 Feb 08, 2005 02:12 AM
