Old Sep 01, 2011, 08:38 AM
EQ45 is offline
Find More Posts by EQ45
Joined Jul 2011
Hello
I ordered NTM Prop Drive Series 35-30 1100kv / 380w with 12x6 prop. Hope I will not sacrify too much flight time on the 3s 2200 mah batteries
Can I keep the original 30 A esc or do I have to set a 40 esc. It suppose to run at 26 amps with 12x6 prop. I might try also 10 x 5 original prop.
EQ45 is offline Find More Posts by EQ45
Old Sep 01, 2011, 08:25 PM
slopepilot is online now
Find More Posts by slopepilot
Gypsy Pilot
slopepilot's Avatar
United States, CA, Beaumont
Joined Dec 2007
Question
Can I use this meter to test the amps draw of my setup? Thanks in advance, Dave
http://www.fluke.com/fluke/usen/proc....htm?PID=56131
slopepilot is online now Find More Posts by slopepilot
Old Sep 02, 2011, 06:59 PM
krexken is offline
Find More Posts by krexken
smoke is my wattmeter
Longview, Tx
Joined May 2008
Originally Posted by EQ45 View Post
Hello
A 12x6 is a lot of prop for a motor that size. A 380 watt rating seems a little optimistic but would probably live if you limited it to short bursts as in light 3d use. Continuous wide open throttle will cook a motor fast if overpropped. Might want to try an 11x5.5 or 10x7 first. Stay away from sf or slow fly props of the same or similar size. They draw much more power than a normal e or electric prop. A wattmeter is a sure enough invaluable tool so there's no guessing. Flight time depends on throttle used, not necessarily the motor size. You should be able to get by with a 30 amp esc.
krexken is offline Find More Posts by krexken
Old Sep 02, 2011, 07:03 PM
krexken is offline
Longview, Tx
Joined May 2008
Don't believe you can. Specs say 0-1 amp rating. Some meters go to 10 amps but that isn't enough either.
Old Sep 03, 2011, 12:54 AM
Sorcerer is offline
Find More Posts by Sorcerer
Antwerp, Belgium
Joined Jun 2007
What kind of prop do you guys advice on this upgrade?
It's the 35-30 1400kv
Sorcerer is offline Find More Posts by Sorcerer
Old Sep 03, 2011, 12:55 AM
EQ45 is offline
Joined Jul 2011
@krexken
On HK site http://www.hobbyking.com/hobbyking/s...dProduct=16230 they give the list of prop test:
8x4 - 14.8v - 251W - 17A
8x4 - 11.1v - 121W - 11A
9x6 - 11.1v - 178W - 16A
9x6 - 14.8v - 355W - 24A
10x5 - 11.1v - 200W - 18A
10x5 - 14.8v - 385W - 26A
11x5.5 - 11.1v - 200w - 20A
12x6 - 11.1v - 266w - 26A
According to that 12x6 is suppose to be possible.
If I can have a little bit more power with that motor and the 10 x 5 original prop so that knife edge is possible (with the stock motor and 9x4.7 prop it look to be not possible)
Old Sep 06, 2011, 02:01 PM
creapyd is online now
Find More Posts by creapyd
Prefectionist
Joined Mar 2007
Thats for the 1100kvt motor. he's got the 1400 kvt motor. I'd start ~9x6 and watch your amps.
@krexken
creapyd is online now Find More Posts by creapyd
Old Sep 08, 2011, 04:31 AM
EQ45 is offline
Joined Jul 2011
My answer was for krexken who commented on my 1100kvt motor. it's clear that the same props can not be used on the 1400kvt motor.
Old Sep 28, 2011, 06:10 AM
EQ45 is offline
Joined Jul 2011
on board camera...
EKEN0004.avi (8 min 50 sec)
I did not install the new motor yet but started to work on a new landing gear...
Old Sep 30, 2011, 07:19 AM
whitrzac is offline
Find More Posts by whitrzac
United States, WI, Baraboo
Joined Aug 2010
Where can I get spare parts for this? my fuselage is kinda beat up now...
What would work better to do some kind of pattern on the bottom(blue is a PIA to see)? Flat black spraypaint, sharpie, others?
FYI: after I shimmed the motor can away from the backplate I've had 4-5 hrs of flight time on it without issue. On a 11x5.5 and 3s 2200 it only gets warm.
whitrzac is offline Find More Posts by whitrzac
Old Sep 30, 2011, 07:12 PM
Gypsy Pilot
slopepilot's Avatar
Joined Dec 2007
99 buck huck..buy a whole new airframe and have all the pieces
Old Oct 02, 2011, 09:36 AM
EQ45 is offline
Joined Jul 2011
I still would like to find something to replace the door of the battery hatch since I loose it.
During flight I lost also the canopy but was able to find it back. I putted some tape so that it does not go off again
Old Oct 02, 2011, 01:41 PM
Gypsy Pilot
slopepilot's Avatar
Joined Dec 2007
nice gear, whats the weight?
Old Oct 02, 2011, 11:05 PM
j.wolf is offline
Find More Posts by j.wolf
Joined Oct 2011
I plan on running 2 cell 2200 mah packs in this plane.
Is that a bad idea. I am a novice. I want to work my way up to running 3 cells with a different prop.
Will this thing fly OK with the 2 cell????
TIA
j.wolf is offline Find More Posts by j.wolf
Discussion HobbyKing Dolphin Micro Sport Glider EPO, 555mm (PNF) e_lm_70 Micro Ready-to-Fly 113 Oct 02, 2015 08:48 AM
Sold Eflite Extra 260 3D 480 apex Aircraft - Electric - Airplanes (FS/W) 3 Oct 27, 2012 11:14 PM
Discussion New HobbyKing warehouse in the USA. Bilbobaker Vendor Talk 116 Jun 03, 2011 09:48 PM
Alert Lipos in stock at HobbyKing USA Warehouse Mikey 68 Batteries and Chargers 181 Jan 26, 2011 06:40 PM
Discussion HobbyKing USA warehouse. neck Gilbert Quiet Flyers (Arizona) 43 Nov 20, 2010 12:48 AM
