This thread is privately moderated by obuggy, who may elect to delete unwanted replies.
Old Sep 14, 2012, 05:08 AM
lex800 is offline
Find More Posts by lex800
lex800's Avatar
Russia, Saint Petersburg, g. Sankt-Peterburg
Joined Jun 2010
Find my codes here: http://hk.rc-international.info/swarm/lex800 (valid until September 28, 2012)
BMS-306DMAX Digital Micro Servo (Extra Strong) 1.6kg / .13sec / 7.1g Save US$: 1.77
Hobby King Discovery Buzzer Save US$: 0.38
6inch Quick Release Bar Clamp Tool Save US$: 0.35
Browse buddycodes on RC International now with your Android mobile phone or tablet with RC International unoffcial Hobbyking app
lex800 is offline Find More Posts by lex800
Old Sep 14, 2012, 10:28 AM
adioperator is offline
Find More Posts by adioperator
adioperator's Avatar
Joined May 2010
Extra Codes, You can save 6.01% for all of this products with:http://rc-buddy.com/user/adioperator! Codes from RC-Buddy.com
Hobbyking 60w Power Supply
Savings: 6.01 % / $0.6
Price after: $9.39
Weight: 407 g
Extra Codes, You can save 59.55% for all of this products with:http://rc-buddy.com/user/adioperator! Codes from RC-Buddy.com
Hobbyking Self Adhesive Centre of Gravity Marker (3pc)
Savings: 59.55 % / $0.53
Price after: $0.36
Weight: 12 g
adioperator is offline Find More Posts by adioperator
Old Sep 14, 2012, 11:17 PM
Dimarazumov is offline
Find More Posts by Dimarazumov
Watch out for that tree!
Joined May 2008
Turnigy 4000mAh Spektrum DX8 Intelligent Transmitter Pack
http://www.hobbyking.com/buddy.asp?c...C-9198A5AAE5DF
$15.12
Original price $17.95
Dimarazumov is offline Find More Posts by Dimarazumov
Old Sep 15, 2012, 01:30 AM
mray is offline
Find More Posts by mray
USA, AZ, Buckeye
Joined Feb 2010
Hobbyking Advanced EDF Jet LED Lighting System
Looking to add some scale flare to your next EDF Jet? This is it!
Send spectators into a frenzy with this systems throttle variable LED Afterburner, couple this system with the sound of our alloy EDF units for an audio visual feast!
Our new EDF LED lighting system adds great scale realism to your EDF Jet. This system has been designed exclusively for EDF Jets. Included in this set: Port (Red) & Starboard (Green) wing tip lights, a red clearance beacon, a super bright 10mm white landing light and an afterburner.
The navigation lights can be switched on/off via an auxillary channel, the afterburner responds to your throttle channel. The afterburner strip suits ducting with a maximum diameter of 150mm & can be trimmed to suit smaller ducts.
Features:
• Authentic navigation lighting scheme
• Lighting control unit
• Throttle controlled afterburner Ring
• User settable afterburner switching
• Navigation lamps switchable via aux channel
• 3s & 4s Power leads with integral fuse
Lights:
1 x 3mm Red LED 450mm lead
1 x 3mm GreenLED 450mm lead
1 x 3mm Red LED 950mm lead
1 x 10mm White LED 450mm lead
1 x 480 mm Yellow/Red afterburner 950mm lead
Spec:
Input: 2 channels (Thro & Aux)
Power: 3s or 4s
Max draw: 400mA
Weight: 81g
Dimensions: (control unit only) 30mm x 50mm x 11mm
Buddy Code- http://www.hobbyking.com/buddy.asp?c...4-5D47CA83805C
Landing Gear Wheel Stop Collar
Landing Gear Wheel Stopper (10pcs)
To suit 3mm Shaft
Buddycode- http://www.hobbyking.com/buddy.asp?c...5-CD21B8912E36
mray is offline Find More Posts by mray
Old Sep 15, 2012, 05:36 AM
turbovector is offline
Find More Posts by turbovector
"Kneel before Zod!"
