This thread is privately moderated by obuggy, who may elect to delete unwanted replies.
Old Aug 20, 2012, 02:58 PM
CrashingDutchman is offline
Find More Posts by CrashingDutchman
CrashingDutchman's Avatar
The Netherlands, Utrecht, Amersfoort
What is Cydia? I checked Cydiapps.com but it doesn't reveal what it is?!
CrashingDutchman is offline Find More Posts by CrashingDutchman
Old Aug 20, 2012, 02:59 PM
pablojaime is offline
Find More Posts by pablojaime
pablojaime's Avatar
Israel, Ashdod
Joined Dec 2009
Originally Posted by CrashingDutchman View Post
What is Cydia? I checked Cydia.com but it doesn't reveal what it is?!
it's like the App Store of Apple, but from the same people that make the Jailbreak.
Pablo.
pablojaime is offline Find More Posts by pablojaime
Old Aug 20, 2012, 06:00 PM
gino1007 is offline
Find More Posts by gino1007
Canada, ON, Toronto
Joined Jun 2012
New Codes, Use as Needed
Turnigy Pure-Silicone Wire 14AWG (1mtr) BLACK
http://www.hobbyking.com/buddy.asp?c...1-1A38F41A07E4
Turnigy Pure-Silicone Wire 14AWG (1mtr) RED
http://www.hobbyking.com/buddy.asp?c...9-DEA0E8FF4735
Turnigy nano-tech 2200mah 3S 35~70C Lipo Pack
http://www.hobbyking.com/buddy.asp?c...C-3E6EA53DB217
gino1007 is offline Find More Posts by gino1007
Old Aug 20, 2012, 06:33 PM
Jinxx is offline
Find More Posts by Jinxx
Jinxx's Avatar
Kaneohe, HI
Joined Oct 2006
Codes should be good until 9/02/12
Male XT60 <-> Female T-Connector (1pc/bag)
http://www.hobbyking.com/buddy.asp?c...4-F0D7A18E8A35
HobbyKing HKU5 5V/5A UBEC
http://www.hobbyking.com/buddy.asp?c...C-25FB056E71E5
Turnigy nano-tech 2100mAh 2S1P 20~40C LiFePo4 Receiver Pack
http://www.hobbyking.com/buddy.asp?c...0-31005C7C197E
Charge Cable w/ Male XT60 <-> 4mm Banana plug
http://www.hobbyking.com/buddy.asp?c...C-B2C2F63E89E7
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC)
http://www.hobbyking.com/buddy.asp?c...0-6324E2E490AA
Polymax 4mm Gold Connectors (10pairs/set)
http://www.hobbyking.com/buddy.asp?c...6-61159103FDE8
Jinxx is offline Find More Posts by Jinxx
Old Aug 20, 2012, 07:13 PM
Jeremy Kamutzki is offline
Find More Posts by Jeremy Kamutzki
Obeying the law of gravity
Jeremy Kamutzki's Avatar
Canada, ON, Cambridge
Joined Jul 2011
Buddy Code for:
Turnigy Nano-Tech 1s 3.7v 25-40C LiPo
http://www.hobbyking.com/buddy.asp?c...2-72072179119A
Turnigy TGY-390DMH High Performance MG Digital Servo (Extra Strong) 5.4kg / .11sec / 22.5g
http://www.hobbyking.com/buddy.asp?c...E-32E5B65E3447
2 Pin 6 x Pico Plug Charging Set Eflite compatible.
http://www.hobbyking.com/buddy.asp?c...1-393D5BD2D3E8
Jeremy Kamutzki is offline Find More Posts by Jeremy Kamutzki
Old Aug 20, 2012, 10:57 PM
PC55 is offline
Find More Posts by PC55
Newcastle. Australia
Joined Jan 2004
Magnetic screws/parts Tray Save US$: 0.57
Turnigy 1.5mm Hex Screwdriver Save US$: 0.37
Solder Wire 1mm/3m Save US$: 0.21
Turnigy Piston Stopper Save US$: 0.46
Scale National Air Force Insignia Decal Sheet - Australia Save US$: 1.99
Futaba Servo Arm Set Save US$: 1.26
PC55 is offline Find More Posts by PC55
Old Aug 21, 2012, 02:17 AM
Westwood is offline
Find More Posts by Westwood
Canada, BC, Burnaby
Joined Oct 2010
XT 90 5mm connector
http://www.hobbyking.com/buddy.asp?c...A-C658DE59DD2F
Westwood is offline Find More Posts by Westwood
Old Aug 21, 2012, 09:08 AM
Ljryeaiii is offline
Find More Posts by Ljryeaiii
Leland
Joined Jul 2012
USBasp AVR Programming Device for ATMEL proc
$4.15
http://www.hobbyking.com/buddy.asp?c...C-A10FF581B4A5
Ljryeaiii is offline Find More Posts by Ljryeaiii
Old Aug 21, 2012, 09:18 AM
zanek is offline
Find More Posts by zanek
Agressive driver
United States, CA, Santa Barbara
Joined Jun 2011
9x5 Propellers (Standard and Counter Rotating
$2.21
http://www.hobbyking.com/buddy.asp?c...A-A2D1C6409323
zanek is offline Find More Posts by zanek
Old Aug 21, 2012, 04:48 PM
Tartago is offline
Find More Posts by Tartago
Plane crazy
Tartago's Avatar
Joined Apr 2006
Immersion RC audio/video transmitter 5.8Ghz Fatshark compatible
http://www.hobbyking.com/buddy.asp?c...7-8E7942C2B1EC
Tartago is offline Find More Posts by Tartago
Old Aug 22, 2012, 02:33 AM
beaverbuddy is offline
Find More Posts by beaverbuddy
New Zealand, Canterbury, Christchurch
Joined Sep 2011
Find my codes here: http://hk.rc-international.info/swarm/quarry44 (valid until September 05, 2012)
Turnigy FBL100 3D Micro Helicopter (RTF) (Mode 2) Save US$: 109.99
beaverbuddy is offline Find More Posts by beaverbuddy
Old Aug 22, 2012, 11:07 AM
sihinch is offline
Find More Posts by sihinch
Canada, ON, Toronto
Joined Jun 2007
185mm BEC eliminator cable
use the code when adding the item to your cart & you will pay only $0.35
http://www.hobbyking.com/buddy.asp?c...5-3A441572DCAB
JR 15cm servo Y lead (5pcs)
use the code when adding the item to your cart & you will pay only $2.40
http://www.hobbyking.com/buddy.asp?c...5-714F8F70188E
Battery hot glue gun
use the code when adding the item to your cart & you will pay only $2.29
http://www.hobbyking.com/buddy.asp?c...6-7E21E123B68D
Master Airscrew 6x4 3-blade prop (that I use for HK Lanc)
use the code when adding the item to your cart & you will pay only $2.47
http://www.hobbyking.com/buddy.asp?c...3-661789D122E2
Master Airscrew 6x4 Pusher 3-blade prop (that I use for HK Lanc)
http://www.hobbyking.com/buddy.asp?c...1-7FC3AAB57A50
sihinch is offline Find More Posts by sihinch
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 11 Feb 15, 2014 03:26 PM
Discussion what do you use as umbilical cable to your ROV? fluxno ROV - Remotely Operated Vehicles 3 Apr 01, 2011 10:46 AM
Discussion Do you wish (When you started) there were as many choices HX3D014 Electric Heli Talk 0 Jan 09, 2007 04:40 AM
Cascade Charger that will charge your battery automatically as many packs as you wish cadetman Batteries and Chargers 8 Feb 08, 2005 02:12 AM
