This thread is privately moderated by obuggy, who may elect to delete unwanted replies.
Old Oct 05, 2012, 06:33 PM
jcarff is offline
Find More Posts by jcarff
United States, FL, Pensacola
Joined Jul 2012
My Buddy Codes
T-28 Funfighter - EPO 650mm (PNP) incl. High
http://www.hobbyking.com/buddy.asp?c...F-1ED5F0B78B7A
Turnigy nano-tech 1000mAh 4S 45~90C Lipo Pac
http://www.hobbyking.com/buddy.asp?c...1-D412C857C746
jcarff is offline Find More Posts by jcarff
Old Oct 05, 2012, 08:07 PM
folke190d is offline
Find More Posts by folke190d
Scratch build warbirds
Canada, NB, Beresford
Joined Mar 2011
New buddy codes from oct. 5th - 19th
Find my codes here: http://hk.rc-international.info/swarm/adam-p (valid until October 12, 2012)
Hobbyking DC-4S Balance Charger and Cell Checker 30w 2s~4s Save US$: 1.43
Turnigy Compact Re-buildable Fuel Filter Save US$: 0.49
Nose Art - "Miss Molly" (L/R sided) Save US$: 1.19
Fuel Dot D11xL12mm Save US$: 0.89
Futaba Servo Arm Set Save US$: 1.26
Turnigy LSD 4.8V 2300mAh Ni-MH Receiver Pack Save US$: 1.06
Turnigy LSD 6.0V 2300mAh Ni-MH Flat Receiver Pack Save US$: 2.05
Carbon Fiber Tube (hollow) 10x750mm Save US$: 1.27
Browse buddycodes on RC International now with your Android mobile phone or tablet with RC International unoffcial Hobbyking app
folke190d is offline Find More Posts by folke190d
Old Oct 05, 2012, 08:21 PM
orck is offline
Find More Posts by orck
Joined Aug 2004
Find my codes here: http://hk.rc-international.info/swarm/orck (valid until October 20, 2012)
Body Stiffener #3 (1pc/bag) - 260 and 26S Save US$: 0.41
Headlight Housing - Baja 260 and 260s (1 pair) Save US$: 1.95
12 LED Cluster - WHITE Save US$: 1.24
Heavy-Duty Beadlock Ring for Off-Road Wheel Baja 260 and 260s (2Pcs/Bag) Save US$: 1.99
Tail Wheel System. w/ Steering and Spring 40-90 Size Save US$: 0.14
Receiver Switch (3 plug) Save US$: 1.19
orck is offline Find More Posts by orck
Old Oct 05, 2012, 09:16 PM
Thirston is offline
Find More Posts by Thirston
United States, NC, Charlotte
Joined Jul 2012
PLUSH 10amp
Metal Gear Servos - Turnigy MG90S
7x6 E APC
Low Voltage Alarm 2S-3S
Thirston is offline Find More Posts by Thirston
Old Oct 05, 2012, 11:36 PM
xzd is offline
xzd
Find More Posts by xzd
xzd
Joined Jul 2004
Hobbyking YEP 120A HV (4~14S) Brushless Speed Controller (OPTO) for only $78.02! save $12.03!
http://www.hobbyking.com/buddy.asp?c...D-8078D9926AC1
xzd is offline Find More Posts by xzd
Old Oct 06, 2012, 08:41 AM
Chimango is offline
Find More Posts by Chimango
Joined Aug 2006
Codes for Upgrade and spare parts for Monster beetle an compatible cars
Aluminium Front Upper Suspension Arms (2pcs/bag) - A2003T, 110BS, A2029 and A2035
http://www.hobbyking.com/buddy.asp?c...D-E014E0ECD39F
Front Upper/Lower Suspension Arm Holder - 110BS, A2003T, A2029 and A2035
http://www.hobbyking.com/buddy.asp?c...E-703AF9C528F4
Aluminum Front Steering Knuckles (2pcs/bag) - A2003T, 110BS, A2029 and A2035
http://www.hobbyking.com/buddy.asp?c...2-427F06E4DAEA
CVD Shafts - 110BS
http://www.hobbyking.com/buddy.asp?c...4-FA7422B6D575
Front Shock Tower (glass fiber) - 110BS, A2029 and A2035
http://www.hobbyking.com/buddy.asp?c...D-F55558C1CE91
Bumper - 110BS and A2003
http://www.hobbyking.com/buddy.asp?c...E-3243738C3B25
2pc Motor Pinion (15T) - 110BS, A2029 and A2035
http://www.hobbyking.com/buddy.asp?c...0-CFAEBA9FC4FA
Spur Gear - 110BS, A2029 and A2035
http://www.hobbyking.com/buddy.asp?c...5-536FB3CC741C
Rear Shock Tower (glass fiber) w/hardware - 110BS, A2029 and A2035
http://www.hobbyking.com/buddy.asp?c...6-A03FCB3ADD82
Aluminum Swaybar Backplate (2pcs/bag) - A2003T, 110BS, A2029 and A2035
http://www.hobbyking.com/buddy.asp?c...D-B7BC1333AACD
Aluminum Lower Suspension Arm Bracket (front/rear) - A2003T
http://www.hobbyking.com/buddy.asp?c...4-9AFFA032CE91
Drive gear w/outdrive - 110BS, A2003T, A2029 and A2035
http://www.hobbyking.com/buddy.asp?c...F-EF4E22BEB2B6
Diff.Pinion Gear B 2(long) and Outdrive - 110BS, A2003T, A2029 and A2035
http://www.hobbyking.com/buddy.asp?c...2-49ADDB6E5DBB
Front Aluminum Shocks (1pair/bag) - 110BS, A2003T, A2029 and A2035
http://www.hobbyking.com/buddy.asp?c...D-A94BC60FE5C4