turbovector's Avatar
Tacoma, WA. USA
Joined Dec 2003
http://www.hobbyking.com/buddy.asp?c...C-5E786B4BFCD7
Hobbyking DC-4S Balance Charger & Cell Checker 30w 2s~4s
http://www.hobbyking.com/buddy.asp?c...9-FE67D00D3D7C
Turnigy nano-tech 260mah 2S 35~70C Lipo Pack (E-flite micro series compatible)
http://www.hobbyking.com/buddy.asp?c...0-B66C8F3E003C
HXT900 Replacement Gear Set
http://www.hobbyking.com/buddy.asp?c...F-498FAAEE91DA
Prop adapter w/ Aluminum Cone 1/4x28-3.2mm shaft (grub screw type)
turbovector is offline Find More Posts by turbovector
Old Sep 15, 2012, 07:35 AM
guslinx is offline
Find More Posts by guslinx
Gusac
Joined Dec 2010
Find my codes here: http://hk.rc-international.info/swarm/rcpilotacro (valid until September 29, 2012)
Air Line/Fuel Line/ Cable Tidy Clip for 6mm OD (10pc) Save US$: 1.04
FrSky TEMS-01 Telemetry Temperature Sensor Save US$: 2.00
Extra Large Alloy Fuel Filter w/Firewall Mount and Heatsink Save US$: 1.58
Un-Cure CA Debonder 1. oz Save US$: 1.59
Part Boxes (PP Transparent) 5pcs Save US$: 0.59
guslinx is offline Find More Posts by guslinx
Old Sep 15, 2012, 09:14 AM
Tartago is offline
Find More Posts by Tartago
Plane crazy
Tartago's Avatar
Joined Apr 2006
Find my codes here: http://hk.rc-international.info/swarm/tartago (valid until September 22, 2012)
FrSky Receiver antenna 60 cm Save US$: 0.78
Balance Plug Savers (JST-XH 5s) (5pc Per Bag) Save US$: 0.86
Turnigy Transmitter Bag / Carrying Case Save US$: 1.80
ZIPPY Compact 2450mAh 5S 35C Lipo Pack Save US$: 31.29
5.8Ghz Audio/Video Transmitter (600mw) Save US$: 2.65
Turnigy Servo Signal Reverser Save US$: 0.41
HobbyKing Advanced EDF Jet LED Lighting System Save US$: 1.04
Tartago is offline Find More Posts by Tartago
Old Sep 15, 2012, 10:02 PM
takeoffmodelismo is offline
Find More Posts by takeoffmodelismo
Joined Mar 2011
Extra Codes, You can save 36.89% for all of this products with:http://rc-buddy.com/user/takeoffmodelismo! Codes from RC-Buddy.com
10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation (Green)
Savings: 60.51 % / $1.9
Price after: $1.24
Weight: 60 g
Polyester Velcro Peel-n-stick adhesive side V-STRONG (1mtr)
Savings: 5.86 % / $0.14
Price after: $2.25
Weight: 107 g
takeoffmodelismo is offline Find More Posts by takeoffmodelismo
Old Sep 16, 2012, 06:48 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Find my codes here: http://hk.rc-international.info/swarm/pavcon (valid until September 30, 2012)
Turnigy Battery Strap 330mm Save US$: 0.37
Insta-Cure Super Thin CA 1. oz Save US$: 1.04
pavcon is offline Find More Posts by pavcon
Old Sep 16, 2012, 10:04 AM
javipons22 is offline
Find More Posts by javipons22
Argentina, Buenos Aires, Lanús Oeste
Joined Mar 2011
Find my codes here: http://hk.rc-international.info/swarm/javipons22 (valid until September 29, 2012)
Turnigy nano-tech 2200mah 3S 25~50C Lipo Pack Save US$: 7.72
javipons22 is offline Find More Posts by javipons22
