This thread is privately moderated by obuggy, who may elect to delete unwanted replies.
Old Mar 22, 2012, 04:57 AM
aeae99's Avatar
Sweden, Stockholm County, Stockholm
Joined Aug 2011
AX 1806N 2500kv Brushless Micro Motor (19g)
http://www.hobbyking.com/buddy.asp?c...A-CE79C7C983A4
TURNIGY Plush 10amp 9gram Speed Controller
http://www.hobbyking.com/buddy.asp?c...2-DE77A1F2B235
Turnigy nano-tech 370mah 3S 25~40C Lipo Pack
http://www.hobbyking.com/buddy.asp?c...D-410449ED8A6F
3mm Prop Saver w/ Adapter & 3 bands
http://www.hobbyking.com/buddy.asp?c...7-B891FC7FC076
Turnigy 2mm Heat Shrink Tube - BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?c...A-A3DC5FC6BB1C
Turnigy 5mm Heat Shrink Tube - BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?c...6-A8607DD8BD62
aeae99 is offline Find More Posts by aeae99
Old Mar 22, 2012, 06:51 AM
Joined Mar 2006
Prop adapter w/ Steel Nut 1/4x28-M4mm shaft
http://www.hobbyking.com/buddy.asp?c...3-98E736B75412
eLviSH is offline Find More Posts by eLviSH
Old Mar 22, 2012, 07:45 AM
seojeff's Avatar
United States, GA, Atlanta
Joined Aug 2011
Find my codes here: http://hk.rc-international.info/swarm/seojeff (valid until March 29, 2012)
Turnigy Aerodrive SK3 3548 Series Replacement Shaft Set Save US$: 1.09
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC) Save US$: 0.19
2mm Gold Connectors 10 pairs (20pc) Save US$: 0.66
40CM Servo Lead (Futaba) 32AWG Ultra Light (10pcs/set) Save US$: 0.80
GWS HD9050 3 Blade Prop Counter Rotate (2pc) Save US$: 0.29
Turnigy AE-30A Brushless ESC Save US$: 1.59
X3 UBEC 6v-23v input - 5v 3A Output Save US$: 2.53
seojeff is offline Find More Posts by seojeff
Old Mar 22, 2012, 02:47 PM
Joined Oct 2011
FrSky DF 2.4Ghz Combo Pack for JR w/ Module and RX (V2) Save US$: 7.26
HXT900 Replacement Gear Set Save US$: 0.41
shein is offline Find More Posts by shein
Old Mar 22, 2012, 09:22 PM
United States, MO, Fenton
Joined Jan 2012
X83 Flyjet
http://www.hobbyking.com/buddy.asp?c...3-7A9971A95273
HX 5010 servo
http://www.hobbyking.com/buddy.asp?c...7-E1B16A04D645
Fentonflyers is offline Find More Posts by Fentonflyers
Old Mar 22, 2012, 10:07 PM
Henchmen wanted. Send Resume.
TomM's Avatar
State College PA
Joined Jul 2002
http://www.hobbyking.com/buddy.asp?c...1-698A7C5F8329
5 Amp Switching BEC to 26V $3.99
http://www.hobbyking.com/buddy.asp?c...3-5826D60F1381
5 Amp Switching BEC to 40V $5.25
Futaba connector "Y" servo leads 30cm. Pack of 5/
NOT $3.99 but $2.77.
