This thread is privately moderated by obuggy, who may elect to delete unwanted replies.
Old Oct 11, 2012, 06:12 PM
If it has wings it will fly...
United Kingdom, England, Birmingham
Joined Mar 2011
Extra Codes, You can save -44.29% for all of this products with:http://rc-buddy.com/user/ckleanth! Codes from RC-Buddy.com
160W Dremel Style Rotary hand-tool w/ 33pc set 230V
Savings: 16.29 % / $2.41
Price after: $12.38
Weight: 970 g
H35 Standoff Motor Mount
Savings: -296.79 % / $-9.26
Price after: $12.38
Weight: 21 g
Turnigy 30A BRUSHED ESC
Savings: -58.11 % / $-4.55
Price after: $12.38
Weight: 39 g
ckleanth is offline Find More Posts by ckleanth
Old Oct 11, 2012, 07:35 PM
That's a funny word
NE Ohio
Joined Apr 2003
Find my codes here: http://hk.rc-international.info/swarm/gulio (valid until October 20, 2012)
Propeller Adapter (Colet Type) 4MM Save US$: 0.44
Turnigy 16mm Flywheel Removal Tool Save US$: 1.04
Plastic E-Prop Spinners w/ Propeller 9inch Save US$: 2.95
Plastic E-Prop Spinners w/ Propeller 8inch Save US$: 1.22
Plastic E-Prop Spinners w/ Propeller 7inch Save US$: 0.97
C-Clip Ring Plier 4 in 1 set Save US$: 0.67
APC style propeller 13x4-E Save US$: 0.53
APC style propeller 14x7-E Save US$: 0.53
TGS Sport 12x8E Precision propeller Save US$: 1.98
TGS Sport 13x8E Precision propeller Save US$: 2.72
Master Airscrew propeller 13x8.5 Save US$: 1.43
Master Airscrew propeller 12x8 Save US$: 1.32
6-32 Blind Nuts (10pcs/bag) Save US$: 0.16
Prop adapter w/ Alu Cone 5/16x24-M6mm shaft (Grub Screw Type) Save US$: 2.78
Prop adapter to suit 6.0mm motor shaft (collet) Save US$: 1.42
Prop adapter w/ Alu Cone M8x6mm shaft (Grub Screw Type) Save US$: 0.60
Browse buddycodes on RC International now with your Android mobile phone or tablet with RC International unoffcial Hobbyking app
gulio is offline Find More Posts by gulio
Old Oct 11, 2012, 09:21 PM
Joined Sep 2011
http://www.hobbyking.com/buddy.asp?c...0-8FC7646DFCA7,
decathlon pnp USA warehouse
2000yamahar6 is offline Find More Posts by 2000yamahar6
Old Oct 11, 2012, 09:29 PM
Canada, BC, Terrace
Joined Feb 2010
Find my codes here: http://hk.rc-international.info/swarm/fivezigen (valid until October 23, 2012)
TL-242 Thread Locker and Sealant Medium Strength Save US$: 0.17
Replacement Pinion Gear 5mm - 18T Save US$: 0.60
Turnigy A-6-10 200W Balance charger and discharger Save US$: 3.95
FiveZigen is offline Find More Posts by FiveZigen
Old Oct 12, 2012, 12:31 AM
flyboy1001e's Avatar
Nelson B.C. Canada
Joined Feb 2003
Sky 500 Ultra Micro Glider parts
Find my codes here: http://hk.rc-international.info/swarm/flyboy1001e (valid until October 22, 2012)
Sky 500 Ultra Micro Glider - Replacement Wire Set Save US$: 3.90
Sky 500 Ultra Micro Glider - Replacement Fuselage Save US$: 6.90
