This thread is privately moderated by obuggy, who may elect to delete unwanted replies.
Old Apr 14, 2012, 04:56 PM
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Find my codes here: http://hk.rc-international.info/swarm/pavcon (valid until April 28, 2012)
Futaba/JR Connector caps (5pcs/set) Save US$: 0.84
pavcon is offline Find More Posts by pavcon
Old Apr 15, 2012, 03:06 AM
Italia, Umbria, Perugia
Joined Dec 2011
Find my codes here: http://hk.rc-international.info/swarm/lillo64 (valid until April 29, 2012)
JXF 11x7 / 279 x 178mm Poly Composite propeller Save US$: 0.76
icarustheflier1 is offline Find More Posts by icarustheflier1
Old Apr 15, 2012, 11:02 AM
Bond, Hotglue Bond
Tartago's Avatar
Joined Apr 2006
Find my codes here: http://hk.rc-international.info/swarm/tartago (valid until April 27, 2012)
Brass Nut for Spinners M6x1-M4 Save US$: 0.12
FPV Fiberglass Pan-Tilt Camera Mount Save US$: 0.94
Tartago is offline Find More Posts by Tartago
Old Apr 15, 2012, 01:48 PM
Bastrop, La
Joined Dec 2008
Today's Codes
Should be good thru April 28th.
NTM Prop Drive 35 Series Accessory Pack
http://www.hobbyking.com/buddy.asp?c...A-A98B71F8FB0B
Propeller Adapter (Colet Type) 3MM
http://www.hobbyking.com/buddy.asp?c...3-556D93BCBF34
Turnigy 3mm Heat Shrink Tube Yellow (1mtr)
http://www.hobbyking.com/buddy.asp?c...8-390B00A27CE0
Receiver Wrap Yellow
http://www.hobbyking.com/buddy.asp?c...A-DE364DEBC281
Master Airscrew propeller 7x5.5
http://www.hobbyking.com/buddy.asp?c...D-30610254794C
HobbyKing Cell Key - 6s Lipoly Cell checker
http://www.hobbyking.com/buddy.asp?c...6-1AF8394626C2
Adjustable Engine Mounts (Large: 40-70 Size)
http://www.hobbyking.com/buddy.asp?c...D-ED29A3BD1081
Hobby King Discovery Buzzer
http://www.hobbyking.com/buddy.asp?c...9-D7D9E9EAAEB7
Turnigy Be Found Lost Model Beeper
http://www.hobbyking.com/buddy.asp?c...2-614B16BBAA92
TGY Slow Fly Prop 8*3.8SF w/ shaft adapters
http://www.hobbyking.com/buddy.asp?c...0-31862029BE38
Pocket Glow Igniter Charger
http://www.hobbyking.com/buddy.asp?c...D-509A71BEA1E1
stumblebum is offline Find More Posts by stumblebum
Last edited by stumblebum; Apr 15, 2012 at 01:57 PM. Reason: Added more codes.....
