Old Aug 07, 2011, 10:50 AM
slopepilot is online now
Find More Posts by slopepilot
Gypsy Pilot
slopepilot's Avatar
United States, CA, Beaumont
Joined Dec 2007
Originally Posted by ben_beyer View Post
Haven't heard IMOP, what does that mean?
messed up,,, IMPO, in my personal opinion
and still no maiden, Its sloping season, been to busy with sloping, check my blog
slopepilot is online now Find More Posts by slopepilot
Old Aug 11, 2011, 08:45 AM
Sorcerer is offline
Find More Posts by Sorcerer
Antwerp, Belgium
Joined Jun 2007
Aaaaaalrighty then
Ordered in Germany on monday. Inhouse today! Great!
Hopefully with a non faulty motor ...
I gonna buy a spare motor anyhow and got some HXT900's stored.
I read a lot about a replacement motor, but don't know exactly what to buy.
I'm gonna buy at HK, that's for sure. I don't want a speedy plane but a fun aerobatics foamie with plenty of airtime.
Batteries I'll be using are 2200mAh 3s Zippy's
Anyone got an idea about the motor? Ow and maybe a good size one without the need to "dremel" the cowling.
Thanks in advance!
Description: Delivered ;)
Sorcerer is offline Find More Posts by Sorcerer
Old Aug 12, 2011, 12:30 PM
Sorcerer is offline
Antwerp, Belgium
Joined Jun 2007
Ok, little update.
Unpacked. No damage, no surprises. Only an ugly sticker on the cowling.
Maybe has something to do with the European law concerning CE certificates ... who cares? As long as it flies
Gonna go for a little shopping tomorrow. The stabilator bolt system is awkward, gonna use other screws on it and glue it also.
The landing gear is worthless as stock, but I think with little modification it wil hold. I going to try to put some sort of spar in between the two legs, maybe it will look silly but if it holds it's ok. Also maybe put some nylon screws in it instead of the steel ones, they wil break on rough landing but will not ripp the whole undercarriage apart.
And now for the motor, I have absolutely no ideay what to do with it. Haven't tested it because I have to solder a 4mm banana on the ESC wich I don't have. Bummer.
Will keep you guys updated. But for now it looks promising. The foam is great quality!
Old Aug 12, 2011, 02:54 PM
stalyoni is offline
Find More Posts by stalyoni
high flyer
stalyoni's Avatar
Australia, WA, Geraldton
Joined May 2008
mate dont fly it with the stock motor. Its really bad and it will only start smoking mid flight.
I would suggest you look for a turnigy 35-30 1400kv motor and put a 9x5 APC prop on it.
I dont think no mater what you do will it ever do 3d flight. The rudder is just not big enough.
Anyways good luck with it.
I just repaired the tail on mine but i still need to replace the rudder servo. The top plastic covering has also gone missing. Should fly fine without but it will create some drag and i would rather track it down first.
stalyoni is offline Find More Posts by stalyoni
Old Aug 13, 2011, 03:38 AM
EQ45 is offline
Find More Posts by EQ45
Joined Jul 2011
New landing gear with 5 cm diameter wheel. Ride better on the grass. Went off at the first trial because I forgot tu glue back the foam from the orignal one.
Concerning the stock motor, it does not smoke with 3S and 9x4.7 prop
EQ45 is offline Find More Posts by EQ45
Old Aug 14, 2011, 04:14 AM
Sorcerer is offline
Antwerp, Belgium
Joined Jun 2007
Yesterday did some inspections and here are my findings:
- need to replace clevis (will use linkage like on my old TwinStar)
- need to replace motor & ESC (don't trust it, will keep it for a smaller plane)
- need to replace servo's (will replace them with HXT900's)
I just place my order incl. a Turnygy NTM 3530 and a 55A ESC.
Hope this will do the trick.
Old Aug 14, 2011, 07:13 AM
TreeDiver is offline
Find More Posts by TreeDiver
BrainFart RC-Pilot
TreeDiver's Avatar
Echt, Netherlands
Joined Aug 2003
Good mods
I have 900kV motor inside of it MaticTorque 30-09 of arround 100gram.
With 12x6 and 26amps...plenty power!
