This thread is privately moderated by obuggy, who may elect to delete unwanted replies.
Old Jun 05, 2012, 09:47 AM
The Violets is offline
Find More Posts by The Violets
Student-Can't Fly Yet
The Violets's Avatar
Canada, QC, Montreal
Joined Apr 2012
Codes Good until the 19th of June
First time poster, here’s a few items from my recent order, good up-to June 19th
Turnigy Hex Driver set 4 in 1 1.5~ 3.0 (Save $0.60)
http://www.hobbyking.com/buddy.asp?c...7-B05DB8BA5D4A
TURNIGY 4pcs hex socket driver set (Save $0.95)
http://www.hobbyking.com/buddy.asp?c...A-DAA8EF440496
Turnigy Imperial Hex Driver Set (050, 1/16, 5/64 & 3/32) 4pc (Save $0.95)
http://www.hobbyking.com/buddy.asp?c...5-5BF334B76F0F
6inch Quick Release Bar Clamp Tool (Save $0.35)
http://www.hobbyking.com/buddy.asp?c...4-D49AA751E590
Hard Steel Tweezer Set (Save $0.35)
http://www.hobbyking.com/buddy.asp?c...C-C5837A0F2DDE
Knife Edge Reamer 0.5-10mm (Save $0.35)
http://www.hobbyking.com/buddy.asp?c...C-36D258787427
File set (10pcs/set) (Save $1.12)
http://www.hobbyking.com/buddy.asp?c...3-D95B04B55EB0
Solder Paste 50g (Save $0.65)
http://www.hobbyking.com/buddy.asp?c...A-0E9D6936BCBD
Self Tapping Screws w/shoulder M2x12 (10pcs/set) (Save $1.12)
http://www.hobbyking.com/buddy.asp?c...2-D72581BAAD0C
XT60 to T-Connector Battery Adapter Lead (2pc) (Save $1.12)
http://www.hobbyking.com/buddy.asp?c...8-1304E16C830B
Slow-Cure 30 Min Epoxy 4.5 oz (Save $1.12)
http://www.hobbyking.com/buddy.asp?c...2-689AB5AAE206
Cheers,
Michael
The Violets is offline Find More Posts by The Violets
Old Jun 05, 2012, 11:23 AM
matkas is offline
Find More Posts by matkas
Best Buddy
matkas's Avatar
Polska, dolnośląskie, Bogatynia
Joined Aug 2009
Michael, your codes:
Extra Codes, You can save 24.29% for all of this products with:http://rc-buddy.com/user/Michael! Codes from RC-Buddy.com
Savings: 12.95 % / $0.57
Price after: $3.83
Weight: 91 g
Savings: 13.02 % / $0.6
Price after: $4.01
Weight: 125 g
Savings: 13.02 % / $0.91
Price after: $6.08
Weight: 275 g
Savings: 35.35 % / $0.35
Price after: $0.64
Weight: 105 g
Savings: 12.95 % / $0.29
Price after: $1.95
Weight: 53 g
Savings: 55.98 % / $2.48
Price after: $1.95
Weight: 47 g
Savings: 16.14 % / $1.08
Price after: $5.61
Weight: 52 g
Solder Paste 50g
Savings: 24.06 % / $0.64
Price after: $2.02
Weight: 76 g
Savings: 80 % / $1.12
Price after: $0.28
Weight: 9 g
Savings: 36.21 % / $0.84
Price after: $1.48
Weight: 24 g
Savings: 25 % / $1.54
Price after: $4.62
Weight: 197 g
matkas is offline Find More Posts by matkas
Old Jun 05, 2012, 03:37 PM
High Flyin' is offline
Find More Posts by High Flyin'
Out the Window
High Flyin''s Avatar
United States, FL, Alachua
Joined Jul 2004
Good Buddy Codes
Find my codes here: http://hk.rc-international.info/swarm/ray (valid until June 15, 2012)
Lightweight Scale wheel 83mm (2pc) Save US$: 1.85
TURNIGY Plush 25amp Speed Controller Save US$: 0.86
TURNIGY Plush 10amp 9gram Speed Controller Save US$: 2.49
FC 28-22 Brushless Outrunner 1200kv Save US$: 0.94
High Flyin' is offline Find More Posts by High Flyin'
Old Jun 06, 2012, 01:40 AM
Mujiber is offline
Find More Posts by Mujiber
Joined Dec 2007
Extra Codes, You can save 33.33% for all of this products with:http://rc-buddy.com/user/mujiber! Codes from RC-Buddy.com
