Old May 03, 2011, 03:55 PM
TreeDiver is offline
Find More Posts by TreeDiver
BrainFart RC-Pilot
TreeDiver's Avatar
Echt, Netherlands
Joined Aug 2003
tested the motor with full battery pack. It started at 30amps and settled to 26-27amps static. Motor did run fine untill now.
Still too windy in Holland... hopefully Thursday maiden
TreeDiver is offline Find More Posts by TreeDiver
Old May 03, 2011, 05:10 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Originally Posted by AZAerobat View Post
I am just learning how to fly 3D I do not want to risk it on a plane that is not designed for it. Buck Huck you are on the top of my short list.
I'm just starting to play with 3D type things too. The BuckHuck looks super, but I didn't want a balsa plane to "learn" on. Here's what I went with for a starter 3D plane and so far I have NO regrets:
http://www.rcgroups.com/forums/showthread.php?t=1377054
Sammy70 is offline Find More Posts by Sammy70
Old May 03, 2011, 05:12 PM
Sammy70 is offline
Sammy70's Avatar
Central Ohio
Joined Feb 2008
If that's the stock motor you were testing I can see why they only last a few minutes!!
That's about DOUBLE the amps that little 28-30 can take!
As a comparision, E-flite Park480's with 11" props pull about 27a at full throttle....
Old May 03, 2011, 05:51 PM
AZAerobat is online now
Find More Posts by AZAerobat
Fly More Crash Less
AZAerobat's Avatar
United States, AZ, Prescott
Joined Sep 2007
I agree. No way did I want to start with a balsa. Right now I am learning on a 3D Hawk. http://www.rcgroups.com/forums/showthread.php?t=1231846 I have only had her up in the air twice. Keep having problems with the motor ripping out of the foam. I am currently in the process of replacing it then hopefully the fun will begin.
AZAerobat is online now Find More Posts by AZAerobat
Old May 03, 2011, 08:50 PM
creapyd is online now
Find More Posts by creapyd
Prefectionist
Joined Mar 2007
I build my own Dollar store foamies for practicing 3d. Nothing like having a plane that's worth $30.00 ready to fly to beat around and not care about crashing.
creapyd is online now Find More Posts by creapyd
Old May 03, 2011, 10:40 PM
Nathing is offline
Find More Posts by Nathing
Joined May 2011
unwise to run it without prop (load)
but of course...it should not smoke anyhow
The motor had already quit during flight and during a subsequent run up on the ground (with the prop on) it started smoking. With the recommended 2200 mAh battery you could smell the motor toasting itself. I took it home and tried it with the smaller pack without the prop and that is what you see in the video. It was already toast by that point. Even unloaded, a motor that comes recommended for a 2200 shouldn't smoke after 5 seconds at full throttle on a 1300.
Nathing is offline Find More Posts by Nathing
Old May 03, 2011, 10:49 PM
Sammy70 is offline
Sammy70's Avatar
Central Ohio
Joined Feb 2008
What size is the stock prop on this thing?
Old May 03, 2011, 11:27 PM
thead is offline
Find More Posts by thead
United States, MA, Boston
Joined May 2005
someone needs to get a video of this thing flying. i have a blue one coming but it wont be here till next week. slow shipping. does the plane have carbon fiber bracing in the wings and stabs? HK doesn't even tell you how much room for battery like they have listed for other models.
are the wheels big enough to land on short grass or do you need pavement? hope to see a vid soon thanks guys.
thead is offline Find More Posts by thead
Old May 03, 2011, 11:51 PM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Agreed i cant believe that no one has posted a vid yet come on fellas
Kris... is offline Find More Posts by Kris...
Old May 04, 2011, 01:02 AM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
Well If I get mine on the scheduled day of Friday Im Off Sunday I will shoot a video on Sunday!
tallflyer is offline Find More Posts by tallflyer
Latest blog entry: Yunnec Typhoon H Review
Old May 04, 2011, 01:15 AM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
Nice one mate roll on Sundays premiere
Old May 04, 2011, 01:24 AM
stalyoni is offline
Find More Posts by stalyoni
high flyer
stalyoni's Avatar
Australia, WA, Geraldton
Joined May 2008
yeah i think ill wait till i see a video of it before i go ahead and order one
stalyoni is offline Find More Posts by stalyoni
Old May 04, 2011, 01:56 AM
BrainFart RC-Pilot
TreeDiver's Avatar
Echt, Netherlands
Joined Aug 2003
yes, that is 100% the way to go and to learn 3D
much better to learn the reflexes
Old May 04, 2011, 02:03 AM
tallflyer's Avatar
Joined Jul 2002
I figured I would chime in here since I started the thread. If you looking for a starter 3D foam plane
http://www.rcgroups.com/forums/showthread.php?t=959721
Since this is My Thread also!
Old May 04, 2011, 02:04 AM
BrainFart RC-Pilot
TreeDiver's Avatar
Echt, Netherlands
Joined Aug 2003
yes, but it did hold and keep in mind that it is "static".
in the air it is less, unless you go vertical and for sure it will go vertical this plane!
If Multiplex would release this as frame for Euro 89--, everybody would purchase it. That is how I see it.
Servos that are build in now, do centre a bit slow...but centre. And if it flies well, no problem to add HS-65hb and another motor if this one starts to smoke.
The ESC seems to be good, but I wonder what type it is. There is no manual.
I can not wait untill the first flight...
Discussion HobbyKing Dolphin Micro Sport Glider EPO, 555mm (PNF) e_lm_70 Micro Ready-to-Fly 113 Oct 02, 2015 08:48 AM
Sold Eflite Extra 260 3D 480 apex Aircraft - Electric - Airplanes (FS/W) 3 Oct 27, 2012 11:14 PM
Discussion New HobbyKing warehouse in the USA. Bilbobaker Vendor Talk 116 Jun 03, 2011 09:48 PM
Alert Lipos in stock at HobbyKing USA Warehouse FieldofDreamsFlyer Batteries and Chargers 181 Jan 26, 2011 06:40 PM
Discussion HobbyKing USA warehouse. neck Gilbert Quiet Flyers (Arizona) 43 Nov 20, 2010 12:48 AM
