This thread is privately moderated by obuggy, who may elect to delete unwanted replies.
Old Jul 20, 2012, 01:02 AM
StZ is offline
StZ
Find More Posts by StZ
StZ
Ελλάς, Δυτική Ελλάδα, Πάτρα
Joined Oct 2010
Buddy Codes valid until August 03, 2012
Find my codes here: http://hk.rc-international.info/swarm/stz (valid until August 03, 2012)
Master Airscrew - Balsa Stripper Save US$: 0.86
X-BLADE Spare SK-5 Steel blades (10pcs/set) Save US$: 0.63
Scale alloy hub rubber wheel 3.0inch Save US$: 0.53
Sponge Wheel D65xH18 (3pcs/bag) Save US$: 0.68
Sponge Wheel D80xH22 (3pcs/bag) Save US$: 0.68
Carbon Fiber Tube (hollow) 12x750mm Save US$: 0.60
Carbon Fiber Tube (hollow) 14x750mm Save US$: 1.43
Carbon Fiber Tube (hollow) 3x2x750mm Save US$: 0.73
6inch Quick Release Bar Clamp Tool Save US$: 0.35
Magnetic screws/parts Tray Save US$: 0.39
Hex Screw M2x10 (20pcs) Save US$: 0.28
StZ is offline Find More Posts by StZ
Old Jul 20, 2012, 01:39 AM
StZ is offline
StZ
StZ
Joined Oct 2010
Buddy Codes valid until July 28, 2012
Find my codes here: http://hk.rc-international.info/swarm/stz (valid until July 28, 2012)
6inch Ratchet Clamp Tool Save US$: 0.35
Polyester Hook and Loop Velcro V-STRONG (1mtr) Save US$: 0.27
Cable/Wire Holder (10pc) Save US$: 0.16
Polyester Velcro Peel-n-stick adhesive side V-STRONG (1mtr) Save US$: 0.14
Nylon Clevis M2 L23 (10sets) Save US$: 0.37
WireLabels - servo wire label heatshrink (14mm x 1m) Save US$: 0.61
JXF 15x6 / 381 x 152.5mm Poly Composite propeller Save US$: 0.61
Super Light Pivot & Round Hinges D4.5xW12xL63mm (10pcs/bag) Save US$: 0.64
HobbyKing Super Glue CA (50g / 1.7oz) Save US$: 1.42
On-Board LED RX Voltage Display Save US$: 0.54
Turnigy Type A Beech wood 13x8 propeller Save US$: 0.94
Old Jul 20, 2012, 02:37 AM
kmihalkov is online now
Find More Posts by kmihalkov
Germany
Joined Sep 2011
Valid until: 04 August 2012
Scorpion SII-3020-780 Brushless Outrunner Motor
http://www.hobbyking.com/buddy.asp?c...3-AB8C6B3F2842
kmihalkov is online now Find More Posts by kmihalkov
Old Jul 20, 2012, 04:11 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Find my codes here: http://hk.rc-international.info/swarm/pavcon (valid until August 03, 2012)
Turnigy Receiver Controlled Switch Save US$: 0.97
Turnigy R/C LED Lighting System Save US$: 0.18
pavcon is offline Find More Posts by pavcon
Old Jul 20, 2012, 09:00 AM
Germany
Joined Sep 2011
Valid until 03. August 2012
Scorpion SII-3014-830KV Brushless Outrunner Motor
http://www.hobbyking.com/buddy.asp?c...1-4291E3C14B3E
Aero Andy is offline
Find More Posts by Aero Andy
ExPat
Aero Andy's Avatar
Spain, Murcia, Mazarrón
Joined Apr 2010
Find my codes here: http://hk.rc-international.info/swarm/aero-andy (valid until August 03, 2012)
ZIPPY Compact 1500mAh 3S 25C Lipo Pack Save US$: 2.22 Now only $7.11
Aero Andy is offline Find More Posts by Aero Andy
Old Jul 20, 2012, 09:02 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Clear Foam Glue (Medium Cure) - Small 20g Save US$: 0.09 Now only $0.61
Old Jul 20, 2012, 09:59 AM
one_eye is offline
Find More Posts by one_eye
Malaysia, Johor, Pasir Gudang
Joined Feb 2012
Some buddy codevo share, valid 14 days from today.