10pc E-clip (3*0.4) - 110BS, A2023T, A2029 and A2035
Savings: 36.84 % / $0.14
Price after: $0.24
Weight: 15 g
10pc E-Clip (4*0.4) - 118B, A2023 and A2035
Savings: 37.5 % / $0.18
Price after: $0.30
Weight: 15 g
Turnigy Heat Shrink Tube 25mm Transparent (1mtr)
Savings: 24 % / $0.18
Price after: $0.57
Weight: 79 g
Pin Horns L22xW19xH.9 (10sets)
Savings: 37.11 % / $0.36
Price after: $0.61
Weight: 6 g
Mujiber is offline Find More Posts by Mujiber
Old Jun 06, 2012, 02:44 AM
furyphoto is offline
Find More Posts by furyphoto
Posting, but should be working
furyphoto's Avatar
Brackendale, BC, Canada
Joined Sep 2006
Find my codes here: http://hk.rc-international.info/swarm/furyphoto (valid until June 16, 2012)
10CM Male to Male Servo Lead (JR) 26AWG (10pcs/set) Save US$: 1.72
Gold Plated Spring Connector 3.5mm (10pair/20pc) Save US$: 1.68
Single 4mm Male to 4 x 3.5mm Female Adapter (1 set) Save US$: 0.69
USBasp AVR Programming Device for ATMEL proccessors Save US$: 0.80
furyphoto is offline Find More Posts by furyphoto
Old Jun 06, 2012, 07:20 AM
Tartago is offline
Find More Posts by Tartago
Plane crazy
Tartago's Avatar
Joined Apr 2006
My codes below:
RC-international is dead today.
9171000016 5.6mm x 21mm M3 Nylon Threaded Spacer (10pc) http://www.hobbyking.com/buddy.asp?c...3-76E5282E46C4
9171000018 5.6mm x 15mm M3 Nylon Tapped Spacer (10pc) http://www.hobbyking.com/buddy.asp?c...D-B1FB242FD565
9171000015 5.6mm x 14mm M3 Nylon Threaded Spacer (10pc) http://www.hobbyking.com/buddy.asp?c...E-8DCBF13CFA83
9171000017 5.6mm x 36mm M3 Nylon Threaded Spacer (10pc) http://www.hobbyking.com/buddy.asp?c...0-16D95AD32B2F
318000015 LED Strip with JST Connector 200mm (Blue) http://www.hobbyking.com/buddy.asp?c...3-D0B0DD0AB2A9
318000017 LED Strip with JST Connector 200mm (White) http://www.hobbyking.com/buddy.asp?c...C-84C61B7D2E57
9165000001 WireLabels - servo wire label heatshrink (14 mm x 1m) Only 0.18!
http://www.hobbyking.com/buddy.asp?c...A-A2E04317D0AE
Only 0.18!
Tartago is offline Find More Posts by Tartago
Old Jun 06, 2012, 09:22 AM
matkas is offline
Best Buddy
matkas's Avatar
Joined Aug 2009
Originally Posted by Tartago View Post
My codes below:
Only 0.18!
Extra Codes, You can save 38.6% for all of this products with:http://rc-buddy.com/user/Tartago! Codes from RC-Buddy.com
Savings: 36.02 % / $0.76
Price after: $1.35
Weight: 15 g
Savings: 16.13 % / $0.35
Price after: $1.82
Weight: 15 g
Savings: 36.02 % / $0.67
Price after: $1.19
Weight: 14 g
Savings: 36.13 % / $0.86
Price after: $1.52
Weight: 20 g
Savings: 48.74 % / $0.97
Price after: $1.02
Weight: 15 g
Savings: 45.73 % / $0.91
Price after: $1.08
Weight: 15 g
WireLabels - servo wire label heatshrink (14mm x 1m)
Savings: 77.22 % / $0.61
Price after: $0.18
Weight: 25 g
Old Jun 06, 2012, 12:29 PM
Hetsis is offline
Find More Posts by Hetsis
Suomi, Vantaa
Joined Jul 2011
ZIPPY Compact 4000mAh 5S 25C Lipo Pack
ZIPPY Compact 2200mAh 3S 25C Lipo Pack
Hetsis is offline Find More Posts by Hetsis
Old Jun 06, 2012, 02:25 PM
matkas is offline
Best Buddy
matkas's Avatar
Joined Aug 2009
Extra Codes, You can save 23.08% for all of this products with:http://rc-buddy.com/user/Bazaar1984! Codes from RC-Buddy.com
5.8g 200mw FPV Wireless AV Tx & Rx Set
Savings: 5.39 % / $3.58
PriceAfter: $62.85
