This thread is privately moderated by obuggy, who may elect to delete unwanted replies.
Old Dec 20, 2012, 04:51 AM
Joined Aug 2012
H-KING 10A Fixed Wing Brushless Speed Controller
http://www.hobbyking.com/buddy.asp?c...0-600F280BAB9D
Hobby King GT-2 2.4Ghz Receiver 3Ch
http://www.hobbyking.com/buddy.asp?c...C-F2D77FCFC14E
Linkage Stopper D1.8mm (10pcs)
http://www.hobbyking.com/buddy.asp?c...D-9CF14B26A6DA
Plastic Pin Horn (10pcs)
http://www.hobbyking.com/buddy.asp?c...F-CB30455F89DA
30CM Servo Lead Extention (JR) with hook 26AWG (5pcs/bag)
http://www.hobbyking.com/buddy.asp?c...6-78A0CD9163B0
ZIPPY Flightmax 1000mAh 2S1P 20C
http://www.hobbyking.com/buddy.asp?c...5-937F36415B59
Turnigy 2mm Heat Shrink Tube - BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?c...D-D203E009F55C
Turnigy 2mm Heat Shrink Tube - RED (1mtr)
http://www.hobbyking.com/buddy.asp?c...C-DF4B3535DADF
2mm Gold Connectors 10 pairs (20pc)
http://www.hobbyking.com/buddy.asp?c...6-CBA444538A8A
Portable Battery Powered Soldering Iron 8W
http://www.hobbyking.com/buddy.asp?c...B-53B16B6236F7
Turnigy AA Ni-ZN 1500mAh High Voltage (ready to use)
http://www.hobbyking.com/buddy.asp?c...2-E8F2387A9CFF
mapesk is offline Find More Posts by mapesk
Old Dec 20, 2012, 06:23 AM
Greece, Attica, Athens
Joined May 2011
Find my codes here: http://hk.rc-international.info/swarm/anlucas (valid until January 03, 2013)
Turnigy 5A (8-40v) SBEC for Lipo Save US$: 0.74
Carbon Fiber Round Tube 250x12x10mm Save US$: 0.21
Dr Mad Thrust 3000kv 1300w 70mm EDF Inrunner Motor 4s version (29mm) Save US$: 1.14
Black Aluminum Motor Heat Sink (36mm Diameter Inrunner) Save US$: 0.60
Browse buddycodes on RC International now with your Android mobile phone or tablet with RC International unoffcial Hobbyking app
anlucas is offline Find More Posts by anlucas
Old Dec 20, 2012, 01:58 PM
Belgium, Brussels
Joined Jul 2010
Find my codes here: http://hk.rc-international.info/swarm/halford (valid until January 03, 2013)
Turnigy H.A.L. Quadcopter Dome Save US$: 2.43
2.5mm F:2.0 Turnigy Micro FPV Camera Lense Save US$: 1.94
2.1mm F:2.0 Turnigy Micro FPV Camera Lense Save US$: 2.32
Metal Push Rods M2xL300 (10pcs/set) Save US$: 0.70
Twisted 60CM Servo Lead Extention (Futaba) 22AWG (5pcs/set) Save US$: 0.55
Twisted 80CM Servo Lead Extention (Futaba) 22AWG (5pcs/set) Save US$: 1.07
Clip On Soft Ferrite Rings (5pc) Save US$: 0.59
3.3V 3A UBEC - 2~5S Lipoly (6-23v) Save US$: 0.36
JWT 2 Pin Pre-wired 100mm fly lead - 1pcs/bag Save US$: 0.05
DIY PCB Bread Board 27.5x17mm (4pcs/bag) Save US$: 0.28
12V 4.5A UBEC 2-5S Lipoly (12-23v) Save US$: 2.94
5030 (green) Three Blade Propeller (ABS) (3pc) Save US$: 0.31
5030R (green) Three Blade Propeller (ABS) (3pc) Save US$: 0.21
Halford is offline Find More Posts by Halford
Old Dec 21, 2012, 01:26 AM
lex800's Avatar
Russia, Saint Petersburg, g. Sankt-Peterburg
Joined Jun 2010
Find my codes here: http://hk.rc-international.info/swarm/lex800 (valid until January 04, 2013)
Glass Fiber Cloth 450x1000mm 48g/m2 (Ultra Thin) Save US$: 0.19
Glass Fiber Cloth 450x1000mm 18g/m2 (Super Thin) Save US$: 0.29
lex800 is offline Find More Posts by lex800
Old Dec 21, 2012, 05:37 PM
Joined Sep 2010
lipo 5000 mah 6s 40c, multii and megapirate controller, 50x30 props, blue velcro
http://hk.rc-international.info/swarm/whiskey29
L-C Power Filter for FPV A/V Systems
8040 SF Props 2pc Standard Rotation/2 pc RH Rotation (Flouro Yellow)
20CM Male to Male Servo Lead (JR) 26AWG (10pcs/set)
Turnigy 5000mAh 6S 40C Lipo Pack
Polyester Velcro Peel-n-stick adhesive side V-STRONG (1mtr)
Ultrasonic Module HC-SR04 Arduino
Multiwii and Megapirate AIO Flight Controller w/FTDI (ATmega 2560)
They dont last long
whiskey29 is offline Find More Posts by whiskey29
Old Dec 22, 2012, 01:10 AM
Joined Sep 2012
Find my codes here: http://hk.rc-international.info/swarm/lucky3448 (valid until January 05, 2013)
Clear Foam Glue (Medium Cure) - Small 20g Save US$: 0.08
Turnigy Accucel-6 50W 6A Balancer/Charger w/ accessories Save US$: 1.34