Sky 500 Ultra Micro Glider - Replacement Vertical Tail and Horizonal Tail Set Save US$: 4.20
Sky 500 Ultra Micro Glider - Replacement Main Wing Save US$: 7.05
flyboy1001e is offline Find More Posts by flyboy1001e
Old Oct 12, 2012, 02:02 AM
United States, CT
Joined Mar 2011
HK price codes (good until 14 days from 10/9)
USBasp AVR Programming Device for ATMEL proc, $4.15:
http://www.hobbyking.com/buddy.asp?c...0-4230E98B2C1D
5.6mm x 15mm M3 Nylon Tapped Spacer (10pc), $1.38:
http://www.hobbyking.com/buddy.asp?c...B-87EBC5A93AAD
5.6mm x 30mm M3 Nylon Tapped Spacer (10pc), $1.56:
http://www.hobbyking.com/buddy.asp?c...1-85B8327F670D
M3x8 Nylon Screws (10pcs/bag), $0.58:
http://www.hobbyking.com/buddy.asp?c...B-5C7F2329661B
5.6mm x 21mm M3 Nylon Threaded Spacer (10pc), $1.34:
http://www.hobbyking.com/buddy.asp?c...8-B5A3CF2F19D1
5.6mm x 36mm M3 Nylon Threaded Spacer (10pc), $1.51:
http://www.hobbyking.com/buddy.asp?c...B-C5C4E72BB0AA
M3 Nylon Nut (10pcs/bag), $0.52:
http://www.hobbyking.com/buddy.asp?c...E-B99E8473892D
10CM Male to Male Servo Lead (JR) 26AWG (10p, $3.03:
http://www.hobbyking.com/buddy.asp?c...9-74E5F31530B6
2mm Gold Connectors 10 pairs (20pc), $1.32:
http://www.hobbyking.com/buddy.asp?c...2-E6173E221692
5.6mm x 14mm M3 Nylon Threaded Spacer (10pc), $1.19:
http://www.hobbyking.com/buddy.asp?c...2-422C8A34D8DD
M3x12mm Nylon Screws (10pcs/bag), $0.70:
http://www.hobbyking.com/buddy.asp?c...4-0FC4CA562E79
Simple Prop Balancer, $0.99:
http://www.hobbyking.com/buddy.asp?c...E-1776B9C9ABF4
Turnigy 5mm Heat Shrink Tube - RED, $0.06:
http://www.hobbyking.com/buddy.asp?c...8-4B1C601EDA5C
adrenahelin is offline Find More Posts by adrenahelin
Old Oct 12, 2012, 06:30 AM
Crash Test Pilot
Levictus's Avatar
United States, NC, Raleigh
Joined Jul 2012
Valid till Oct 20th
My buddy codes:
Turnigy plush 40a esc
http://www.hobbyking.com/buddy.asp?c...3-879FFCAD1A54
Turnigy plush 30a esc
http://www.hobbyking.com/buddy.asp?c...5-E722E4B13F43
Linkage stopper
http://www.hobbyking.com/buddy.asp?c...C-39B5D6046BDD
Nylon T connectors (Dean's copy)
http://www.hobbyking.com/buddy.asp?c...4-61951E5295B0
Corona DS238MG Digital Metal Gear Servo 4.6kg/ 22g/ 0.14sec
http://www.hobbyking.com/buddy.asp?c...9-E60F5D0A038C
3.5mm Male/Female bullet
http://www.hobbyking.com/buddy.asp?c...1-F0B050682123
Levictus is offline Find More Posts by Levictus
Old Oct 12, 2012, 08:35 AM
United States, MO, Fenton
Joined Jan 2012
Alloy DPS Series 70mm 10-Blade EDF unit with 2200kv Motor - 1900watt (6s)
http://www.hobbyking.com/buddy.asp?c...0-7CD4E1F49FAC
Saves $6.38
Turnigy HV SBEC 5A Switch Regulator (8-42V input)
http://www.hobbyking.com/buddy.asp?c...0-79A6BC4F3C52
Saves $1.01
