This thread is privately moderated by obuggy, who may elect to delete unwanted replies.
Old Jun 24, 2012, 07:13 AM
hakan2391 is offline
Find More Posts by hakan2391
Joined May 2011
Nylon Snap-Click style clevis 2x8x23mm (10pc
hakan2391 is offline Find More Posts by hakan2391
Joined May 2011
http://www.hobbyking.com/buddy.asp?c...D-218CA613DD32
Old Jun 24, 2012, 09:53 AM
unixadm is offline
Find More Posts by unixadm
Joined Feb 2008
Turnigy 4S 5000mah 20C Hard Shell LIPO Pack:
http://www.hobbyking.com/buddy.asp?c...0-A65E0DB9B7A3
I'm running this pack in a Team Associated SC8E RTR (1/8th) and it works absolutely excellent. I blew two tires yesterday with this pack. Save $1.64
unixadm is offline Find More Posts by unixadm
Old Jun 24, 2012, 12:22 PM
Wasp09 is offline
Find More Posts by Wasp09
Canada, ON, Ottawa
Joined Jun 2009
5030R 3-blade props:
http://www.hobbyking.com/buddy.asp?c...B-DFD8E7F39282
Wasp09 is offline Find More Posts by Wasp09
Old Jun 25, 2012, 06:23 AM
neo__04 is offline
Find More Posts by neo__04
Australia, VIC, Warrnambool
Joined Feb 2012
XT60 Harness for 2 Packs in Parallel (1pc)
http://www.hobbyking.com/buddy.asp?c...6-B5313BDF201B
Q005 FPV Fiberglass Pan-Tilt Camera Mount L-Size
http://www.hobbyking.com/buddy.asp?c...6-A3D68704EF48
AM1051-30CM Futaba Y Servo Lead 30cm Length (5pcs/bag)
http://www.hobbyking.com/buddy.asp?c...9-F3F032486464
HK-151 Insta-Set CA Accelerator 2. oz
http://www.hobbyking.com/buddy.asp?c...2-DE2F495C0E47
307000001 AC Hinge Sheet 180mmx140mmx0.3mm
http://www.hobbyking.com/buddy.asp?c...2-612A48F9E5F3
T-Twins Twin pack charge lead (2 x 3S)6S w/ XT60
http://www.hobbyking.com/buddy.asp?c...7-5FE4C5ACF201
HXT500 HXT500 5g / .8kg / .10sec Micro Servo
http://www.hobbyking.com/buddy.asp?c...E-3C375F159B5C
015000008 30CM Servo Lead Extention (JR) with hook 26A
http://www.hobbyking.com/buddy.asp?c...5-22C0E9722861
9171000034 Tie-D-Wires Cable & Wire Holders (10pc)
http://www.hobbyking.com/buddy.asp?c...7-88646DD5671A
008-00201x10 Nylon & Pinned Hinge 16x28.5 (10pcs)
http://www.hobbyking.com/buddy.asp?c...F-4A11D5511FBB
neo__04 is offline Find More Posts by neo__04
Old Jun 25, 2012, 09:34 AM
R1-Chris is offline
Find More Posts by R1-Chris
Joined Jun 2006
Rhino 1250mAh 2S 7.4v 30C Lipoly Pack
http://www.hobbyking.com/buddy.asp?c...B-436B3ECF9892
Codes valid until July, 5th:
2mm Gold Connectors 10 pairs (20pc)
http://www.hobbyking.com/buddy.asp?c...9-463F2884EB48
Servo Terminals (Futaba) Gold Plated (10pair
http://www.hobbyking.com/buddy.asp?c...1-DA020E896AA2
HK-3000 3ch 2.4ghz FHSS RX suit the HK310 Tr
http://www.hobbyking.com/buddy.asp?c...5-CF6375B45C44
Mini T45 EDF Fighter Jet EPO (KIT)
http://www.hobbyking.com/buddy.asp?c...6-FACB5AC50909