TomM is offline Find More Posts by TomM
Old Mar 22, 2012, 10:13 PM
TomM's Avatar
State College PA
Joined Jul 2002
http://www.hobbyking.com/buddy.asp?c...F-D486E22B5CFD
4S 3300 $8.10 off = $27.52
Old Mar 23, 2012, 02:57 AM
Born again sloper
ShaneH's Avatar
Australia, NSW, Bensville
Joined Aug 2011
Find my codes here: http://hk.rc-international.info/swarm/shaneh (valid until April 06, 2012)
Washers #4(bag of 100pc) Save US$: 0.73
Socket Head Bolt 4x20mm Save US$: 0.79
Socket Head Bolt 4x16mm Save US$: 0.79
Hex locknuts M4 10pc Save US$: 0.50
GWS EP Propeller (DD-7035 178x89mm) (6pcs/set) Save US$: 1.07
GWS EP Propeller (DD-6030 152x76mm) (6pcs/set) Save US$: 1.01
Peel-n-stick foam tape. 10x5inch 4mm thick Save US$: 1.25
Turnigy Teflon Coated Wire 36AWG (1mtr) Black Save US$: 0.36
Glass Fiber Cloth 500x1000mm (Light weight) Save US$: 1.52
ShaneH is offline Find More Posts by ShaneH
Old Mar 23, 2012, 08:09 AM
Master of disaster
bartwaw's Avatar
Polska, Śląskie, Zabrze
Joined May 2006
Here's mine:
Light Foam Wheel Diam: 28, Width: 12mm (5pcs/bag)
http://www.hobbyking.com/buddy.asp?c...C-675E44C64E78
HK600GT tail boom (HN6031)
http://www.hobbyking.com/buddy.asp?c...4-101180308DC4
Turnigy Battery Strap 330mm
http://www.hobbyking.com/buddy.asp?c...7-3EDF65CD8F56
Turnigy Accucel-6 50W 6A Balancer/Charger w/ accessories
http://www.hobbyking.com/buddy.asp?c...8-3999E8CF3C29
FrSky D8R-II 2.4Ghz 8CH Receiver with Telemetery
http://www.hobbyking.com/buddy.asp?c...A-BB81A713DC93
BMS-821DMG+HS High Performance Digital Servo (Metal Gear) 6.4kg / .11sec / 45g
http://www.hobbyking.com/buddy.asp?c...1-A0CC6877C498
ZIPPY Compact 4500mAh 4S 35C Lipo Pack
http://www.hobbyking.com/buddy.asp?c...0-C4A0527B3C22
Battery Strap
http://www.hobbyking.com/buddy.asp?c...1-46DE0F364757
FrSky FLD-02 Telemetry Display Screen
http://www.hobbyking.com/buddy.asp?c...7-8295AEB03787
Nylon T-Connectors Male (10pcs/Bag)
http://www.hobbyking.com/buddy.asp?c...3-BF09303A56DB
Nylon T-Connectors Female (10pcs/Bag)
http://www.hobbyking.com/buddy.asp?c...0-C54FADDD1ED3
bartwaw is offline Find More Posts by bartwaw
Old Mar 23, 2012, 09:39 AM
Australia, VIC, Narre Warren
Joined Jun 2011
30CM Servo Lead (Futaba) 32AWG Ultra Light (10pcs/set)
http://www.hobbyking.com/buddy.asp?c...3-CD2B357CD711
planex is offline Find More Posts by planex
Old Mar 23, 2012, 11:06 AM
Joined Mar 2012
My Codes list!!!
