This thread is privately moderated by obuggy, who may elect to delete unwanted replies.
Old Jan 24, 2013, 02:08 AM
Justapoke is offline
Find More Posts by Justapoke
The Netherlands
Joined Jun 2012
All my buddy-codes on RCSearch.info
NTM Prop Drive Series 28-26A 1200kv / 250w (DE Warehouse)
$13.93* (buddy price -11%, -$1.76)
Turnigy Transmitter Bag / Carrying Case (NL Warehouse)
$9.44* (buddy price -18%, -$2.09)
Micro Servo Connector Lead 1.25 Pitch - Female Plug (5pcs/bag)
$0.91*
Folding Propeller Assembly 8x6 (Alloy/Hub Spinner) (1pc/bag)
$7.32* (buddy price -13%, -$1.08)
Folding Propeller Assembly 8x4.5 (Alloy/Hub Spinner) (1pc/bag)
Turnigy Aerodrive SK3 - 2826-1240kv Brushless Outrunner Motor
$15.39* (buddy price -6%, -$1.02)
Propeller Adapter Puller / Pinion Gear Puller
$3.02* (buddy price -24%, -$0.97)
Hobbyking E-Fair Balsa Glider 1540mm (ARF) (DE Warehouse)
$49.37* (buddy price -13%, -$7.29)
Transmitter Neck Strap Balancer (JR/Spektrum/Hitec) (NL Warehouse)
$2.78* (buddy price -13%, -$0.41)
2.4Ghz A-FHSS Compatible 5CH Micro Receiver (Hitec Minima compatible) (NL Warehouse)
$12.43* (buddy price -13%, -$1.84)
HXT500 5g / .8kg / .10sec Micro Servo (NL Warehouse)
$3.26* (buddy price -13%, -$0.49)
Durafly 1100mm P-51D Landing gear (NL Warehouse)
$5.40* (buddy price -36%, -$3.02)
TURNIGY Voltage Protector
$0.61* (buddy price -69%, -$1.38)
Hobbyking 2-8S Cell Checker with Low Voltage Alarm
$3.17* (buddy price -13%, -$0.47)
Mini Ultra-light Horns 23x14x6mm (4pcs/set)
$0.65* (buddy price -33%, -$0.32)
Female Molex 1.25 to Male JR Servo Extension (1pc)
$0.35* (buddy price -36%, -$0.2)
Male Molex 1.25 to Female JR Servo Extension (1pc)
Turnigy 20A BRUSHED ESC
$4.29* (buddy price -13%, -$0.66)
Turnigy Aerodrive SK3 2836 Series Replacement Shaft Set
$0.39* (buddy price -59%, -$0.57)
NTM Prop Drive 3530 Series Replacement Shaft
$0.48* (buddy price -49%, -$0.47)
Turnigy Aerodrive SK3 2826 Series Replacement Shaft Set
$0.37* (buddy price -60%, -$0.56)
NTM Prop Drive 2826 Series Replacement Shaft
$0.45* (buddy price -48%, -$0.41)
NTM Prop Drive 2836 Series Replacement Shaft
$0.48* (buddy price -46%, -$0.41)
Turnigy Aerodrive SK3 3542 Series Replacement Shaft Set
$0.61*
Justapoke is offline Find More Posts by Justapoke
Old Jan 25, 2013, 05:01 AM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Turnigy High-End Fiberglass Canopy for Trex 500 Pro
Atomic Skull is offline Find More Posts by Atomic Skull
Old Jan 25, 2013, 05:58 PM
ckleanth is online now
Find More Posts by ckleanth
If it has wings it will fly...