Black Aluminum Motor Heat Sink (36mm Diameter
http://www.hobbyking.com/buddy.asp?c...F-EBBA90A3D4D1
BA Nano Gyro 2.3gram
http://www.hobbyking.com/buddy.asp?c...2-7A04CADF497E
Impeller Hub for (EDF55 & 64) 2.3mm Shaft
http://www.hobbyking.com/buddy.asp?c...8-4982CBC6AA4B
Impeller Hub for EDF40 2mm Shaft
http://www.hobbyking.com/buddy.asp?c...7-15F9D0592C6B
Rotor for Hobbyking Alloy 50mm EDF Unit
http://www.hobbyking.com/buddy.asp?c...3-8E4B0FB9984D
Impeller Hub for (EDF55 & 64) 2mm Shaft
http://www.hobbyking.com/buddy.asp?c...0-89AD39918D4E
R1-Chris is offline Find More Posts by R1-Chris
Old Jun 25, 2012, 12:09 PM
fatcat1 is offline
Find More Posts by fatcat1
United States, IN, Mooresville
Joined Feb 2008
Brand new Buddy Codes for everyone enjoy!!!
JR Spektrum Satellite EXtensions
EC3 PLUGS 10Pcs set
30CM Servo Lead Extention (JR) with hook 26AWG (5pcs/bag)
fatcat1 is offline Find More Posts by fatcat1
Old Jun 26, 2012, 03:05 AM
anlucas is online now
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Find my codes here: http://hk.rc-international.info/swarm/anlucas (valid until July 10, 2012)
HobbyKing Red Brick 30A ESC Save US$: 1.06
Plastic Scale Undercarriage Trailing Link 5mm Save US$: 1.60
TURNIGY Voltage Protector Save US$: 1.38
anlucas is online now Find More Posts by anlucas
Old Jun 26, 2012, 09:05 AM
laask is offline
Find More Posts by laask
Joined May 2012
hacker Style Brushless Outrunner 20-28M
http://www.hobbyking.com/buddy.asp?c...2-78A8ABBF4722
HobbyKing 20A BlueSeries Brushless Speed Con
http://www.hobbyking.com/buddy.asp?c...1-8845B4BBA88C
Slow Fly Electric Prop 9047R SF and 9047 (4 pc - Green)
http://www.hobbyking.com/buddy.asp?c...B-C005CC46F515
http://www.hobbyking.com/buddy.asp?c...7-97BBAF973BB5
ZIPPY Compact 4000mAh 3S 25C Lipo Pack
http://www.hobbyking.com/buddy.asp?c...D-87821EB83BD5
Turnigy Battery Strap 330mm
http://www.hobbyking.com/buddy.asp?c...1-7D3AFE434BD3
5.6mm x 14mm M3 Nylon Threaded Spacer (10pc)
http://www.hobbyking.com/buddy.asp?c...4-264853953F76
Hobby King Quadcopter Power Distribution Board
http://www.hobbyking.com/buddy.asp?c...0-14637B4E6718
Single 4mm Male to 4 x 3.5mm Female Adapter
http://www.hobbyking.com/buddy.asp?c...9-9BFB30E93B2F
Hobby King 2.4Ghz 6Ch Tx & Rx V2 (Mode 2)
http://www.hobbyking.com/buddy.asp?c...6-319369277F0E
Hobby King 2.4Ghz 6Ch Tx USB Cable
http://www.hobbyking.com/buddy.asp?c...5-D644E7D82F2A
TURNIGY Transmitter Strap
http://www.hobbyking.com/buddy.asp?c...6-E8CE9B3BF0F0
USBasp AVR Programming Device for ATMEL proc
http://www.hobbyking.com/buddy.asp?c...C-34A5093ECCA3
laask is offline Find More Posts by laask
Old Jun 26, 2012, 09:21 AM
mjtaylor is offline