The ESC is Turnigy AE-30amps.
Next to thata HXT900's
TreeDiver is offline Find More Posts by TreeDiver
Old Aug 15, 2011, 04:09 AM
jb0005 is offline
Find More Posts by jb0005
FLY HARD OR FLY HOME TO MUMMY
jb0005's Avatar
Joined Jan 2011
i'm using the Aeolian 3530 1100kv(very cheap too- $9.80 US!) and it has that much power it was tearing off the elevators. i've now re installed the the elevators using robart hinges believe it or not! and so far its holding together really well. i originally tried hinge tape, but Slopepilot was right and the hinge came loose again resulting in a crash.its flying really well now though with the robarts
jb0005 is offline Find More Posts by jb0005
Old Aug 15, 2011, 01:01 PM
laotzu is offline
Find More Posts by laotzu
Joined Jul 2011
Am planning to replace the motor with turnigy 3536 1400kv or 3536 900 kv. Which motor is better for this plane?
laotzu is offline Find More Posts by laotzu
Old Aug 15, 2011, 05:55 PM
stalyoni is offline
high flyer
stalyoni's Avatar
Joined May 2008
1400kv with a 10x5 would be the sweet spot i would think.
I run a 35-30 1700kv motor with a 8x4 and its stupidly fast. But i love it now.
Old Aug 18, 2011, 04:16 AM
Sorcerer is offline
Antwerp, Belgium
Joined Jun 2007
Someone has a manual of the stock ESC? Or knows where to find it?
I'm going to use it in a small plane.
Old Aug 21, 2011, 01:18 PM
Gypsy Pilot
slopepilot's Avatar
Joined Dec 2007
today maiden..if not windy
plane is RTF and video cam is charged..850 grams
got my 35-30 1100kv, 40A esc, I have a 9x4.5 to try on it, maybe got to store for a 12x6. Stock landing gear, carbon pushrods in larger sleeves, control horns, hs55's and 2 2200 zippies. CG is at 90/91 naturally, may try for 89 with some lead in nose. Wish me luck! Video later!
Old Aug 25, 2011, 01:41 AM
EQ45 is offline
Joined Jul 2011
@ Slope pilot
Good luck. You will see that planes fly well
On my side I removed definitively the landing gear. It's faster and it's better to play the stupid "banderolle" at the club (There is one Thermic plane with a vhs tape behind it and you have to cut it with your plane.). I do not know the name in English. With the stock motor and 9x4.7 propeller, it's fine provided that the other plane does not speed too much.
In this configuration, the plane works pretty nicely for my skill. The only thing is that I think that the pro does not give enough air on the rudder and it's impossible to fly on the side (wings vertically)
Old Aug 28, 2011, 03:41 PM
DexterIt is offline
Find More Posts by DexterIt
DexterIt's Avatar
Italy, Lombardia, Rovato
Joined Jun 2011
Hello guys!I brought this plane from DE and i was very happy with him,until i crushed into a electric pole.The plane got nothing too bad,but one of the aileron wings is getting lose.I put a picture to see.What kind of tape should i use to repair it?
Thank you.
Regards Daniel!
DexterIt is offline Find More Posts by DexterIt
Old Aug 28, 2011, 08:54 PM
Gypsy Pilot
slopepilot's Avatar
Joined Dec 2007
this post here
Thank you.
Regards Daniel!
http://www.rcgroups.com/forums/showp...&postcount=627
Discussion HobbyKing Dolphin Micro Sport Glider EPO, 555mm (PNF) e_lm_70 Micro Ready-to-Fly 113 Oct 02, 2015 09:48 AM
Sold Eflite Extra 260 3D 480 apex Aircraft - Electric - Airplanes (FS/W) 3 Oct 28, 2012 12:14 AM
Discussion New HobbyKing warehouse in the USA. Bilbobaker Vendor Talk 116 Jun 03, 2011 10:48 PM
Alert Lipos in stock at HobbyKing USA Warehouse FieldofDreamsFlyer Batteries and Chargers 181 Jan 26, 2011 07:40 PM
Discussion HobbyKing USA warehouse. neck Gilbert Quiet Flyers (Arizona) 43 Nov 20, 2010 01:48 AM
