This thread is privately moderated by obuggy, who may elect to delete unwanted replies.
Old Jan 06, 2013, 02:00 AM
T.R.M. is offline
Find More Posts by T.R.M.
T.R.M.'s Avatar
España, AL, Bollullos de la Mitación
Joined Jan 2012
Hobbyking Y650 Scorpion Glass Fiber Pan/Tilt Camera Mount
http://www.hobbyking.com/buddy.asp?c...E-6DD614B67882
T.R.M. is offline Find More Posts by T.R.M.
Old Jan 06, 2013, 06:43 PM
rabdooley is offline
Find More Posts by rabdooley
rabdooley's Avatar
USA, NH, Center Ossipee
Joined Apr 2010
RCG 30cc Gas engine w/ CD-Ignition 3.9HP/2.94kw (USA Warehouse)
Normally $223.00 Swarm $179.34
http://www.hobbyking.com/buddy.asp?c...5-4770A9CBBAFD
rabdooley is offline Find More Posts by rabdooley
Old Jan 06, 2013, 11:49 PM
toppnotch is offline
Find More Posts by toppnotch
Joined Feb 2012
Find my codes here: http://hk.rc-international.info/swarm/moe-faux (valid until January 14, 2013)
Solo Pro 100 Horizontal Shaft (2pcs/bag) Save US$: 0.52
Solo Pro 180 Main Gear Save US$: 0.61
Solo Pro 180 Main Blade Grip Set w/Bearings Save US$: 1.26
Turnigy Servo Signal Reverser Save US$: 0.41
ZIPPY Compact 850mAh 2S 25C Lipo Pack Save US$: 1.93
JST Female 2 pin connector set (10pcs/set) Save US$: 0.24
HXT500 5g / .8kg / .10sec Micro Servo Save US$: 0.44
toppnotch is offline Find More Posts by toppnotch
Old Jan 07, 2013, 11:57 AM
RVA is offline
RVA
Find More Posts by RVA
RVA
RVA's Avatar
United States, CA, Long Beach
Joined Jan 2011
HK Warehouse
Charge Cable w/ Male XT60 <-> 4mm Banana plug
$2.04*
Control Horns 13.5x16mm (10pcs)
$0.61*
RVA is offline Find More Posts by RVA
Old Jan 07, 2013, 01:42 PM
hemiblas is offline
Find More Posts by hemiblas
United States, CO, Aurora
Joined May 2009
Turnigy 2200mAh 3S 20C Lipo Pack - You will not believe the price. $4.27 each save over 3 bucks.
http://www.hobbyking.com/buddy.asp?c...E-D8AFE46E41E5
Turnigy 9x receiver
http://www.hobbyking.com/buddy.asp?c...1-965CFFAABE31
Turnigy battery strap
http://www.hobbyking.com/buddy.asp?c...E-7843F65C3488
hemiblas is offline Find More Posts by hemiblas
Old Jan 07, 2013, 02:33 PM
nguyen.tran is offline
Find More Posts by nguyen.tran
nguyen.tran's Avatar
Canada, BC, Vancouver
Joined Nov 2008
All my buddy-codes on RCSearch.info
Turnigy 9X 2.4GHz 8Ch Receiver (V2)
$8.29*
Spare Shaft for 24gram HXM2730 Motor
$0.47*
nguyen.tran is offline Find More Posts by nguyen.tran
Old Jan 07, 2013, 02:59 PM
efx is offline
efx
Find More Posts by efx
efx
Rookie in training, heads up
efx's Avatar
Los Angeles
Joined Mar 2010
Does anyone know what's up with both buddy code sites. International is throwing some error and the buddyprice has been crapping out for a while not accepting buddy codes or working really. I know the HK site is also acting up today as I can barely get in there. I know they are all different sites so kind of interesting how all are well crapping out...lol
efx is offline Find More Posts by efx
Old Jan 07, 2013, 07:33 PM
RyoKen is offline
Find More Posts by RyoKen
The Netherlands, ZH, Rijswijk
Joined Aug 2011
(valid until January 21, 2013)
HXT 500 for $3.03
http://www.hobbyking.com/buddy.asp?c...B-95CF8AD1520E
Description:
TURNIGY Voltage Booster for Servo & Rx (1S to 5v 1A) for $0.94
http://www.hobbyking.com/buddy.asp?c...3-74FA6AAC7647
Description:
FrSky DHT 8ch DIY Telemetry Compatible Transmitter Module for $20.63
http://www.hobbyking.com/buddy.asp?c...3-50B024B0F2AC
Description:
RyoKen is offline Find More Posts by RyoKen
Old Jan 07, 2013, 07:47 PM
T.R.M. is offline
T.R.M.'s Avatar
Joined Jan 2012
NTM Prop Drive 28-26 1000kV / 315W
http://www.hobbyking.com/buddy.asp?c...0-EF393B45CAAE
ZIPPY Flightmax 4000mAh 4S1P 40C
http://www.hobbyking.com/buddy.asp?c...D-75716873A056
Multi-Rotor Roll / Tilt GoPro Hero 2 Soporte de la cámara
http://www.hobbyking.com/buddy.asp?c...C-657C5D88A830
4mm Gold Connectors 10 pares (20PC)
http://www.hobbyking.com/buddy.asp?c...0-C7F840A0D699
Propeller Adapter (Tipo Colet) 3MM
http://www.hobbyking.com/buddy.asp?c...3-B88B3C1D960E
Hélice APC Style 9x6R (Rotación Derecha 2 piezas)
http://www.hobbyking.com/buddy.asp?c...0-13B1AD3AEB17
Hélice APC Style 9x6 (2 piezas)
http://www.hobbyking.com/buddy.asp?c...7-C35D679C9DFC
Tornillos M3x12mm Nylon (10pcs/bag)
http://www.hobbyking.com/buddy.asp?c...8-24BEB776A6EA
M3 Tuerca Nylon (10pcs/bag)
http://www.hobbyking.com/buddy.asp?c...A-2C9DBA3A6EDE
5.6mm x 36mm Nylon M3 Threaded Espaciador (10pc)
http://www.hobbyking.com/buddy.asp?c...4-B1E006BF43C5
Old Jan 08, 2013, 01:16 AM
mray is offline
Find More Posts by mray
USA, AZ, Buckeye
Joined Feb 2010
Shock absorbing strut set-
http://www.hobbyking.com/hobbyking/s...dProduct=11300
buddy code: http://www.hobbyking.com/buddy.asp?c...7-ABAA30D442C7
Body Support:
http://www.hobbyking.com/hobbyking/s...dProduct=14180
Buddy Code: http://www.hobbyking.com/buddy.asp?c...5-FADF0CAB6D20
mray is offline Find More Posts by mray
Old Jan 08, 2013, 01:05 PM
Molotov is offline
Find More Posts by Molotov
Joined Aug 2008
Turnigy nano-tech 6000mah 3S 25~50C Lipo Pack Save US$: 10.74
Molotov is offline Find More Posts by Molotov
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 11 Feb 15, 2014 03:26 PM
Discussion what do you use as umbilical cable to your ROV? fluxno ROV - Remotely Operated Vehicles 3 Apr 01, 2011 10:46 AM
Discussion Do you wish (When you started) there were as many choices HX3D014 Electric Heli Talk 0 Jan 09, 2007 04:40 AM
Cascade Charger that will charge your battery automatically as many packs as you wish cadetman Batteries and Chargers 8 Feb 08, 2005 02:12 AM