Find More Posts by mjtaylor
Joined Jun 2012
HobbyKing buddy codes good until July 9th
DL-Volt-Alarm On Board Lipoly Low Voltage Alarm (2s~4s) only $1.79
http://www.hobbyking.com/buddy.asp?c...B-90AEFE38AC7C
E3.17-0.5-11T Pinion Gear 3.17mm/0.5M 11T (1pc) only $0.73
http://www.hobbyking.com/buddy.asp?c...F-72C24104AB96
ACC6 Turnigy Accucel-6 50W 6A Balancer/Charger only $22.39
http://www.hobbyking.com/buddy.asp?c...C-18118054E95F
9171000003 USBasp AVR Programming Device for ATMEL proc only $4.15
http://www.hobbyking.com/buddy.asp?c...9-D99D22D15234
S611-A Turnigy R/C Helicopter Blade Balancer (Carbon) only $2.88
http://www.hobbyking.com/buddy.asp?c...B-37B0903C768E
ES-02-3mm Wire Mesh Guard Black 3mm (1mtr) only $0.18
http://www.hobbyking.com/buddy.asp?c...4-89078B12A197
TIG_tail_62 62mm TIG Carbon Fiber Tail Blade only $4.65
http://www.hobbyking.com/buddy.asp?c...5-1DD17982B9BE
mjtaylor is offline Find More Posts by mjtaylor
Old Jun 26, 2012, 10:22 AM
Tharindurmt is offline
Find More Posts by Tharindurmt
Joined Aug 2011
Buddy Codes
Find my codes here: http://hk.rc-international.info/swarm/tharindurmt (valid until July 10, 2012)
18-11 2000kv Micro Brushless Outrunner (10g) Save US$: 0.38
hexTronik 24gram Brushless Outrunner 1300kv Save US$: 0.53
TURNIGY Plush 6A /.8bec/6g Speed Controller Save US$: 1.27
5x3R Propellers (Counter Rotating) (5Pcs/Bag) Save US$: 1.00
Tharindurmt is offline Find More Posts by Tharindurmt
Old Jun 26, 2012, 12:37 PM
rkovvur is offline
Find More Posts by rkovvur
R/C newbie
United States, TX, Austin
Joined Mar 2008
Find my codes here: http://hk.rc-international.info/swarm/rkovvur (valid until July 04, 2012)
General Purpose L Bracket (5pcs/bag) Save US$: 1.15
Hex locknuts M3 10pc Save US$: 0.45
5.6mm x 36mm M3 Nylon Threaded Spacer (10pc) Save US$: 0.87
Slow Fly Electric Prop 9047SF (4 pc) Save US$: 0.39
M3x12mm Nylon Screws (10pcs/bag) Save US$: 0.23
Arduino Uno - Atmel Atmega 328-PU (Clone) Save US$: 0.65
rkovvur is offline Find More Posts by rkovvur
Old Jun 26, 2012, 06:44 PM
joeyjojojjjjjj is offline
Find More Posts by joeyjojojjjjjj
Custom User Title: goes here
Joined May 2008
TURNIGY Plush 18amp Speed Controller
http://www.hobbyking.com/buddy.asp?c...E-45111121562D
Turnigy balancer & Charger 2S-3S
http://www.hobbyking.com/buddy.asp?c...1-89289F834EB7
AX 1806N 2100kv Brushless Micro Motor (19g)
http://www.hobbyking.com/buddy.asp?c...E-869104E5F9B2
http://www.hobbyking.com/buddy.asp?c...9-0F71E395CD43
Electric Motor StandOff Mounts 10mm Small ba
http://www.hobbyking.com/buddy.asp?c...8-1E64EBF259FA
http://www.hobbyking.com/buddy.asp?c...C-A6FA2D6188D4
joeyjojojjjjjj is offline Find More Posts by joeyjojojjjjjj
Old Jun 26, 2012, 07:25 PM
