Old Apr 29, 2011, 02:36 PM
JustPlaneChris is offline
Find More Posts by JustPlaneChris
JustPlaneChris's Avatar
Austin, TX
Joined Sep 2005
I still have one in a box somewhere, but my "around the house" heli is an LAHeli Ricco (collective pitch - and flybarless - but almost as light as a FP!).
As you can see from my posts here I still dabble with planes too. Just got the email that my order is packed and being sent to shipping.
-Chris
JustPlaneChris is offline Find More Posts by JustPlaneChris
Old Apr 29, 2011, 02:41 PM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Originally Posted by JustPlaneChris View Post
Who cares? I've got helicopters for that task.
-Chris
Well quite a few I reckon seeing as its suppose to be a "genuine 3D performer"
Kris... is offline Find More Posts by Kris...
Old Apr 29, 2011, 03:17 PM
TreeDiver is offline
Find More Posts by TreeDiver
BrainFart RC-Pilot
TreeDiver's Avatar
Echt, Netherlands
Joined Aug 2003
Hi
I use glow tube to secure the clevis.
See picture of a nice spot for the ESC.
The 2200 25C Nano 3s fits perfect and balance is good.
If I am not wrong it is 90mm - 92mm (1/3 of root which is 275mm)
I could run the motor...and "plenty power".
Because it was in house...and already so much power...I like to do it outside.
Prop does has no info, but I guess it is 10x5 slowfly.
Rob
TreeDiver is offline Find More Posts by TreeDiver
Old Apr 29, 2011, 03:22 PM
Sammy70 is offline
Find More Posts by Sammy70
PSALM 14:1
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Thanks for the update Ron and good pictures.
Have you checked the weight? Curious how much this thing weighs....
Sammy70 is offline Find More Posts by Sammy70
Old Apr 29, 2011, 03:30 PM
BrainFart RC-Pilot
TreeDiver's Avatar
Echt, Netherlands
Joined Aug 2003
Not yet. I will post that tomorrow. If I am not wrong it is between 810-820gram with 2200 3s Nano 25C pack. If that is so... "not bad for an epo plane"!!
Cheers and maybe...tomorrow maiden
Old Apr 29, 2011, 04:30 PM
Austin, TX
Joined Sep 2005
Good point. I'm not buying it to do 3D, I want it for regular aerobatics. I suppose if it really is 100+g lighter than the Parkzone Extra, it just might do 3D. Someone else will have to find out though, 3D is not for me (with planes anyway )
-Chris
Old Apr 29, 2011, 04:54 PM
nova50073 is offline
Find More Posts by nova50073
USA, NC, Earl
Joined Jan 2009
Originally Posted by nova50073 View Post
Call me a guinda pig, I hit the buy button.
I had been looking at the HK BIG yak 54, but so many burned up motors on it, and every motor I wanted to buy was backorder, so I saw this was a new one, so I blew a $100 on, and I have plenty of RX's and 2200 batterys, to use with this plane.
will post what breaks first, if it is not pilot error.
Well I got it , rather quick from the usa warehouse, it IS a very good looking plane, and I dont know, but the foam seems harder than what I am used to, in easystar and stryker planes, just my opinion, once it hits the ground hard, bet it breaks just the same, HA.
Took some watt meter reading, 2200, 25c , used battery, fair charge on it,
27.49 Amps
268 watts
battery 12.18 V after run.
NO manual at all, anyone have a idea on the throws?
I was going to go with
25 percent of cord, to be safe on the CG
nova50073 is offline Find More Posts by nova50073
Old Apr 29, 2011, 08:46 PM
Sammy70 is offline
PSALM 14:1
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Well it's ALL YOU GUYS' FAULT!!
I ordered a blue one today
Old Apr 29, 2011, 11:41 PM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
Flight Report .....................................?
Old Apr 30, 2011, 02:57 AM
BrainFart RC-Pilot
TreeDiver's Avatar
Echt, Netherlands
Joined Aug 2003
27.49 Amps
268 watts
1/3 of cord is the balance point. Same as on my Eflite SU-26m (also 1meter plane)
So 90mm-92mm
25percent of chord...that is hard to achive, because you can not move backwards the pack, or you have to place it in a 45degrees angle or so....
epo quality is very good of this plane
this epo (or elapor how multiplex does call it) is brilliant stuff
by the way... maybe by gluing the tail piece, instead of the two bolts you can move the CG a bit forward also
Old Apr 30, 2011, 03:34 AM
BrainFart RC-Pilot
TreeDiver's Avatar
Echt, Netherlands
Joined Aug 2003
trow
manual does not mention the trow. Maybe an idea to take the settings adviced for my SU-26m which has the same size and very simular wingshape.
Ailerons Low rate
Up 3/4-inch (19mm)
Down 3/4-inch (19mm
Ailerons High rate
Up 1 1/4-inch (32mm)
Down 1 1/4-inch (32mm)
Elevator Low rate
Up 1-inch (25mm)
Down 1-inch (25mm)
Elevator High rate
Up 2-inch (50mm)
Down 2-inch (50mm)
Rudder Low rate
Up 1 1/2 inch (38mm)
Down 1 1/2-inch (38mm)
Rudder High rate
Up 2-inch (50mm)
Down 2-inch (50mm)
Maybe this will work....
Old Apr 30, 2011, 06:49 AM
Sammy70 is offline
PSALM 14:1
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Originally Posted by TreeDiver View Post
Ailerons Low rate
Up 1/4-inch (19mm)
Down 1/4-inch (19mm
19mm = 3/4"
Old Apr 30, 2011, 07:14 AM
BrainFart RC-Pilot
TreeDiver's Avatar
Echt, Netherlands
Joined Aug 2003
19mm = 3/4"
typo.... and corrected
Old Apr 30, 2011, 08:03 AM
Sammy70 is offline
PSALM 14:1
Sammy70's Avatar
Central Ohio
Joined Feb 2008
27.49 Amps
268 watts
Either your numbers were typed wrong or your battery is VERY poor.
268w / 27.49a = 9.75v
Any pack that sags to less than 10v under load is bad news. If the pack is fully charged (and should be capable of the loads) I like to see them stay above 11v, at least for a while, and then slowly drop towards 10.5v.
I don't see this 28-30 motor lasting very long at all if it's pulling 27amps!
Old Apr 30, 2011, 08:10 AM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
My tracking information says I wont get mine until may 5th I guess I can wait 6 more days for it.
tallflyer is offline Find More Posts by tallflyer
Latest blog entry: Yunnec Typhoon H Review
Discussion HobbyKing Dolphin Micro Sport Glider EPO, 555mm (PNF) e_lm_70 Micro Ready-to-Fly 113 Oct 02, 2015 08:48 AM
Sold Eflite Extra 260 3D 480 apex Aircraft - Electric - Airplanes (FS/W) 3 Oct 27, 2012 11:14 PM
Discussion New HobbyKing warehouse in the USA. Bilbobaker Vendor Talk 116 Jun 03, 2011 09:48 PM
Alert Lipos in stock at HobbyKing USA Warehouse Mikey 68 Batteries and Chargers 181 Jan 26, 2011 06:40 PM
Discussion HobbyKing USA warehouse. neck Gilbert Quiet Flyers (Arizona) 43 Nov 20, 2010 12:48 AM