laxmikant is offline Find More Posts by laxmikant
Old Dec 22, 2012, 01:22 AM
James not bond
jy0933's Avatar
Joined May 2012
Find my codes here: http://hk.rc-international.info/swarm/jxl (valid until December 31, 2012)
Turnigy EasyMatch Park300 Series - Replacement Shaft Save US$: 0.12
Atmel Atmega Socket Firmware Flashing Tool Save US$: 1.21
jy0933 is offline Find More Posts by jy0933
Old Dec 22, 2012, 09:49 AM
Joined Aug 2011
Ball and roller link 4.8x2x18mm (10pcs/set)
http://www.hobbyking.com/buddy.asp?c...3-4D2A177F283C
Silicon fuel pipe (1 mtr) Yellow 6x3mm
http://www.hobbyking.com/buddy.asp?c...2-E6C03F3F9334
Large Fuel Clunk with filter for Gas/Turbine powered models
http://www.hobbyking.com/buddy.asp?c...A-2359B4EA70D9
Fuel Vent Through Hull/Tank - Twin Pack
http://www.hobbyking.com/buddy.asp?c...5-E3C70D7CC722
Air Line/Fuel Line/ Cable Tidy Clip for 6mm OD (10pc)
http://www.hobbyking.com/buddy.asp?c...9-CA6B56D06469
Insta-Set CA Accelerator 2. oz
http://www.hobbyking.com/buddy.asp?c...A-2F2393B06E70
dudy201 is offline Find More Posts by dudy201
Old Dec 23, 2012, 02:11 PM
teamwork, do it my way!
Dubai, UAE
Joined Jun 2007
Hi All,
Hope you all have a VERY MERRY XMAS....may all your landings be good ones
Find my codes here: http://hk.rc-international.info/swarm/andy (valid until January 06, 2013)
Master Airscrew propeller 16x10 Save US$: 11.55
Master Airscrew propeller 16x10 (Pusher) Save US$: 3.08
WW2/Classic Era Pilot 66mmx67mmx37 (Green) Save US$: 1.33
Turnigy Aerodrive SK3 5045/5055 Series Replacement Ball Bearing Set (3pcs/bag) Save US$: 1.21
Turnigy Aerodrive SK3 5055 Series Replacement Shaft Set Save US$: 1.37
Turnigy Piston Stopper Save US$: 0.46
90mm (3.5 inch) Lightweight Alloy Scale Wheel Assembly (2pc) Save US$: 1.09
Nylon Wing Bolt M6x30 (10pcs/bag) Save US$: 0.30
Cathurga is offline Find More Posts by Cathurga
Old Dec 24, 2012, 01:21 AM
Mr. 1 Post
stripe157's Avatar
West Texas
Joined Nov 2008
Turnigy 1300
Here's one some of you may find useful, a Turnigy 1300 mAh 3S 25C battery, and unlike most of the 1300s right now, its actually in stock. Use the code to pay $9.27.
http://www.hobbyking.com/buddy.asp?c...6-285E6636B530
stripe157 is offline Find More Posts by stripe157
Old Dec 24, 2012, 03:37 AM
Vienna calling...
Donaldsneffe's Avatar
Österreich, Wien
Joined Aug 2010
All my buddy-codes on RCSearch.info
Hobby 6mm Masking Tape
$0.73*
hexTronik 2 gram Brushless Outrunner 7700kv
$7.47* (buddy price -5%, -$0.38)
Donaldsneffe is offline Find More Posts by Donaldsneffe
Old Dec 24, 2012, 11:28 AM
soebhemo's Avatar
jakarta
Joined May 2010
Extra Codes, You can save 14.8% for all of this products with:http://rc-buddy.com/user/bhemo! Codes from RC-Buddy.com
Silicon fuel pipe (1 mtr) Yellow for Gas/Nitro Engines 4x2.5mm
Savings: 73.15 % / $1.09
Price after: $0.40
Weight: 25 g
JXF 16x6 / 406 x 153mm Poly Composite propeller
Savings: 84.31 % / $2.15
Price after: $0.40
Weight: 119 g
Quanum 2.4Ghz Telemetry System (Volt/Amp/Temp/mAh) V3.0
Savings: 7.26 % / $3.63
Price after: $46.36
Weight: g
Twisted 22AWG servo wire 1mtr (R/B/W) 22AWG
Savings: 55.83 % / $0.67
Price after: $0.53
Weight: 15 g
Savings: 35.94 % / $0.69
Price after: $1.23
Weight: 32 g
Bumper and Susp.Arm Holder - A3015
Savings: 28.07 % / $0.48
Price after: $1.23
Weight: 41 g
soebhemo is offline Find More Posts by soebhemo
Old Dec 24, 2012, 04:46 PM
2jzgtevvti's Avatar
Thailand, Bangkok
Joined Oct 2005
Save Money
2jzgtevvti is offline Find More Posts by 2jzgtevvti
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 5 May 18, 2011 01:38 PM
Discussion what do you use as umbilical cable to your ROV? fluxno ROV - Remotely Operated Vehicles 3 Apr 01, 2011 10:46 AM
Discussion Do you wish (When you started) there were as many choices HX3D014 Electric Heli Talk 0 Jan 09, 2007 04:40 AM
Cascade Charger that will charge your battery automatically as many packs as you wish cadetman Batteries and Chargers 8 Feb 08, 2005 02:12 AM