Weight: 190 g
Turnigy nano-tech 1000mAh 3S 45~90C Lipo Pack
Savings: -500.29 % / $-52.38
PriceAfter: $62.85
Weight: 136 g
Prop Saver w/ Band 4mm (10pcs)
Savings: -1475.19 % / $-58.86
PriceAfter: $62.85
Weight: 29 g
APC style propeller 9x6-E
Savings: 39 % / $0.39
PriceAfter: $0.61
Weight: 20 g
APC Style Propeller 8x4 (2 pc)
Savings: 24.02 % / $0.43
PriceAfter: $1.36
Weight: 47 g
4mm Gold Connectors 10 pairs (20pc)
Savings: 20.24 % / $0.5
PriceAfter: $1.97
Weight: 31 g
Push Rod Sleeves (2pc/bag)
Savings: 36.26 % / $0.62
PriceAfter: $1.09
Weight: 19 g
Nylon Clevis 2x29mm (10pcs)
Savings: 12.5 % / $0.08
PriceAfter: $0.56
Weight: 6 g
Pin Horns L20xW15xH11.52 (4 holes) 10pcs/set
PriceAfter: $0.61
Weight: 13 g
hacker Style Brushless Outrunner 20-28M
Savings: 5.39 % / $0.67
PriceAfter: $11.75
Weight: 89 g
1047SF Combo (1047SF & R1047SF) (3 Standard & 3 Counter Rotating Per Bag)
Savings: 46.58 % / $2.79
PriceAfter: $3.20
Weight: 69 g
Savings: 15.56 % / $0.77
PriceAfter: $4.18
Weight: 35 g
Turnigy 5A (8-26v) SBEC for Lipo
Savings: 17.96 % / $0.88
PriceAfter: $4.02
Weight: 37 g
Extra Codes, You can save 12.61% for all of this products with:http://rc-buddy.com/user/Hetsis! Codes from RC-Buddy.com
Savings: 12.52 % / $4.63
Price after: $32.36
Weight: 529 g
Savings: 12.9 % / $1.45
Price after: $9.79
Weight: 179 g
Old Jun 06, 2012, 05:53 PM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
TQVM Matkas!
Old Jun 06, 2012, 09:00 PM
garytcl is offline
Find More Posts by garytcl
garytcl's Avatar
Joined Aug 2008
9x5 propeller 5pcs / set
http://www.hobbyking.com/buddy.asp?c...5-E49C1055EE5B
Landing Gear Wheels stopper
http://www.hobbyking.com/buddy.asp?c...B-2ABC8F8AF5AF
Zippy Compact 3s 1000mah 25C * Only USD 4.13/pc !!!
http://www.hobbyking.com/buddy.asp?c...6-D24E145A71BC
HK Orange 10g Servo
http://www.hobbyking.com/buddy.asp?c...1-190F73122737
Turnigy Glow Plug lighter Tool
http://www.hobbyking.com/buddy.asp?c...D-BFCFAC690FFE
CF Rod solid 2.5 x 750mm
Small Wheels 30 x 13mm ( 5pcs ) only USD 1.11/pc
http://www.hobbyking.com/buddy.asp?c...3-2E38062335B4
garytcl is offline Find More Posts by garytcl
Old Jun 07, 2012, 12:58 AM
teknokraze is offline
Find More Posts by teknokraze
Pro RC Boneyard Developer
teknokraze's Avatar
Canada, BC, Arrow Creek
Joined Jan 2012
ZIPPY Compact 4500mAh 3S 35C Lipo Pack
Save $8.32 per battery!
Regular Price: $34.13
Buddy Price: $25.81
http://www.hobbyking.com/buddy.asp?c...E-1DFE885C896A
teknokraze is offline Find More Posts by teknokraze
Old Jun 07, 2012, 02:43 AM
Brutal Sausage is offline
Find More Posts by Brutal Sausage
Brutalizer
United States, CA, San Diego
Joined Nov 2011
Scorpion HK-4025-630 (6mm Shaft) Brushless Outrunner Motor
Save $45.66! Expires June 20, 2012
Brutal Sausage is offline Find More Posts by Brutal Sausage
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 11 Feb 15, 2014 03:26 PM
Discussion what do you use as umbilical cable to your ROV? fluxno ROV - Remotely Operated Vehicles 3 Apr 01, 2011 10:46 AM
Discussion Do you wish (When you started) there were as many choices HX3D014 Electric Heli Talk 0 Jan 09, 2007 04:40 AM
Cascade Charger that will charge your battery automatically as many packs as you wish cadetman Batteries and Chargers 8 Feb 08, 2005 02:12 AM
