This thread is privately moderated by obuggy, who may elect to delete unwanted replies.
Old Mar 24, 2012, 02:28 PM
lex800 is offline
Find More Posts by lex800
lex800's Avatar
Russia, Saint Petersburg, g. Sankt-Peterburg
Joined Jun 2010
Find my codes here: http://hk.rc-international.info/swarm/lex800 (valid until April 07, 2012)
Pushrod Snap-On Link 144pc 1,1.4,1.6,2.0mm Save US$: 3.32
Control Arms 43x13x24x3mm (5pcs/bag) Save US$: 0.58
Micro Control Rod Rocker Horn (7mm x 3mm - 10pcs) Save US$: 0.23
Micro Control Rod Keeper (10mm long - 10pcs) Save US$: 0.15
Nylon Snap-Click style clevis 2x8x23mm (10pc) Save US$: 0.31
Control Rod Window L38xH4.5mm (10pcs) Save US$: 0.97
Clear Foam Glue (Medium Cure) - Large 100ml Save US$: 0.12
BMS-371DD Digital Micro Servo 1.2kg / .10sec / 6g Save US$: 1.25
lex800 is offline Find More Posts by lex800
Old Mar 25, 2012, 10:43 AM
dosan71 is offline
Find More Posts by dosan71
Joined Mar 2012
http://www.hobbyking.com/buddy.asp?c...B-8FB4D3D70780
dosan71 is offline Find More Posts by dosan71
Old Mar 25, 2012, 11:20 AM
CrashingDutchman is offline
Find More Posts by CrashingDutchman
CrashingDutchman's Avatar
The Netherlands, Utrecht, Amersfoort
@dosan71: Nobody is going to click just buddy codes without knowing what they are. I added them to my buddy code site. The site generates forum code that you can just copy/past into the various forums you use.
This is the result:
Find my codes here: http://hk.rc-international.info/swarm/dosan71 (valid until April 08, 2012)
Master Airscrew propeller 9x7 Save US$: 2.88
Indian Decal Sheet Save US$: 0.22
Nose Art "Eagle Punch" L/R handed Save US$: 0.60
Decal Sheet Small Chequer Pattern Black/Clear 590mmx180mm Save US$: 0.80
Decal Sheet Chequer Pattern Red/Clear 590mmx180mm Save US$: 0.80
Nose Art - "Charlies Heavy" L/R Side Save US$: 0.60
Star Red Various Sizes Decal Sheet 425mmx300mm Save US$: 1.36
Light Foam Wheel (Diam: 40, Width: 12mm) (5pcs/bag) Save US$: 0.45
Light Foam Wheel (Diam: 40, Width: 11mm) (5pcs/bag) Save US$: 0.44
Scale alloy hub rubber wheel 4.0inch Save US$: 0.74
CrashingDutchman is offline Find More Posts by CrashingDutchman
Old Mar 25, 2012, 10:55 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
GWS EP Propeller (RD-8060 203x152mm) (6pcs/set)
[S]$4.21[/S] $3.05* (discount 28%, -$1.16)
3drcparts is offline Find More Posts by 3drcparts
Old Mar 26, 2012, 01:54 AM
scub is offline
Find More Posts by scub
United States, MA, Springfield
Joined Dec 2010
ZIPPY 350mAh 20C single cell Save US$: 1.02
scub is offline Find More Posts by scub
Old Mar 26, 2012, 04:10 AM
greenfeet is offline
Find More Posts by greenfeet
greenfeet's Avatar
Australia, SA, Yankalilla
Find my codes here: http://hk.rc-international.info/swarm/trippergreenfeet (valid until April 09, 2012)
HK-310 3 Channel 2.4ghz FHSS Ground Radio Save US$: 2.62
2848SL 3900kv Brushless Inrunner (WaterCooled) Save US$: 5.01
Carbon Fiber Tissue (Fine 10g/m2) 1mtr Save US$: 0.99
Peel-n-stick foam tape. 10x5inch 4mm thick Save US$: 1.25
Silicon fuel pipe (1 mtr) Yellow 6x3mm Save US$: 0.60
greenfeet is offline Find More Posts by greenfeet
Old Mar 26, 2012, 06:27 AM
schumixmd is offline
Find More Posts by schumixmd
schumixmd's Avatar
Moldova
Joined Jun 2010
Find my codes here: http://hk.rc-international.info/swarm/schumixmd (valid until April 09, 2012)
Battery Strap - Go-Kart Save US$: 0.19
Spare Rubber Ring for Prop Saver (10pcs) Save US$: 0.68
Folding Propeller Assembly 9x5 (Alloy/Hub Spinner) (1pc/bag) Save US$: 0.74
Turnigy 20A BRUSHED ESC Save US$: 0.66
schumixmd is offline Find More Posts by schumixmd
Old Mar 26, 2012, 06:50 AM
ceandre is offline
Find More Posts by ceandre
Joined Jul 2010
