Old Apr 21, 2011, 10:55 AM
mikes68charger is offline
Find More Posts by mikes68charger
Why kamikaze pilot wear helmet
mikes68charger's Avatar
United States, IL, Rock Island
Joined Jul 2010
Toe in or Toe Out on War bird front landing gear?
Ok, wich way is more stable for landing and take off.
Is it better to have your wheels a little toed in or out?
I know stright ahead would be great. LOL
mikes68charger is offline Find More Posts by mikes68charger
Old Apr 21, 2011, 11:07 AM
800mZero is offline
Find More Posts by 800mZero
3DHS Junkie
800mZero's Avatar
Rhode Island
Joined Jun 2005
toe in
800mZero is offline Find More Posts by 800mZero
Old Apr 21, 2011, 09:25 PM
wellington53 is offline
Find More Posts by wellington53
Glenn
wellington53's Avatar
United States, WI, Oconto Falls
Joined Jan 2004
Second the toe in.
wellington53 is offline Find More Posts by wellington53
Old Apr 21, 2011, 10:08 PM
Joined Jul 2010
thanks
Old Apr 21, 2011, 10:15 PM
P40D is offline
Find More Posts by P40D
Auctung! P-40!
P40D's Avatar
Winnipeg, Manitoba, CANADA
Joined Mar 2010
depends.. narrow gear like the P-40 & Bf 109, toe-out. just like the real ones.
P40D is offline Find More Posts by P40D
Old Apr 22, 2011, 02:53 AM
twmonroe is offline
Find More Posts by twmonroe
Joined Mar 2011
Agree with P40 on that one..tow in on narrow gear...more likely to nose over..they toed em out in the idea that it would help...
Mustang was toed in
TM
twmonroe is offline Find More Posts by twmonroe
Old Apr 22, 2011, 10:12 AM
Joined Jul 2010
So Would the tow in or out effect take off?
I have a 540T Edge, When I take off, I have to use some/alot rudder like my war birds, but once it get to a good speed before I give it some up elevator, I have noticed it starts to nose over ( the front of the bird is heading toward the ground at 40-50mph take off speed)
I have even hit the prop before take off once, so i get worreid when I see it start noseing over I tend to jurk the elevator, it lifts off, but hit hits the tail wheel pretty hard.
I cant look to see if it has toe in or out, as I was flying it yesterday, and I freaken had a stall while doing a hover about 50feet off the ground. I was able to get it do nose over, I made it dive stright down to get some speed, and pulled up last sec, it riped the wheels out, and almost broke the hole back end off the bird.
But she will fly once more
Old Apr 22, 2011, 02:57 PM
twmonroe is offline
Joined Mar 2011
you could actually use more toe on one gear to counter the tendancy for a warbird to not track a straight line on take off
They want to go right..so put a touch more toe on the right gear to help hold it straight. Just like on a car..race cars use more toe, along with other things to either make the car more stable and help with understeer..less toe..less stable..
TM
Old Apr 23, 2011, 08:33 PM
us185damiani is offline
Find More Posts by us185damiani
www.****enageair.org
us185damiani's Avatar
United States, PA, Watsontown
Joined Mar 2006
Toe in because the drag on the ground will tend to straighten to zero toe. Full size airplanes are almost always straight on
us185damiani is offline Find More Posts by us185damiani
Old May 01, 2011, 10:28 PM
Joined Jul 2010
Well I did not have time to make my retracts have toe in, but made the straight. Well I came in fast and I touch down a little harder than I would like and the wheels dug in the mud.
Warning to others. This caused them to toe out and made the retracts collapse.
If the were toed in. It would of not failed as the action of being pushed in would go agenst the bracket vs pushing against the servo
Old May 10, 2011, 10:24 PM
Leroy G is online now
Find More Posts by Leroy G
Leroy G.
Leroy G's Avatar
Coeur d' alene, Id.
Joined Jan 2010
toe in
Toe in around 2-3 degrees, do not toe one side more than the other, all these type planes pull right on take off so use rudder not aleron to correct. Leroy
Why toe in, ? Like on your car, front wheels have toe in to keep wheels from wandering, it does the same thing on these scale models and aids tracking. LEROY
Leroy G is online now Find More Posts by Leroy G
Old May 11, 2011, 11:48 AM
mgrande11 is offline
Find More Posts by mgrande11
mgrande11's Avatar
United States, NC, King
Joined Mar 2009
use both
mgrande11 is offline Find More Posts by mgrande11
Wanted front landing gear PLEASE :( RChelisrule Aircraft - Electric - Jets (FS/W) 4 Apr 12, 2011 06:30 PM
Discussion Orientation Face On or Toe In On FP and CP Helis wnppmy Beginner Training Area (Heli-Electric) 13 Apr 08, 2011 05:01 AM
Wanted ANY FRONT Landing Gear PLEASE! RChelisrule Aircraft - Electric - Airplanes (FS/W) 1 Apr 07, 2011 09:02 PM
Should tail drager undercarriage have toe in or toe out? mork Parkflyers 8 Sep 05, 2002 05:11 PM