Fentonflyers is offline Find More Posts by Fentonflyers
Old Oct 12, 2012, 10:00 AM
Teokharis's Avatar
Italia, Campania, Napoli
Joined Nov 2011
Fiberglass parts for Beatle 116b and more
Find my codes here: http://hk.rc-international.info/swarm/uzzi (valid until October 26, 2012)
Main Chassis Bottom Plate (glass fiber) - A2003T and 110BS Save US$: 3.61
Replacement Shell w/ Decal - 118B (Red) Save US$: 1.32
1/16 Brushless 4WD Monster Beatle Shell - 110BS Save US$: 2.45
6inch Quick Release Bar Clamp Tool Save US$: 0.35
5inch Ratchet Clamp Tool Save US$: 0.34
Rear Shock Tower (glass fiber) w/hardware - 110BS, A2029 and A2035 Save US$: 1.30
Front Shock Tower (glass fiber) - 110BS, A2029 and A2035 Save US$: 1.09
Teokharis is offline Find More Posts by Teokharis
Old Oct 12, 2012, 11:26 AM
Luck is my skill
queadlunnrau's Avatar
On Earth
Joined Jun 2009
Rotating retract set for Durafly 1100mm F4-U Corsair - Save $1.64
TURNIGY Plush 10amp 9gram Speed Controller - Save $1.88
queadlunnrau is online now Find More Posts by queadlunnrau
Old Oct 12, 2012, 02:45 PM
Sweden, Stockholm
Joined Jul 2012
Turnigy 9X LCD Backlight Kit - White (DIY)
[S]$4.99[/S] $3.66* (buddy price 27%, -$1.33)
5030 Propellers (Red) - 3xCW and 3xCCW - 6pcs per bag
[S]$3.49[/S] $2.68* (buddy price 23%, -$0.81)
Micro Control Rod Keeper (10mm long - 10pcs)
[S]$1.12[/S] $0.97*
XeCutor is offline Find More Posts by XeCutor
Old Oct 12, 2012, 08:13 PM
Joined Jan 2012
rcg 30cc gas motor, turnigy plush 40A and more
RCG 30CC gas engine $173.03 : http://www.hobbyking.com/buddy.asp?c...1-B3395F0FC5B8
CNC alloy servo arm long (futaba) $3.03 : http://www.hobbyking.com/buddy.asp?c...0-CC2448376D2A
12V electric fuel pump for gas models $9.92 : http://www.hobbyking.com/buddy.asp?c...B-3C8D93863540
Turnigy plush 40A speed control $17.99 : http://www.hobbyking.com/buddy.asp?c...3-BC99ADA62473
Pivot & Round Hinges 4.5x67mm (10pcs) $1.25 : http://www.hobbyking.com/buddy.asp?c...0-D4076FA3BDC2
Aluminium Prop Spinner 76mm / 3.0inch diameter $7.89 : http://www.hobbyking.com/buddy.asp?c...F-EB63979B38CE
CNC Alloy Double Servo Arm X-Long (Futaba) $3.51 : http://www.hobbyking.com/buddy.asp?c...C-8308A850FB28
Large Bore/Capacity Gas Filters (Grey) (2pcs) $4.96 : http://www.hobbyking.com/buddy.asp?c...6-48CFE5C44968
Resin Civilian Pilot 90mmx120mmx56 Large Scale $2.42 : http://www.hobbyking.com/buddy.asp?c...A-08BEA498E0CB
Alloy Fuel Tank Vent for Gas Models (Small Bore) $2.42 : http://www.hobbyking.com/buddy.asp?c...6-E141B2DF692D
buddy codes valid till 24/10/2012
bigdog21782 is offline Find More Posts by bigdog21782
Old Oct 12, 2012, 10:08 PM
United States, PA, Bucks
Joined Oct 2011
Super Gold Plus Odorless CA 1. oz (Foam Safe) (USA Warehouse)
