Old Apr 21, 2011, 12:49 PM
SpookiePower is offline
Find More Posts by SpookiePower
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
Did my first FPV flight today, but still have some video range problems
Today I did my very first FPV flight, and it went ok for a first flight. But I still have some problems with the video gone bad, at about 400 meters away from ground station.
I'm using a 500mw Lawmate Video Tx/Rx and a 8 dbi CP antenna. My Video tx is located at the tail on my EasyStar, and I use a ferritring and a capacitor before my camera - which is located in the nose of my plane. I only use one Lipo to power all gear/motor. For controlling the plane, I'm using Thomas's Scherrer 433Mhz LRS.
I'm almost out of ideas, of what to do, to get a better range.
On my CP antenna, I have the long wire running to my video Rx. I have been told to make it shorter, and on my FPV pod, the wire running from the lipo to the camera, might be a bite too long. But could those two wires (pod and CP antenna) prevent me from getting a video range at more than 400 meters ?
I have added some photos of my setup.
SpookiePower is offline Find More Posts by SpookiePower
Old Apr 21, 2011, 12:57 PM
techspy is offline
Find More Posts by techspy
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Since you are using one battery for everything, have you checked to see what the voltage going to your video TX is at when your motor is running? If it goes down from 12v, that could be an issue. I had a similar situation. You can add a small 800mah, 3s lipo just for your video equipment and see if that helps. Otherwise, you can try something like this. I have one and it works great.
http://www.dpcav.com/xcart/product.p...cat=252&page=1
techspy is offline Find More Posts by techspy
Old Apr 21, 2011, 01:04 PM
lovegroove is offline
Find More Posts by lovegroove
http://drone-pilot.blogspot.fr
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
With a 500mW video tx, you should be able to get 400m with no antenna on the receiver. I'd suggest that something is seriously wrong with your setup. Are you sure that the cable from the patch has the correct sort of plug? Sometimes they come with RP-SMA connectors that don't have the centre pin, but the plugs will still mate together.
lovegroove is offline Find More Posts by lovegroove
Old Apr 21, 2011, 01:06 PM
Blackrat is offline
Find More Posts by Blackrat
Registered Loon
Blackrat's Avatar
South Africa, WC, Knysna
Joined May 2006
i struggled with range with the std rubber antennae , do yourself a favour and make an inverted V , made my video 100% better
Blackrat is offline Find More Posts by Blackrat
Old Apr 21, 2011, 01:47 PM
Art Newland is offline
Find More Posts by Art Newland
CD-ROM Junkie
Art Newland's Avatar
United States, WA, Bellingham
Joined Apr 2001
"On my CP antenna" does this mean circular polarized?
Art Newland is offline Find More Posts by Art Newland
Old Apr 21, 2011, 02:09 PM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
Yes
Old Apr 21, 2011, 02:11 PM
Oddmar is offline
Find More Posts by Oddmar
Out of the way, Peck!
United States, AR, Arkadelphia
Joined Mar 2010
In the middle picture it looks like a stock rubber duck antenna on the video tx on the plane...those antennas generally suck.
Try bending up one of IBCrazy's 3-lobe Cloverleaf antennas with a short 12" lead between it and the video TX for the plane, and bend up a 4-lobe Skew Planar Wheel antenna for the groundstation video RX.
Also, having a 'long wire' between the receiving antenna and the video receiver is bad...at higher frequencies long coax leads 'attenuate', or reduce, signal strength. Probably no more than 12" to 18" is best.
If you want to mount your groundstation video rx up high for better signal like i do, use a short coax between the antenna and the rx, and a long video rca cable pumping a video signal from the rx to the LCD or goggles.
I don't run 900mhz for video, so i'll leave it up to other people to tell you whether you need a dual-notch filter between the plane's video tx and it's antenna. And are you running an LC filter between the battery and your avionics if you are using a single battery?
Oddmar is offline Find More Posts by Oddmar
Old Apr 21, 2011, 02:53 PM
Joined Jun 2009
I have thought about using two lipos, but I'm using a LC filter to prevent noise getting to the camera. The noise in the picture, only gets there, when I reach about 400 meters - if I turn back again, the picture is perfect.
My camera should work between 10.8v - 13.2v and I only fly on fully charged lipos.
Old Apr 21, 2011, 02:55 PM
Joined Jun 2009
I just checked my CP antenna. I have the center pin.
Old Apr 21, 2011, 02:57 PM
Joined Jun 2009
I don't know anything about the inverted V antenna, but it sounds like something to go for. But I'm not using the stock rubber antenna on my video Rx.
Old Apr 21, 2011, 02:59 PM
NDw is offline
NDw
Find More Posts by NDw
NDw
Ireland, Limerick, Kilmallock
Joined Aug 2010
nvm, misread
NDw is offline Find More Posts by NDw
Old Apr 21, 2011, 03:01 PM
Joined Jun 2009
Yes, it is the stock rubber antenna.
I have the long wire from my Rx CP antenna to my video Rx. I will try to make i shorter before my next flight.
Yes I use a LC filter between Lipo and the camera.
Old Apr 21, 2011, 04:02 PM
jkarnacki is offline
Find More Posts by jkarnacki
USA, CA, San Carlos
Joined Nov 2007
Surprised nobody has asked this yet...where are you flying? (what type of terrain)
- Jeff
jkarnacki is offline Find More Posts by jkarnacki
Old Apr 22, 2011, 01:38 AM
paintball_kidz is offline
Find More Posts by paintball_kidz
Epic Huckin'
paintball_kidz's Avatar
Surrey, BC
Joined Jun 2007
LC filter should be between lipo and vtx, no?
Also is that stock antenna linear?
paintball_kidz is offline Find More Posts by paintball_kidz
Old Apr 22, 2011, 02:03 AM
Joined Jun 2009
- Jeff
Later today I will post some photos from my flying field.
Discussion First ATTOPILOT flight in my Cessna 182 today billh117 UAV - Unmanned Aerial Vehicles 17 Apr 27, 2011 11:40 PM
Discussion My Slick 51 Maiden Flight but with problems Elec 1800 3D Flying 18 Apr 01, 2011 12:13 PM
Discussion Yeah, I know it's wrong but they did it first! NoFlyZone Life, The Universe, and Politics 82 Mar 31, 2011 12:19 AM
Rave Finally did my first flight today, on my corona Patrick Plawner Electric Heli Talk 17 Jan 01, 2004 03:13 PM
