United States, FL, St Petersburg
Joined Nov 2010
My buddy code
Find my codes here: http://hk.rc-international.info/swarm/shaneh (valid until October 22, 2012)
JST-XH 2S Wire Extension 20cm (10pcs/bag) Save US$: 0.41 ![]() Turnigy High Density R/C LED Flexible Strip-White (1mtr) Save US$: 1.87 ![]() High Density R/C LED Flexible Strip-Yellow (1mtr) Save US$: 5.55 ![]() Luminescent (Glow in the dark) Self Adhesive Film - 1200mm x 200mm Save US$: 0.64 Turnigy High Density R/C LED Flexible Strip-Green (1mtr) Save US$: 0.62 ![]() Turnigy High Density R/C LED Flexible Strip-Red (1mtr) Save US$: 1.69
United States, SC, Myrtle Beach
Joined Jun 2011
Turnigy 5000mah 40c 6s battery - USA warehouse -
$59.59 !!!!!!!! http://www.hobbyking.com/buddy.asp?c...5-4F72A830FA88 |
United States, CA, Rocklin
Joined Aug 2012
If you need any 3mm locknuts, now is the time to stock up!!
http://www.hobbyking.com/buddy.asp?c...4-1372D95F5546
Find my codes here: http://hk.rc-international.info/swarm/shaneh (valid until October 23, 2012)
JST-XH 2S Wire Extension 20cm (10pcs/bag) Save US$: 0.41 ![]() Turnigy High Density R/C LED Flexible Strip-White (1mtr) Save US$: 1.87 ![]() High Density R/C LED Flexible Strip-Yellow (1mtr) Save US$: 5.55 ![]() Luminescent (Glow in the dark) Self Adhesive Film - 1200mm x 200mm Save US$: 0.64 Turnigy High Density R/C LED Flexible Strip-Green (1mtr) Save US$: 0.62 ![]() Turnigy High Density R/C LED Flexible Strip-Red (1mtr) Save US$: 1.69 ![]() Servo Covers Save US$: 1.34
Joined Dec 2011
Hobbyking YEP 80A (2~6S) SBEC Brushless Speed Controller
http://www.hobbyking.com/buddy.asp?c...5-71DA88A5AF44 Turnigy High-End Fiberglass Canopy for Trex 500 Pro ![]() http://www.hobbyking.com/buddy.asp?c...0-A3182CE2A918 10CM Male to Male Servo Lead (JR) 26AWG (10pcs/set) ![]() http://www.hobbyking.com/buddy.asp?c...8-2BF264508AAF Servo Terminals (Futaba) Gold Plated (10pairs/set) http://www.hobbyking.com/buddy.asp?c...F-5C7B2DE1C7D1 Turnigy 4.7mm Ball End Reamer ![]() http://www.hobbyking.com/buddy.asp?c...5-2154E78A7E40 Turnigy Swashplate Tool (8mm) http://www.hobbyking.com/buddy.asp?c...1-4A762EAC044F Turnigy R/C Helicopter Pitch Gauge 450 size & Above (actually too big for 450) ![]() http://www.hobbyking.com/buddy.asp?c...C-AEB8DF09458B Neon Yellow Fiberglass Horizontal/Vertical Fins Trex 500 XL (1.5cm longer than standard) ![]() http://www.hobbyking.com/buddy.asp?c...9-8528605672EA |
Joined May 2012
These codes end the 22nd of October!!!
Front Shock set (2pc) - 110BS, A2003T, A2029 ![]() http://www.hobbyking.com/buddy.asp?c...3-EFAFA0D2DE92 You pay $3.15 Slow Fly Electric Prop 11x4.7SF (4 pc - Green) ![]() http://www.hobbyking.com/buddy.asp?c...9-4A09D2A473DF You pay $3.58 Flat 26AWG servo wire 1mtr (R/O/B) ![]() http://www.hobbyking.com/buddy.asp?c...F-179CDBF3D356 You pay $0.24 Flat 22AWG servo wire 1mtr (R/B/Y) ![]() http://www.hobbyking.com/buddy.asp?c...5-4653233342EA You pay $0.44 Front Upper Suspension arms (left/right) - 110BS, A2003 and A2029 ![]() http://www.hobbyking.com/buddy.asp?c...9-02E38B56506C You Pay $0.30 Front Dogbone - 110BS ![]() http://www.hobbyking.com/buddy.asp?c...4-87C815E752EE You pay $2.12 Front Upper Suspension Arm Pins - 110BS, A2003 and A2029 ![]() http://www.hobbyking.com/buddy.asp?c...2-EF9A9973B7B8 You pay $0.24 Front Upper Sus.arm Sleeve Spacer (4pc) - 110BS, A2003 and A2029 ![]() http://www.hobbyking.com/buddy.asp?c...3-3A60883D6628 You pay $0.24 Front Wheel Steering Arm & Mount Set 40mm (5sets) ![]() http://www.hobbyking.com/buddy.asp?c...9-BFECA846E4FB You pay $2.24 |
United States, TN, Memphis
Joined Dec 2011
Find my codes here: http://hk.rc-international.info/swarm/daniel (valid until October 20, 2012)
Turnigy nano-tech 2100mAh 2S1P 20C LiFePo4 Transmitter Pack Save US$: 3.98 6 x Parallel JST-PH Charge Lead for E-flite UMX Series 2S Lipoly Save US$: 1.85 Hobbyking YEP 45A (2~6S) SBEC Brushless Speed Controller Save US$: 8.03 Browse buddycodes on RC International now with your Android mobile phone or tablet with RC International unoffcial Hobbyking app
United Kingdom, England, Bristol
Joined Aug 2011
Extra Codes, You can save 5.01% for all of this products with:http://rc-buddy.com/user/simonchambers! Codes from RC-Buddy.com
Extra Codes, You can save 28.23% for all of this products ! Codes from RC-Buddy.com
| Thread Tools | |
| Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor | lrplin | Hot Online Deals | 5 | May 18, 2011 01:38 PM |
| Discussion what do you use as umbilical cable to your ROV? | fluxno | ROV - Remotely Operated Vehicles | 3 | Apr 01, 2011 10:46 AM |
| Discussion Do you wish (When you started) there were as many choices | HX3D014 | Electric Heli Talk | 0 | Jan 09, 2007 04:40 AM |
| Cascade Charger that will charge your battery automatically as many packs as you wish | cadetman | Batteries and Chargers | 8 | Feb 08, 2005 02:12 AM |