Old Apr 15, 2012, 02:28 PM
Canada, BC, Nanaimo
Joined Oct 2006
Assan receiver, quadcopter props, nylon parts and servo wire
Find my codes here: http://hk.rc-international.info/swarm/mantraguy (valid until April 29, 2012)
X8 R4 4Ch 2.4GHz Receiver Save US$: 4.04
10X6 Propellers (Standard and Counter Rotating) (6pc) Save US$: 1.25
M3 x 20mm Nylon Screws (10pcs/bag) Save US$: 0.26
5.6mm x 30mm M3 Nylon Tapped Spacer (10pc) Save US$: 0.89
M4 Nylon Nut (10pcs/bag) Save US$: 0.21
Flat 26AWG servo wire 1mtr (R/B/Y) Save US$: 0.73
mantraguy is offline Find More Posts by mantraguy
Old Apr 15, 2012, 03:30 PM
Joined Aug 2011
Extra Codes, You can save 35.96% for all of this products with:http://rc-buddy.com/user/Stewie! Codes from RC-Buddy.com
8x4 Propellers (5Pcs/Bag)
Savings: 35.96 % / $0.82
Price after: $1.46
Weight: 75 g
Extra Codes, You can save 68.69% for all of this products with:http://rc-buddy.com/user/Stewie! Codes from RC-Buddy.com
Spare Rubber Ring for Prop Saver (10pcs)
Savings: 68.69 % / $0.68
Price after: $0.31
Weight: 11 g
cs373 is offline Find More Posts by cs373
Old Apr 15, 2012, 11:10 PM
Newcastle. Australia
Joined Jan 2004
Find my codes here: http://hk.rc-international.info/swarm/pc55bomber (valid until April 30, 2012)
6 LED Strip White Save US$: 0.68
3 LED Strip White Save US$: 0.59
3 LED Strip BLUE Save US$: 0.59
3 LED Strip Red Save US$: 0.59
3 LED Strip GREEN Save US$: 0.41
JST Male 2 pin connector set (10pcs/set) Save US$: 0.38
JST Female 2 pin connector set (10pcs/set) Save US$: 0.24
Transmitter Neck Strap Balancer (JR/Spektrum/Hitec) Save US$: 0.39
Mystery 30A BEC Brushless Speed Controller (Blue Series) Save US$: 1.10
flitetest T-Shirt You cannot fly this plane - Black (Large) Save US$: 2.11
PC55 is offline Find More Posts by PC55
Old Apr 16, 2012, 01:57 AM
Joined Mar 2010
C-Clip Ring Plier 4 in 1 set
http://www.hobbyking.com/buddy.asp?c...1-019CB8A27897
Slow Fly Electric Prop 8045R (4 pc - Green)
http://www.hobbyking.com/buddy.asp?c...B-071A19B4344A
Slow Fly Electric Prop 8045R SF (4 pc)
http://www.hobbyking.com/buddy.asp?c...0-8468DD31EE0D
Slow Fly Electric Prop 8045SF (4 pc)
http://www.hobbyking.com/buddy.asp?c...0-F26BCD6E335D
Silicon fuel pipe (1 mtr) Yellow for Gas/Nit
http://www.hobbyking.com/buddy.asp?c...F-0D8D0F728513
12 LED Cluster - ORANGE
http://www.hobbyking.com/buddy.asp?c...1-C8B527EEC26B
Turnigy Pure-Silicone Wire 24AWG (1mtr) Black
http://www.hobbyking.com/buddy.asp?c...4-FDA0160619DD
Turnigy Pure-Silicone Wire 24AWG (1mtr) Red
http://www.hobbyking.com/buddy.asp?c...F-9B7AD8832EC2
Wire Mesh Guard Orange 6mm (1mtr)
http://www.hobbyking.com/buddy.asp?c...6-1C8DB3A0B8BC
Hex locknuts M3 10pc
http://www.hobbyking.com/buddy.asp?c...B-C8336D8D0F8B
Valid for 13 days from the day of posting
daddoo is offline Find More Posts by daddoo
Old Apr 16, 2012, 07:39 AM
soebhemo's Avatar
jakarta
Joined May 2010
Use as you wish....
EPP-FPV 1.8M X-Large EPP & Carbon Fiber R/C
http://www.hobbyking.com/buddy.asp?c...2-396EFD6172AC
Turnigy MG930 Digital Metal Gear Servo 3.6kg
http://www.hobbyking.com/buddy.asp?c...9-B2816965F40C
BMS-136MG Retract Servo (Metal Gear) 6.1kg
http://www.hobbyking.com/buddy.asp?c...6-030B1AFD6242
is
soebhemo is offline Find More Posts by soebhemo
Old Apr 16, 2012, 09:46 AM
United States, MO, Fenton
Joined Jan 2012
Hobby King multi rotor control board
http://www.hobbyking.com/buddy.asp?c...A-1229621A7165
Fentonflyers is offline Find More Posts by Fentonflyers
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 5 May 18, 2011 01:38 PM
Discussion what do you use as umbilical cable to your ROV? fluxno ROV - Remotely Operated Vehicles 3 Apr 01, 2011 10:46 AM
Discussion Do you wish (When you started) there were as many choices HX3D014 Electric Heli Talk 0 Jan 09, 2007 04:40 AM
Cascade Charger that will charge your battery automatically as many packs as you wish cadetman Batteries and Chargers 8 Feb 08, 2005 02:12 AM