Rear Aluminum Shocks (2pcs/bag) - 110BS, A2003T, A2029 and A2035
http://www.hobbyking.com/buddy.asp?c...4-33208F728DFD
Aluminum Rear Hub Carrier (2pcs/bag) - A2003T, 110BS, A2029 and A2035
http://www.hobbyking.com/buddy.asp?c...D-30F3CFD50E57
Aluminum Front Carriers (2pcs/bag) - A2003T, 110BS, A2029 and A2035
http://www.hobbyking.com/buddy.asp?c...B-894B16622258
Aluminum Front Lower Suspension Arm (2pcs/bag) - 110BS
http://www.hobbyking.com/buddy.asp?c...B-AA143F2D7286
Chimango is offline Find More Posts by Chimango
Old Oct 06, 2012, 09:25 AM
seojeff is offline
Find More Posts by seojeff
seojeff's Avatar
United States, GA, Atlanta
Joined Aug 2011
Find my codes here: http://hk.rc-international.info/swarm/seojeff (valid until October 10, 2012)
Nylon Screws 6x60mm (10pcs) Save US$: 0.32
Nylon and Pinned Hinge 26.5x36 (10pcs/bag) Save US$: 0.77
HXT 6.9kg / 39.2g / .16sec Twin bearing servo Save US$: 0.11
TURNIGY Plush 80A w/ UBEC Speed Controller Save US$: 4.63
60CM Servo Lead Extention (JR) with hook 26AWG (5pcs/bag) Save US$: 0.90
Twisted 80CM Servo Lead Extention (Futaba) 22AWG (5pcs/set) Save US$: 1.09
Futaba Y Servo Lead 30cm Length (5pcs/bag) Save US$: 1.20
-female-polyquest-4s-10cm-113351]Male JST-XH [-] Female Polyquest 4S 10cm (5pcs/bag) Save US$: 0.49
WireLabels - servo wire label heatshrink (14mm x 1m) Save US$: 0.61
Turnigy Aerodrive SK3 5045 Series Replacement Shaft Set Save US$: 1.34
seojeff is offline Find More Posts by seojeff
Old Oct 07, 2012, 06:51 AM
gordonnora is online now
Find More Posts by gordonnora
United States, PA, Easton
Joined Feb 2010
I don't get it....Why keep giving all the codes?
gordonnora is online now Find More Posts by gordonnora
Old Oct 07, 2012, 07:32 AM
daddoo is offline
Find More Posts by daddoo
Joined Mar 2010
Extra Codes, You can save 23.71% for all of this products with:http://rc-buddy.com/user/MC! Codes from RC-Buddy.com
Neon Yellow Fiberglass Horizontal/Vertical Fins Trex 250
Savings: 23.71 % / $0.83
Price after: $2.67
Weight: 17 g
daddoo is offline Find More Posts by daddoo
Old Oct 07, 2012, 07:35 AM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
StarHopper44 is offline Find More Posts by StarHopper44
Old Oct 07, 2012, 07:39 AM
hakank is offline
Find More Posts by hakank
Sweden (┼kersberga)
Joined Nov 2004
You earn points = $ to be used in the shop if the codes are being used of someone.
hakank is offline Find More Posts by hakank
Old Oct 07, 2012, 07:52 AM
Hammer is online now
Find More Posts by Hammer
United States, NC, Harrisburg
Joined Mar 1999
Voltage booster
Use 1s LiPo to power receiver and servos.
Regular price 2.99
Buddy price .94
http://www.hobbyking.com/buddy.asp?c...2-43CF705B4E23
Hammer is online now Find More Posts by Hammer
Old Oct 07, 2012, 09:14 AM
Stefan_Go is online now
Find More Posts by Stefan_Go
Stefan_Go's Avatar
Finland, Pirkanmaa, Valkeakoski
Joined Sep 2012
Not to forget, that the buyer gets a discount when using the codes.
Stefan_Go is online now Find More Posts by Stefan_Go
Old Oct 07, 2012, 11:21 AM
Levictus is offline
Find More Posts by Levictus
Crash Test Pilot
Levictus's Avatar
United States, NC, Raleigh
Joined Jul 2012
My buddy codes, valid till Oct 20th
My buddy codes:
Turnigy plush 40a esc
http://www.hobbyking.com/buddy.asp?c...3-879FFCAD1A54
Turnigy plush 30a esc
http://www.hobbyking.com/buddy.asp?c...5-E722E4B13F43
Linkage stopper
http://www.hobbyking.com/buddy.asp?c...C-39B5D6046BDD
Nylon T connectors (Dean's copy)
http://www.hobbyking.com/buddy.asp?c...4-61951E5295B0
Corona DS238MG Digital Metal Gear Servo 4.6kg/ 22g/ 0.14sec
http://www.hobbyking.com/buddy.asp?c...9-E60F5D0A038C
3.5mm Male/Female bullet
http://www.hobbyking.com/buddy.asp?c...1-F0B050682123
Levictus is offline Find More Posts by Levictus
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 11 Feb 15, 2014 03:26 PM
Discussion what do you use as umbilical cable to your ROV? fluxno ROV - Remotely Operated Vehicles 3 Apr 01, 2011 10:46 AM
Discussion Do you wish (When you started) there were as many choices HX3D014 Electric Heli Talk 0 Jan 09, 2007 04:40 AM
Cascade Charger that will charge your battery automatically as many packs as you wish cadetman Batteries and Chargers 8 Feb 08, 2005 02:12 AM
