This thread is privately moderated by obuggy, who may elect to delete unwanted replies.
Old May 16, 2012, 02:41 PM
Joined Mar 2012
Find my codes here: http://hk.rc-international.info/swarm/redjacek (valid until May 30, 2012)
Turnigy Be Found Lost Model Beeper Save US$: 0.73
redjacek is offline Find More Posts by redjacek
Old May 16, 2012, 05:17 PM
Scratch build warbirds
Canada, NB, Beresford
Joined Mar 2011
valid till may 28th
Turnigy 2650mAh 3S 1C LLF Tx Pack (Futaba/JR)
http://www.hobbyking.com/buddy.asp?c...8-92D5C767EF27
Rhino 460mAh 2S 7.4v 20C Lipoly Pack
http://www.hobbyking.com/buddy.asp?c...1-7E2BE9D76847
TURNIGY Voltage Protector
http://www.hobbyking.com/buddy.asp?c...5-1E9A9A52238B
Nose Art - "Pacific Princess" (L/R sided)
http://www.hobbyking.com/buddy.asp?c...A-40BB35BE6B07
CNC Alloy Servo Arm Long (JR)
http://www.hobbyking.com/buddy.asp?c...1-EB826826D817
CNC Alloy Servo Arm Short (JR)
http://www.hobbyking.com/buddy.asp?c...D-4D31B69611B8
X-BLADE Spare SK-5 Steel blades (10pcs/set)
http://www.hobbyking.com/buddy.asp?c...0-7BF205554AF6
folke190d is offline Find More Posts by folke190d
Old May 16, 2012, 08:26 PM
Joined Mar 2012
Extra Codes, You can save 30.59% for all of this products ! Codes from RC-Buddy.com
High Density R/C LED Flexible Strip-Yellow (1mtr)
Savings: 44.36 % / $3.5
Price after: $4.39
Weight: 59 g
Turnigy High Density R/C LED Flexible Strip-Red (1mtr)
Savings: 15.38 % / $0.62
Price after: $3.41
Weight: 59 g
8 Point snap-off spare blades (10pcs/set)
Savings: 46.94 % / $0.23
Price after: $0.26
Weight: 81 g
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC)
Savings: 11.95 % / $0.19
Price after: $1.40
Weight: 30 g
Cheap discounts on these buddy codes use them for LED lights and more
save 3 dollars on Yellow LED strips RC buddy
hobbyking
5030 Propellers (Red) - 3xCW and 3xCCW - 6pcs per bag
Savings: 23.21 % / $0.81
Price after: $2.68
Weight: 18 g
djsoccerstar5 is offline Find More Posts by djsoccerstar5
Old May 16, 2012, 09:10 PM
130 mph :)
3d astronaut's Avatar
Joined Sep 2011
Where do you guys search for buddy codes?? The site I used to use is down
3d astronaut is offline Find More Posts by 3d astronaut
Old May 16, 2012, 09:36 PM
fly_right's Avatar
USA, NC, Stanley
Joined Sep 2008
Find my codes here: http://hk.rc-international.info/swarm/fly_right (valid until May 24, 2012)
TURNIGY Plush 60amp Speed Controller Save US$: 7.17
FPV Fiberglass Pan-Tilt Camera Mount L-Size Save US$: 1.96
Prop Saver w/ Band 2.3mm (10pcs/set) Save US$: 0.99
Prop Saver w/ Band 2mm (10pcs) Save US$: 1.50
JST-XH 3S Wire Extension 20cm (10pcs/bag) Save US$: 0.47
Turnigy 9X 2.4GHz 8Ch Receiver (V2) Save US$: 0.78
TURNIGY Plush 30amp Speed Controller Save US$: 0.84
fly_right is offline Find More Posts by fly_right
Old May 17, 2012, 05:45 AM
Singapore, Singapore
Joined Nov 2011
valid until May 31, 2012
Find my codes here: http://hk.rc-international.info/swarm/kopauk (valid until May 31, 2012)
JST-XH to JST LED Power Distribution Lead Save US$: 1.25
LED Strip with JST Connector 200mm (Red) Save US$: 0.97
Turnigy 2650mAh 3S 1C LLF Tx Pack (Futaba/JR) Save US$: 0.49
LED Strip with JST Connector 200mm (Green) Save US$: 0.97
kopauk is offline Find More Posts by kopauk
Old May 17, 2012, 01:20 PM
.Joel's Avatar
Australia, VIC, Melbourne
Joined Dec 2011
Australian Warehouse Codes!!!
Valid until June 1st
Not heaps, just two items.... they don't seem to carry much at all in their Australian warehouse in terms of variety....