mickmick is offline
Find More Posts by mickmick
Joined Sep 2011
Find my codes here: http://hk.rc-international.info/swarm/mickmick (valid until July 11, 2012)
NTM Prop Drive 35-48 Series 900KV / 815W Save US$: 3.98
NTM Prop Drive 3548 Series Replacement Shaft Save US$: 1.19
Turnigy Aerodrive SK3 3542 Series Replacement Shaft Set Save US$: 0.89
Turnigy Aerodrive SK3 - 35-XX Spare Accessory Pack Save US$: 1.40
Z-bend Pliers. Heavy Duty 90deg up to 1/16 Save US$: 1.64
TURNIGY Plush 80A w/ UBEC Speed Controller Save US$: 4.63
Turnigy Ultra-light wood propeller 11x6 Save US$: 0.30
Ultra Thin Foam Glue 40ml Save US$: 0.89
Clear Foam Glue (Medium Cure) - Large 100ml Save US$: 0.13
Evotite CA460 Foam Safe Super Glue (Medium) Save US$: 1.18
Polyester Velcro Peel-n-stick adhesive side V-STRONG (1mtr) Save US$: 0.15
Strong Rare-Earth Button Magnets (10pcs/set) Save US$: 0.90
Insta-Set CA Accelerator 8. oz Save US$: 2.00
Super Gold Thin Odorless CA 1/2 oz Save US$: 1.30
Super Gold Plus Odorless CA 1/2 oz (Foam Safe) Save US$: 1.27
Quick-Cure 5 Min Epoxy 4.5 oz Save US$: 0.77
Glass Fiber Cloth 450x1000mm 48g/m2 (Ultra Thin) Save US$: 0.19
Glass Fiber Cloth 450x1000mm 18g/m2 (Super Thin) Save US$: 0.29
Nylon and Pinned Hinge 16x28.5 (10pcs) Save US$: 0.37
Plastic Parts Set 29pc (horn hinge) Save US$: 0.92
Control Horns 13.5x16mm (10pcs) Save US$: 0.36
Mini Ultra-light Horns 23x14x6mm (4pcs/set) Save US$: 0.27
Linkage Stopper M3x2xL11.2mm (10pcs/set) Save US$: 0.55
Linkage Stopper D1.8mm (10pcs) Save US$: 1.99
Threaded Ends M2xL20mm (10pcs/set) Save US$: 0.94
Nylon Snap-Click style clevis 10pc Save US$: 0.64
Carbon Fiber Rod (solid) 1x750mm Save US$: 0.75
Carbon Fiber Rod (solid) 2.0x750mm Save US$: 0.73
Carbon Fiber Rod (solid) 1.5x750mm Save US$: 0.74
Carbon Strip 1x3x750mm (5pcs/set) Save US$: 1.47
Carbon Strip 1x6x750mm (5pcs/set) Save US$: 2.14
Rhino 1050mAh 3S 11.1v 20C Lipoly Pack Save US$: 0.90
Turnigy nano-tech 1000mah 2S 25~50C Lipo Pack Save US$: 1.63
Turnigy nano-tech 850mah 2S 25~40C Lipo Pack Save US$: 2.57
Master Airscrew S-2 Propeller 11x6 Save US$: 0.44
Master Airscrew propeller 11x6 Save US$: 1.13
Master Airscrew propeller 12x4 Save US$: 1.43
mickmick is offline Find More Posts by mickmick
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 11 Feb 15, 2014 03:26 PM
Discussion what do you use as umbilical cable to your ROV? fluxno ROV - Remotely Operated Vehicles 3 Apr 01, 2011 10:46 AM
Discussion Do you wish (When you started) there were as many choices HX3D014 Electric Heli Talk 0 Jan 09, 2007 04:40 AM
Cascade Charger that will charge your battery automatically as many packs as you wish cadetman Batteries and Chargers 8 Feb 08, 2005 02:12 AM