1) NTM Prop Drive Series 2826 -1000kv
http://www.hobbyking.com/buddy.asp?c...E-6CA20455E338
2) Air retract pipe D3x1.7mm (1 Mtr)
http://www.hobbyking.com/buddy.asp?c...4-2B960D0B3979
3) Turnigy Talon V2 Carbon Fiber extended Boom 320mm (2 pcs)
Optional upgrade part to extend the boom length on your Talon V2 Quadcopter.
http://www.hobbyking.com/buddy.asp?c...7-90699F6B8EA0
4) FPV Fiberglass Pan Tilt Camera Mount
http://www.hobbyking.com/buddy.asp?c...C-05E9C57F5946
5) Servo Lead Label Heatshrink (14mm x 1m)
-Ideal for neat labelling of servo leads, simply cut the desired pre-printed label from the roll, slide onto the lead or plug and shrink! The following Labels are pre-printed onto the 1 metre roll: Aux 1, Aux 2, Flap, Gear, Battery, Aileron, Elevator, Rudder, Throttle.
http://www.hobbyking.com/buddy.asp?c...6-F15F9BCC4B23
6) Turnigy 4mm Heat Shrink Tube - BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?c...0-9379A9C3DFA9
7) Turnigy 4mm Heat Shrink Tube - RED
http://www.hobbyking.com/buddy.asp?c...A-54857D223F03
8) Turnigy 5mm Heat Shrink Tube - RED
http://www.hobbyking.com/buddy.asp?c...7-68517689BEBE
9) Hobby King Quadcopter power distribution board
10) Turnigy 5mm Heat Shrink Tube - BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?c...F-6EFD96DC210C
11) Super Simple Mini OSD
http://www.hobbyking.com/buddy.asp?c...7-39F6E276A793
one_eye is offline Find More Posts by one_eye
Old Jul 20, 2012, 10:26 AM
one_eye is offline
Joined Feb 2012
Old Jul 20, 2012, 12:37 PM
abroadhurst94 is offline
Find More Posts by abroadhurst94
abroadhurst94's Avatar
United Kingdom, England, Lincoln
Joined Jun 2011
Find my codes here: http://hk.rc-international.info/swarm/abroadhurst94 (valid until August 3, 2012)
USBasp AVR Programming Device for ATMEL proccessors Save US$: 0.80
abroadhurst94 is offline Find More Posts by abroadhurst94
Old Jul 20, 2012, 02:30 PM
tisdale is offline
Find More Posts by tisdale
United States, AR, Midway
Joined Jun 2012
do some one have free Shipping Options today at r/c hobbyking today ?? pls send ty
tisdale is offline Find More Posts by tisdale
Old Jul 20, 2012, 02:50 PM
GTiDonavan is offline
Find More Posts by GTiDonavan
Joined Jan 2012
Hobbyking Red brick 30A ESC http://www.hobbyking.com/buddy.asp?c...4-97A011F4B830
GTiDonavan is offline Find More Posts by GTiDonavan
Old Jul 21, 2012, 02:59 AM
Banjo5 is offline
Find More Posts by Banjo5
Canada, ON, Merrickville-Wolford
Joined Jun 2012
OK, just did another order and here's the codes if they help anyone. Cheers, Andrew.
Find my codes here: http://hk.rc-international.info/swarm/andrew (valid until August 03, 2012)
JST Female 2 pin connector set (10pcs/set) Save US$: 0.24
GWS EP Propeller (DD-9050 229x127mm) (6pcs/set) Save US$: 1.25
GWS EP Propeller (DD-6030 152x76mm) (6pcs/set) Save US$: 1.01
Banjo5 is offline Find More Posts by Banjo5
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 11 Feb 15, 2014 03:26 PM
Discussion what do you use as umbilical cable to your ROV? fluxno ROV - Remotely Operated Vehicles 3 Apr 01, 2011 10:46 AM
Discussion Do you wish (When you started) there were as many choices HX3D014 Electric Heli Talk 0 Jan 09, 2007 04:40 AM
Cascade Charger that will charge your battery automatically as many packs as you wish cadetman Batteries and Chargers 8 Feb 08, 2005 02:12 AM