Old Sep 16, 2012, 11:02 AM
AlphaBravo is offline
Find More Posts by AlphaBravo
Joined Apr 2012
Validity : until 29 September 2012
1) TURNIGY Voltage Protector
http://www.hobbyking.com/buddy.asp?c...D-2B29C7777AF7
2) Turnigy AA LSD 2400mAh Low Self Discharg NIMH Batt
http://www.hobbyking.com/buddy.asp?c...D-B6644E3E34AB
3) Turnigy 9X LCD Backlight Kit for Turnigy/Flysky radio
http://www.hobbyking.com/buddy.asp?c...5-7E6369AF3953
4) Turnigy Transmitter bag/ carrying case
http://www.hobbyking.com/buddy.asp?c...0-30BC64430E31
5) Turnigy Heat Shrink Tube 20mm Transparent
http://www.hobbyking.com/buddy.asp?c...5-9A765E42A989
6) On Board Lipoly Low Voltage Alarm (2s~4s)
http://www.hobbyking.com/buddy.asp?c...E-20533B963B7B
7) XT60 Harness for 2 Packs in Parallel connector/adaptor
http://www.hobbyking.com/buddy.asp?c...F-EC0BC05BFC77
8) Single 4mm Male to 4 x 3.5mm Female Adaptor
http://www.hobbyking.com/buddy.asp?c...2-8EEEF5196668
9) USBasp AVR Programming Device for ATMEL proccessors (until 26 Sept 2012)
http://www.hobbyking.com/buddy.asp?c...6-80AEA9EAA733
AlphaBravo is offline Find More Posts by AlphaBravo
Old Sep 16, 2012, 11:41 AM
CheckSum is offline
Find More Posts by CheckSum
CheckSum's Avatar
Joined Jan 2011
Atmel Atmega Socket Firmware Flashing Tool
$18.78* (buddy price 6%, -$1.21)
All my buddy-codes here
CheckSum is offline Find More Posts by CheckSum
Old Sep 16, 2012, 07:37 PM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
Find my codes here: http://hk.rc-international.info/swarm/jxl (valid until September 26, 2012)
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC) Save US$: 0.20
Luminescent (Glow in the dark) Self Adhesive Film - 1200mm x 200mm Save US$: 0.64
12V 4.5A UBEC 2-5S Lipoly (12-23v) Save US$: 0.50
JST-XH 3S Wire Extension 20cm (10pcs/bag) Save US$: 0.47
jy0933 is offline Find More Posts by jy0933
Old Sep 17, 2012, 06:00 AM
Palle_Plutt is offline
Find More Posts by Palle_Plutt
Kingdom of Sweden, Västra Götaland County, Lindome
Joined Jul 2011
Find my codes here: http://hk.rc-international.info/swarm/palle_plutt (valid until October 01, 2012)
Hobbyking Retro LCD Pocket Scale 0.1g~500g Save US$: 2.14
Turnigy nano-tech 1700mAh 2S1P 20~40C LiFePo4 Receiver Pack Save US$: 2.44
Balance Plug Savers (JST-XH 2s) (5pc Per Bag) Save US$: 0.26
Turnigy nano-tech 260mAh 1S 35-70C Lipo Pack (QR Ladybird/Genius CP/Mini CP) Save US$: 1.30
Palle_Plutt is offline Find More Posts by Palle_Plutt
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 11 Feb 15, 2014 03:26 PM
Discussion what do you use as umbilical cable to your ROV? fluxno ROV - Remotely Operated Vehicles 3 Apr 01, 2011 10:46 AM
Discussion Do you wish (When you started) there were as many choices HX3D014 Electric Heli Talk 0 Jan 09, 2007 04:40 AM
Cascade Charger that will charge your battery automatically as many packs as you wish cadetman Batteries and Chargers 8 Feb 08, 2005 02:12 AM
