Old Oct 03, 2011, 08:57 AM
EQ45 is offline
Find More Posts by EQ45
Joined Jul 2011
Originally Posted by slopepilot View Post
nice gear, whats the weight?
I did not weight it but I'm sure it's less than the original one and it's 5.5 cm wheel
It's nice to land on the grass but in the air the performance are also decreased (just a little bit) but the visualisation of the plane orientation is better...
I still have to install the bigger motor and see what flight time I can get.
EQ45 is offline Find More Posts by EQ45
Old Oct 03, 2011, 12:32 PM
whitrzac is offline
Find More Posts by whitrzac
United States, WI, Baraboo
Joined Aug 2010
Originally Posted by j.wolf View Post
I plan on running 2 cell 2200 mah packs in this plane.
Is that a bad idea. I am a novice. I want to work my way up to running 3 cells with a different prop.
Will this thing fly OK with the 2 cell????
TIA
Starting out with an aerobatic plain is a bad idea in general. It should fly on a 2s but you will be full throttle for most of the flight.
whitrzac is offline Find More Posts by whitrzac
Old Oct 03, 2011, 05:14 PM
slopepilot is offline
Find More Posts by slopepilot
Gypsy Pilot
slopepilot's Avatar
United States, CA, Beaumont
Joined Dec 2007
I think it calls for a 2-3s 2200
so, yeah
slopepilot is offline Find More Posts by slopepilot
Old Oct 03, 2011, 10:44 PM
j.wolf is offline
Find More Posts by j.wolf
Joined Oct 2011
I am not starting out. This will be my first larger plane. I am currently flying a UM Sukhoi SU26XP with relative ease. My thoughts were that the extra was just a bigger version of that. So, I should have fun with it.
Just worried it wont fly well on 2 cell. I am used to flying at WOT w/ my Sukhoi. So, that wont be an issue.
j.wolf is offline Find More Posts by j.wolf
Old Oct 04, 2011, 12:00 AM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
3 cell
3 cell is the pack you should use! a 2 cell would make the plane fly too slow and you would be fighting the whole time.
tallflyer is offline Find More Posts by tallflyer
Latest blog entry: My Official 3DR Solo Blog
Old Oct 04, 2011, 12:55 AM
jb0005 is offline
Find More Posts by jb0005
FLY HARD OR FLY HOME TO MUMMY
jb0005's Avatar
Joined Jan 2011
Originally Posted by jb0005 View Post
if anyone is interested, i installed a new motor,Aeolian 3530 1100kv(very cheap too- $9.80 US!) , same as slope pilot, and flew it for the first time today. A bit more nose up trim needed with the heavier motor up front but thats about it. it also pulls a lot harder to the left because of the extra power being generated. i can now go vertical after take off and keep going forever if i wanted to(and my plane is quite heavy with much thicker aluminium landing gear than stock, and i'm also running a 9x6 prop which isn't made for climbing) all in all, its faster, got far better climb and hopefully more reliable. i'm still using the stock esc, it gets warm but not hot, so i'll just have to keep an eye on it when the weather warms up
this might answer eq45's question about a good combo that will do knife edge. i can knife edge with this very easily, and convert from horizontal flight to vertical whilst in knife edge. its important to have good power, but a 9x6 prop is all that is required to knife edge.i'm no expert but i'm pretty sure krexken is right, a 12x6 would be way overpropped and you will kill your esc. if your still having problems with knife edge try increasing the throws on your rudder. but be warned, this combo does make the stock esc warm
jb0005 is offline Find More Posts by jb0005
Old Oct 04, 2011, 10:18 AM
whitrzac is offline
Joined Aug 2010
I'v used a 10x5, 11x5.5 and 12x6 prop... once I shimmed the motor bell away from the backplate the motor only gets luke warm and the esc never hits above 130ish
Old Oct 05, 2011, 10:24 PM
laotzu is offline
Find More Posts by laotzu
Joined Jul 2011
Where is CG of this plane?
Does CG location change when we change landing gear or batt size?
Thanks.
laotzu is offline Find More Posts by laotzu
Old Oct 06, 2011, 02:23 AM
TreeDiver is online now
Find More Posts by TreeDiver
BrainFart RC-Pilot
TreeDiver's Avatar
Echt, Netherlands
Joined Aug 2003
Cg
Thanks.
I took the same value as my Eflite SU-26m. The wings are very identical.
90mm - 92mm (1/3 of root which is 275mm)
TreeDiver is online now Find More Posts by TreeDiver
Old Oct 09, 2011, 01:08 PM
EQ45 is offline
Joined Jul 2011
Raining today in belgium, so additional work on landing gear and hatch trap
Name: 2011-10-09 12.06.03.jpg
Description:
Name: 2011-10-09 12.07.00.jpg
Description:
The electrical stuff on the wing was cut and use to lock the wheels
Name: 2011-10-09 19.38.22.jpg
Description:
Name: 2011-10-09 19.38.40.jpg
Description:
Name: 2011-10-09 19.39.03.jpg
Description:
Old Nov 11, 2011, 02:00 AM
Paul66 is offline
Find More Posts by Paul66
Joined Jul 2010
Down Thrust?
Hi Guys - I am mounting a Turnigy 3536 900KV motor to this plane. Can someone please give me an idea of how much down/right thrust I should put in?
Thanks in advance.
Paul
Paul66 is offline Find More Posts by Paul66
Old Nov 11, 2011, 05:52 AM
BrainFart RC-Pilot
TreeDiver's Avatar
Echt, Netherlands
Joined Aug 2003
Thanks in advance.
Paul
IMO, it is inside the firewall already this down/right thrust.
So mount it and you should be ready to go
Old Nov 11, 2011, 11:27 AM
Gypsy Pilot
slopepilot's Avatar
Joined Dec 2007
[QUOTE=laotzu;19515635]Where is CG of this plane?
3.5 inches
the landing,yes if heavier/lighter..the battery the same, you can move it forward or back to achieve the proper CG
Old Nov 12, 2011, 11:00 AM
EQ45 is offline
Joined Jul 2011
I broke it today while doing knife edges... I think the rudder broke in flight...
The wing is fine
The rudder is broken and the elevator also
the motor is dead and the whole front was bended...
So next step is repair...
with hot water I put back the fuselage so it's not bended anymore.
I put in the howen at 100 C the motor cover but it was too much and now the surface looks like small sphere.
for the rudder and elevator I will use floppy disk to make hinges.
As I broke a clevis, I will order new ones for repair...
I will put the NTM motor I bought the 35-30 1100 kv with a 10x5 prop at first.
Hope to be back in the air soon...
Old Nov 13, 2011, 03:32 PM
Paul66 is offline
Joined Jul 2010
Thanks TreeDiver - I'll just mount as you have suggested.
Discussion HobbyKing Dolphin Micro Sport Glider EPO, 555mm (PNF) e_lm_70 Micro Ready-to-Fly 113 Oct 02, 2015 08:48 AM
Sold Eflite Extra 260 3D 480 apex Aircraft - Electric - Airplanes (FS/W) 3 Oct 27, 2012 11:14 PM
Discussion New HobbyKing warehouse in the USA. Bilbobaker Vendor Talk 116 Jun 03, 2011 09:48 PM
Alert Lipos in stock at HobbyKing USA Warehouse FieldofDreamsFlyer Batteries and Chargers 181 Jan 26, 2011 06:40 PM
Discussion HobbyKing USA warehouse. neck Gilbert Quiet Flyers (Arizona) 43 Nov 20, 2010 12:48 AM