[S]$9.66[/S] $7.36* (buddy price 24%, -$2.3)
Wing Tape 45mic x 45 mm x 100m ( Wide - Black)
[S]$1.58[/S] $1.01* (buddy price 36%, -$0.57)
Wing Tape 45mic x 24 mm x 100m (Narrow - Orange)
[S]$1.05[/S] $0.67* (buddy price 36%, -$0.38)
C10 Micro brushless outrunner 2900kv
[S]$10.79[/S] $10.12*
HobbyKing Cell Key - 6s Lipoly Cell checker
[S]$2.99[/S] $2.56* (buddy price 14%, -$0.43)
Wing Tape 45mic x 45 mm x 100m ( Wide - Orange)
Linkage Stopper M3x2xL11.2mm (10pcs/set)
[S]$1.52[/S] $0.97* (buddy price 36%, -$0.55)
Cyanoacrylate (Super Glue) Single Pack
[S]$0.59[/S] $0.47*
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC)
[S]$1.59[/S] $1.40* (buddy price 12%, -$0.19)
NTM Prop Drive 28-36 750KV / 265W (USA Warehouse)
[S]$16.12[/S] $14.70* (buddy price 9%, -$1.42)
Hobbyking Model Aircraft Stand (small)
[S]$4.95[/S] $3.86*
Floater-Jet Replacement Rudder
[S]$2.08[/S] $1.95*
Floater-Jet Replacement Horizontal Stabalizer
[S]$2.73[/S] $2.56*
Wing Tape 45mic x 24mm x 100m (Narrow - Black)
Hobbyking SK450 Replacement Arm Set - Bright Green (2pcs/bag)
[S]$6.56[/S] $5.00*
Carbon Fiber Rod (solid) 2.5x750mm
[S]$1.35[/S] $0.48* (buddy price 64%, -$0.87)
Fatshark 3p Molex/3p JST CCD Connection Cable
[S]$0.76[/S] $0.48*
Carbon Fiber Rod (solid) 1.8x750mm
[S]$1.15[/S] $0.42* (buddy price 63%, -$0.73)
Carbon Fiber Square Tube 750x3mm
[S]$1.49[/S] $0.65* (buddy price 56%, -$0.84)
Carbon Strip 1x3x750mm (5pcs/set)
[S]$4.09[/S] $2.62* (buddy price 36%, -$1.47)
Carbon Fiber Rod (solid) 2.0x750mm
Hobbyking 12 Point snap knives (10pcs/set)
[S]$0.99[/S] $0.67*
Ex-Long CA Ex-Tips (1pc)
[S]$0.23[/S] $0.14* (buddy price 39%, -$0.09)
Carbon Fiber Rod (solid) 1.5x750mm
[S]$0.99[/S] $0.25* (buddy price 75%, -$0.74)
Turnigy Utility Bag - 380x230x275mm
[S]$12.99[/S] $11.23* (buddy price 14%, -$1.76)
Carbon Strip 1x6x750mm (5pcs/set)
[S]$5.98[/S] $3.84* (buddy price 36%, -$2.14)
All my buddy-codes here
Milktruck is offline Find More Posts by Milktruck
Old Oct 13, 2012, 03:24 AM
looking up down under
scruffy1's Avatar
Australia, NSW, Fairlight
Joined Feb 2008
oops !
see below
scruffy1 is online now Find More Posts by scruffy1
Old Oct 13, 2012, 03:25 AM
scruffy1's Avatar
Joined Feb 2008
Mini Plug Extention for Micro Battery 10cm (5pcs/bag) (AUS Warehouse)
no, not $1.99 ! $0.70*
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 5 May 18, 2011 01:38 PM
Discussion what do you use as umbilical cable to your ROV? fluxno ROV - Remotely Operated Vehicles 3 Apr 01, 2011 10:46 AM
Discussion Do you wish (When you started) there were as many choices HX3D014 Electric Heli Talk 0 Jan 09, 2007 04:40 AM
Cascade Charger that will charge your battery automatically as many packs as you wish cadetman Batteries and Chargers 8 Feb 08, 2005 02:12 AM