ZIPPY Flightmax 2200mAh 4S1P 20C (AUS Warehouse) ( Click Here ) $16.52
NTM Prop Drive Series 28-30A 750kv / 140w (AUS Warehouse) ( Click Here ) $13.30
Regards,
Joel
.Joel is online now Find More Posts by .Joel
Old May 17, 2012, 05:25 PM
<<x USMC
r0beert0's Avatar
USA, CA, Rancho Cucamonga
Joined Jun 2010
Find my codes here: http://hk.rc-international.info/swarm/roberto (valid until May 31, 2012)
X-BLADE Spare SK-5 Steel blades (10pcs/set) Save US$: 0.63
TURNIGY Plush 6A /.8bec/6g Speed Controller Save US$: 1.27
Male Molex 1.25 to Female JR Servo Extension (1pc) Save US$: 0.20
r0beert0 is offline Find More Posts by r0beert0
Old May 17, 2012, 05:55 PM
.Joel's Avatar
Joined Dec 2011
International Warehouse!!!
BuddyCodes Valid until the 1st of June 2012!
Yes... I had a few things to check off my list tonight, one of the best deals here has to be the 1m Shrink Tube at $0.04/meter!!! You could buy 10m for 40c!
NTM Prop Drive 28 Series Accessory Pack // $1.15 // http://www.hobbyking.com/buddy.asp?c...B-4F757D2B8815
NTM Prop Drive 2830 Series Replacement Shaft // $0.45 // http://www.hobbyking.com/buddy.asp?c...2-3B61D8C64D1C
FrSky DHT 8ch DIY Telemetry Compatible Trans // $20.63 // http://www.hobbyking.com/buddy.asp?c...1-11637097E039
FrSky D8RSP 2.4Ghz Receiver (w/telemetry) // $25.28 // http://www.hobbyking.com/buddy.asp?c...7-6650258F2283
Turnigy 9X LCD Backlight Kit - White (DIY) // $3.63 // http://www.hobbyking.com/buddy.asp?c...5-71E33BB23983
TURNIGY Transmitter Strap // $0.73 // http://www.hobbyking.com/buddy.asp?c...4-10D22D0A19F3
Fiber-Optic Lights for night flying (Yellow) // $2.78 // http://www.hobbyking.com/buddy.asp?c...7-603933A04DAB
2mm Gold Connectors 10 pairs (20pc) // $1.32 // http://www.hobbyking.com/buddy.asp?c...D-EB3BC61F1085
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC) // $1.39 // http://www.hobbyking.com/buddy.asp?c...D-97C213F758C4
PolyMax 4.0mm Gold Connectors 10 PAIRS (20PC) // $2.25 // http://www.hobbyking.com/buddy.asp?c...1-5EC05A0942A4
Turnigy 3mm Heat Shrink Tube Yellow (1mtr) // $0.04 // http://www.hobbyking.com/buddy.asp?c...5-02929873C4E6
Turnigy 4mm Heat Shrink Tube Yellow (1mtr) // $0.05 // http://www.hobbyking.com/buddy.asp?c...C-8B8FA35CBB58
Turnigy 5mm Heat Shrink Tube Yellow (1mtr) // $0.06 // http://www.hobbyking.com/buddy.asp?c...6-44B49EB43642
Turnigy 30mm Heat Shrink Tube Yellow (1mtr) // $0.68 // http://www.hobbyking.com/buddy.asp?c...F-1920785CB152
Turnigy 3mm Heat Shrink Tube Black (1mtr) // $0.05 // http://www.hobbyking.com/buddy.asp?c...E-664917BB402F
Turnigy 4mm Heat Shrink Tube Black (1mtr) // $0.05 // http://www.hobbyking.com/buddy.asp?c...4-A6B068FCAC4B
Turnigy 5mm Heat Shrink Tube Black (1mtr) // $0.06 // http://www.hobbyking.com/buddy.asp?c...6-36CCF78EF1BF
Turnigy 3mm Heat Shrink Tube Red (1mtr) // $0.05 // http://www.hobbyking.com/buddy.asp?c...D-AEFE5FD0603D
Turnigy 4mm Heat Shrink Tube Red (1mtr) // $0.05 // http://www.hobbyking.com/buddy.asp?c...F-799D429ED387
Turnigy 5mm Heat Shrink Tube Red (1mtr) // $0.06 // http://www.hobbyking.com/buddy.asp?c...F-06A018232E4C
Turnigy 25mm Heat Shrink Tube Clear (1mtr) // $0.57 // http://www.hobbyking.com/buddy.asp?c...2-BED4EB91228C
Hobbyking Model Aircraft Stand (small) // $3.84 // http://www.hobbyking.com/buddy.asp?c...E-63D4C6C33893
Magnetic screws/parts Tray // $2.48 // http://www.hobbyking.com/buddy.asp?c...5-320679CBF31C