ckleanth's Avatar
United Kingdom, England, Birmingham
Joined Mar 2011
http://www.hobbyking.com/buddy.asp?c...C-B91550845CEF
http://www.hobbyking.com/buddy.asp?c...5-68546045615B
http://www.hobbyking.com/buddy.asp?c...9-AA201CDD70F9
Extra Codes, You can save 75.51% for all of this products with:http://rc-buddy.com/user/ckleanth! Codes from RC-Buddy.com
FrSky 2.4G V8 Series 5db module Antenna
Savings: 30.95 % / $0.91
Price after: $2.03
Weight: g
Turnigy Super Brain 60A Brushless ESC
Savings: 95.94 % / $47.96
Price after: $2.03
Weight: g
Turnigy nano-tech 1300mAh 3S 45~90C Lipo Pack (UK Warehouse)
Savings: 13.05 % / $1.86
Price after: $12.39
Weight: 161 g
ckleanth is online now Find More Posts by ckleanth
Old Jan 25, 2013, 09:18 PM
bernardo gomes is offline
Find More Posts by bernardo gomes
Joined Jun 2008
2 DAYS TO END
FrSky DF 2.4Ghz Combo Pack for JR w/ Module & RX - 5.97
http://www.hobbyking.com/buddy.asp?c...9-EEAD9C9A9C70
Turnigy 0# 3mm Philips Head Screwdriver - 0.37
http://www.hobbyking.com/buddy.asp?c...F-2FFC9C6DD8C3
13 DAYS TO END
Turnigy 9XR Safety Protected 11.1v (3s) 2200mAh 1.5C Transmitter Pack - 2,12
http://www.hobbyking.com/buddy.asp?c...6-2C1F991B4ED4
Turnigy nano-tech 950mah 3S 25~50C Lipo Pack - 1,14
http://www.hobbyking.com/buddy.asp?c...D-5ACE2F7AB04C
Turnigy Heat Shrink Tube 50mm BLACK (1mtr) 0.57
http://www.hobbyking.com/buddy.asp?c...A-34F1FB39861F
Wii Motion Plus - 0.63
http://www.hobbyking.com/buddy.asp?c...4-759362EF4920
bernardo gomes is offline Find More Posts by bernardo gomes
Old Jan 25, 2013, 09:29 PM
dutchumb is offline
Find More Posts by dutchumb
Joined Nov 2012
Thanks for the codes
dutchumb is offline Find More Posts by dutchumb
Old Jan 26, 2013, 03:24 PM
rcfanatic123 is offline
Find More Posts by rcfanatic123
rcfanatic123's Avatar
United States, NY, Rye
Joined Feb 2012
http://www.hobbyking.com/buddy.asp?c...E-42A83C90FFE9
PRODUCT ID: T2650.3S.1C
"The Turnigy 2650mAh Transmitter pack fits snuggly into any Futaba or Jr radio which uses a 4x4 AA cell battery configuration (see image).
It includes discharge plugs for both JR, Spektrum plus other radios.
It's built with a low C-rate Long Life LiCo Formular which isn't like a standard LiPo. It retains voltage for months on end without need for a storage charge so you can store your radio and fly once a month and not have to worry about discharging or recharging your pack."
rcfanatic123 is offline Find More Posts by rcfanatic123
Old Jan 26, 2013, 11:35 PM
allmotor09 is offline
Find More Posts by allmotor09
Joined Jan 2013
close
allmotor09 is offline Find More Posts by allmotor09
Old Jan 26, 2013, 11:49 PM
Joined Jan 2013
close
Old Jan 26, 2013, 11:57 PM
Joined Jan 2013
close
Old Jan 27, 2013, 08:26 AM
hatbiday is offline
Find More Posts by hatbiday
Joined Jan 2013
Turnigy nano-tech 2200mah 3S 35~70C Lipo Pack
Save $2.95 on Turnigy nano-tech 2200mah 3S 35~70C Lipo Pack / $15.04*
Code is Good until Feb 9, 2013
hatbiday is offline Find More Posts by hatbiday
Old Jan 27, 2013, 08:34 AM
hatbiday is offline
Joined Jan 2013
10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation (Red)
$1.33* for 10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation (Red) / $1.31 Saving
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 11 Feb 15, 2014 03:26 PM
Discussion what do you use as umbilical cable to your ROV? fluxno ROV - Remotely Operated Vehicles 3 Apr 01, 2011 10:46 AM
Discussion Do you wish (When you started) there were as many choices HX3D014 Electric Heli Talk 0 Jan 09, 2007 04:40 AM
Cascade Charger that will charge your battery automatically as many packs as you wish cadetman Batteries and Chargers 8 Feb 08, 2005 02:12 AM