FMA Co-Pilot 2-Channel Flight Stabilization System - IN STOCK - $48.14
http://www.hobbyking.com/buddy.asp?c...E-75D66B79B61A
http://www.hobbyking.com/buddy.asp?c...4-095EDA93EBDB
Turnigy Mini Anemometer (Wind Meter) - $16.71*
http://www.hobbyking.com/buddy.asp?c...7-6E4E7952DA8C
ceandre is offline Find More Posts by ceandre
Old Mar 26, 2012, 07:51 AM
gionir is offline
Find More Posts by gionir
The stalling italian
gionir's Avatar
France, RA, Lyon
Joined Jan 2011
Find my codes here: http://hk.rc-international.info/swarm/gionir (valid until April 09, 2012)
Mini Swift R/C EPO Glider Plug-n-Fly w/ crash-kit (DE Warehouse) Save US$: 7.86
Turnigy 500mAh 2S 20C Lipo Pack (DE Warehouse) Save US$: 1.38
gionir is offline Find More Posts by gionir
Old Mar 26, 2012, 08:29 AM
shkimran is offline
Find More Posts by shkimran
Joined Oct 2011
Find my codes here: http://hk.rc-international.info/swarm/shkimran (valid until April 09, 2012)
APC Style Propeller 8x6 (2 pc) Save US$: 0.21
APC Style Propeller 9x6 (2 pc) Save US$: 0.25
APC style propeller 9x6-E Save US$: 0.39
Linkage Stopper M3x2xL11.2mm (10pcs/set) Save US$: 0.55
Flap Hinge 0.46 size model up (1pc) Save US$: 0.12
Front Wheel Steering Arm and Mount Set 32mm (5sets) Save US$: 0.71
Nylon and Pinned Hinge 16x28.5 (10pcs) Save US$: 0.37
Nylon and Pinned Hinge 20x36 (10pcs) Save US$: 0.29
Control Horns 13.5x16mm (10pcs) Save US$: 0.36
Steering Arms (1/2 Arm) 10x 21mm (5pcs/set) Save US$: 0.42
Nylon Arm 2.5 x 5 x 6 (10pcs) Save US$: 0.43
Nylon Arm 2.8 x 5 x 6 (10pcs/set) Save US$: 0.12
Carbon Fiber Rod (solid) 2.5x750mm Save US$: 0.87
Carbon Fiber Square Tube 750x6mm Save US$: 0.85
Carbon Strip 1x3x750mm (5pcs/set) Save US$: 1.47
8 Point snap-off spare blades (10pcs/set) Save US$: 0.23
Strong Rare-Earth Button Magnets (10pcs/set) Save US$: 0.89
2 in 1 Magnetizer and Demagnetizer Tool Save US$: 0.40
General Purpose L Bracket (5pcs/bag) Save US$: 1.15
5x5mm Grub Screw (10pcs/pack) Save US$: 0.82
Landing Gear Wheel Stop Set Collar 6x2.1mm (10pcs) Save US$: 0.50
Landing Gear Wheel Stop Set Collar 8x3.1mm (10pcs) Save US$: 0.50
Landing Gear Wheel Stop Set Collar 6x5.1mm (10pcs) Save US$: 0.50
Nylon Screws 6x60mm (10pcs) Save US$: 0.32
Carbon Fiber Tube (hollow) 3x2x750mm Save US$: 0.73
Carbon Fiber Rod (solid) 2.0x750mm Save US$: 0.73
Master Airscrew propeller 8x6 Save US$: 0.55
Master Airscrew propeller 9x6 Save US$: 0.64
Twin-action fine needle pistol air brush set Save US$: 4.09
Turnigy Covering Film Iron. Save US$: 0.82
Nylon Snap-Click style clevis 10pc Save US$: 0.64
Nylon and Pinned Hinge 26.5x36 (10pcs/bag) Save US$: 0.77
Self-Tapping/Machine Screws W/Shoulder 2x12 (bag of 100pc) Save US$: 0.73
Self-Tapping Screws 2.5x10 (bag of 100pc) Save US$: 0.73
Self-Tapping Screws 2.5x14 (bag of 100pc) Save US$: 0.73
Self-Tapping Screws 3x12 (bag of 100pc) Save US$: 0.73
Self-Tapping Screws 3x20 (bag of 100pc) Save US$: 0.73
shkimran is offline Find More Posts by shkimran
Old Mar 26, 2012, 02:05 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
lol
pavcon is offline Find More Posts by pavcon
Old Mar 26, 2012, 04:34 PM
vindego is offline
Find More Posts by vindego
Joined Mar 2012
FrSky 7dbi patch antenna
http://www.hobbyking.com/buddy.asp?c...7-2EF8D7E9F231
vindego is offline Find More Posts by vindego
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 11 Feb 15, 2014 03:26 PM
Discussion what do you use as umbilical cable to your ROV? fluxno ROV - Remotely Operated Vehicles 3 Apr 01, 2011 10:46 AM
Discussion Do you wish (When you started) there were as many choices HX3D014 Electric Heli Talk 0 Jan 09, 2007 04:40 AM
Cascade Charger that will charge your battery automatically as many packs as you wish cadetman Batteries and Chargers 8 Feb 08, 2005 02:12 AM