Soldering Iron 230V 80W w/ Spare Tip // $3.35 // http://www.hobbyking.com/buddy.asp?c...1-677F66726F05
Wire Cutters // $1.16 // http://www.hobbyking.com/buddy.asp?c...9-D2CBB66AF576
Mr JIG - Soldering Aid // $3.47 // http://www.hobbyking.com/buddy.asp?c...F-5D50D08EE996
Turnigy Battery Strap 330mm // $1.21 // http://www.hobbyking.com/buddy.asp?c...2-92ED7DDA05E4
Peel-n-stick foam tape. 10x5inch 4mm thick // $0.24 // http://www.hobbyking.com/buddy.asp?c...1-22CF48E173D7
Hobby King Digital Vernier Calipers 150mm // $12.34 // http://www.hobbyking.com/buddy.asp?c...3-443B8D6CE9C6
Knife Edge Reamer 0.5-10mm // $4.13 // http://www.hobbyking.com/buddy.asp?c...D-685DAB3C0BC4
Turnigy Pure-Silicone Wire 24AWG (1mtr) Yellow // $0.22 // http://www.hobbyking.com/buddy.asp?c...E-AC520CCDC85D
Old May 17, 2012, 06:37 PM
That's a funny word
NE Ohio
Joined Apr 2003
Find my codes here: http://hk.rc-international.info/swarm/gulio (valid until May 30, 2012)
TP Adapter Coversion Board W/ Polyquest Charger plug Save US$: 0.99
PQ Adapter Coversion Board W/ Polyquest Charger plug Save US$: 0.19
gulio is offline Find More Posts by gulio
Old May 17, 2012, 07:38 PM
United States, NJ, Rockaway
Joined Feb 2011
Find my codes here: http://hk.rc-international.info/swarm/memnuts (valid until May 31, 2012)
Turnigy nano-tech 180mah 2S 25~40C Lipo Pack Save US$: 0.75
Turnigy nano-tech 850mah 2S 25~40C Lipo Pack Save US$: 2.54
memnuts is offline Find More Posts by memnuts
Old May 18, 2012, 04:06 AM
That will simply buff out
Boofhead's Avatar
Australia, NSW, Kareela
Joined Jul 2001
0.2mm needle for TG-130K air brush (1pc)
[S]$1.99[/S] $0.79* (buddy<br>price 60%, -$1.2)
Twin-action air brush set.
[S]$17.99[/S] $13.05* (buddy<br>price 27%, -$4.94)
Turnigy 1300mAh 3S 30C Lipo Pack (AUS Warehouse)
[S]$13.24[/S] $8.50* (buddy<br>price 36%, -$4.74)
All my buddy-codes here
Boofhead is offline Find More Posts by Boofhead
Old May 19, 2012, 01:08 AM
Italia, Umbria, Perugia
Joined Dec 2011
Find my codes here: http://hk.rc-international.info/swarm/lillo64 (valid until June 02, 2012)
A123-6.6VB 2300mAh 2s1P Receiver Pack Save US$: 1.42
Receiver Switch (3 plug) Save US$: 1.19
icarustheflier1 is offline Find More Posts by icarustheflier1
Old May 19, 2012, 03:41 AM
Joined May 2012
Motor Turnigy XK3665-B-2300KV Brushless Inrunner: http://www.hobbyking.com/buddy.asp?c...2-12CBB5FC43EC
Y cable HXT 4mm Battery Harness 14AWG for 2 Packs in Series: http://www.hobbyking.com/buddy.asp?c...4-E1CAF28B21AA
Programing card Hobby King HKSS programming card for HK 150A ESC: http://www.hobbyking.com/buddy.asp?c...8-CE25427C7F31
Li-Po car battery Turnigy nano-tech 5800mah 2S2P 30~60C Hardcase Lipo Pack: http://www.hobbyking.com/buddy.asp?c...B-46392366350B
HXT 4mm Gold Connector w/ Protector (10pcs/set): http://www.hobbyking.com/buddy.asp?c...A-E1DB6303CDE4
Valid 11 days from now.
hellwheels is offline Find More Posts by hellwheels
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 5 May 18, 2011 01:38 PM
Discussion what do you use as umbilical cable to your ROV? fluxno ROV - Remotely Operated Vehicles 3 Apr 01, 2011 10:46 AM
Discussion Do you wish (When you started) there were as many choices HX3D014 Electric Heli Talk 0 Jan 09, 2007 04:40 AM
Cascade Charger that will charge your battery automatically as many packs as you wish cadetman Batteries and Chargers 8 Feb 08, 2005 02:12 AM