NTM2826-1200 NTM Prop Drive Series 28-26A 1200kv / 250w
http://www.hobbyking.com/buddy.asp?c...A-D2E2AEACFAB3
TR_P25A TURNIGY Plush 25amp Speed Controller
http://www.hobbyking.com/buddy.asp?c...D-EF65D260E9ED
Z44003S15C ZIPPY Flightmax 4400mAh 3S1P 15C
http://www.hobbyking.com/buddy.asp?c...2-1D01D38BE476
QUAD-CON16K HobbyKing Multi-Rotor Control Board V2.1 (At
http://www.hobbyking.com/buddy.asp?c...E-FC0942A4BF7B
9171000033 Hobby King Quadcopter Power Distribution Boa
http://www.hobbyking.com/buddy.asp?c...0-FD3B4C3842EC
HK-T6A-M1 Hobby King 2.4Ghz 6Ch Tx & Rx V2 (Mode 1)
http://www.hobbyking.com/buddy.asp?c...3-787A388F3777
Turnigy-3S Turnigy balancer & Charger 2S-3S
http://www.hobbyking.com/buddy.asp?c...2-748CD72F8A02
067000002 On-Board Lipoly Low Voltage Alarm 2s~3s
http://www.hobbyking.com/buddy.asp?c...F-C55189B9AF76
http://www.hobbyking.com/buddy.asp?c...3-153ED16B6143
Turnigy Talon Alloy Motor Mount Block (2pcs/
http://www.hobbyking.com/buddy.asp?c...7-D6601DCFAFAF
Turnigy Talon Carbon Fiber Boom 243mm (1pc/b
http://www.hobbyking.com/buddy.asp?c...B-05DB7D8CA44B
9323000005 Turnigy Talon Carbon Fiber Main Frame Upper
http://www.hobbyking.com/buddy.asp?c...3-41D0F3D8B6A4
9323000006 Turnigy Talon Carbon Fiber Main Frame Lower
http://www.hobbyking.com/buddy.asp?c...3-BAA6D586B2F9
9323000007 Turnigy Talon Carbon Fiber Landing Gear (2pc
http://www.hobbyking.com/buddy.asp?c...7-BAA26A539B1B
9323000008 Turnigy Talon Carbon Fiber Boom 498mm (1pc/b
http://www.hobbyking.com/buddy.asp?c...3-1A255AE75B1D
froguz is offline Find More Posts by froguz
Old Mar 23, 2012, 08:13 PM
Sverige, Södermanlands Län, Eskilstuna
HK Buddy Codes
http://www.hobbyking.com/buddy.asp?c...A-BC3D51FAF6CB
Turnigy Be Found Lost Model Beeper
http://www.hobbyking.com/buddy.asp?c...3-28AF6BF4279C
Petrik59 is offline Find More Posts by Petrik59
Old Mar 24, 2012, 03:17 AM
Joined Oct 2009
HK Buddy Codes
Find my codes here: http://hk.rc-international.info/swarm/whitejoy (valid until April 07, 2012)
USB Simulator Cable Phoenix RC Save US$: 2.86
HK450V2 Main Shaft Save US$: 2.04
HK450V2 Metal Tail Boom Holder Save US$: 0.71
HK450V2 Tail Boom Save US$: 0.74
HK450V2 Timing Belt Save US$: 0.37
HK450V2 Feathering Shaft Set (41x4mmxM2) Save US$: 2.14
HK450V2 Stabilizer Bar Save US$: 0.63
HK450V2 Stabilizer Control Arm Set Save US$: 1.05
HK450V2 Wash-Out Base Save US$: 0.58
whitejoy is offline Find More Posts by whitejoy
Old Mar 24, 2012, 01:30 PM
Joined Aug 2011
Extra Codes, You can save 34.81% for all of this products with:http://rc-buddy.com/user/Medo! Codes from RC-Buddy.com
TP Slow Fly propeller 9x4.7
Savings: 14.49 % / $0.1
Price after: $0.59
Weight: 27 g
Small Wheel Diam: 25mm Width: 13mm (5pcs/bag)
Savings: 47.32 % / $0.53
Price after: $0.59
Weight: 19 g
dolino is offline Find More Posts by dolino
Alert Hobbyking BuddyPrice Code $12.20 for 560w NTM motor lrplin Hot Online Deals 5 May 18, 2011 01:38 PM
Discussion what do you use as umbilical cable to your ROV? fluxno ROV - Remotely Operated Vehicles 3 Apr 01, 2011 10:46 AM
Discussion Do you wish (When you started) there were as many choices HX3D014 Electric Heli Talk 0 Jan 09, 2007 04:40 AM
Cascade Charger that will charge your battery automatically as many packs as you wish cadetman Batteries and Chargers 8 Feb 08, 2005 02:12 AM
