Old Apr 20, 2011, 07:13 PM
Paul Naton is offline
Find More Posts by Paul Naton
Paul Naton's Avatar
Lewisburg, PA
Joined Apr 2002
Fun With ALES Full Throttle Yoke Failure
I was out practicing today with my ALES plane, when the prop yoke failed at full throttle. Conditions were very breezy with strong but broken late day thermals moving at 15-20kts downwind.
Plane is a modified Aria HLG (more info on the plane here: http://glidefast.typepad.com/glidefa...ider.html#more)
I got one of Randy's CAM units last week and have been practicing getting 10 from 600 feet. First flight was a 10 though very turbulent and got low a few times. I didn't want to land so came over the tree line and pushed upwind diving for speed and to get below the wind gradient. Felt some air blow through a few seconds earlier and the plan was to build speed, hit power, accelerate, then pull up hard into the gradient, and go downwind to catch that air and start another 10 minute cycle. I was 40 meters away from myself and hit the power button, still diving slightly.
The plane spooled up quickly, and at 15 feet, I started to pull up going about 60kts. Just then I noticed something leave the plane and a hundredth of a second later the plane pulled vertical, and I saw another object leave the plane!
Plane shot up to 50 feet and I had no pitch control. OK, I now know the motor left the plane, and my CG is now at the trailing edge of the wing. The plane flopped around, and landed in the parking lot, with only some slight v-tail damage.
I found the motor and spinner a hundred feet upwind, with one blade missing. A long search turned up the other blade, confirming the it was not the blade but the yoke that failed. The picture shows the plastic yoke broken at the bolt hole and missing firewall.
Note to self: never use plastic yokes again, especially after you put in a Hi-C battery.
Ordering some new spinners tonight!
Paul Naton
Radio Carbon Art Productions
http://radiocarbonart.com/
Paul Naton is offline Find More Posts by Paul Naton
Site Sponsor
Old Apr 20, 2011, 09:35 PM
Leadchucker is offline
Find More Posts by Leadchucker
AMA7224 LSF1832
Leadchucker's Avatar
United States, DE, Seaford
Joined Sep 2008
Yow!!! Don't look like your aircraft faired too badly considering.
I don't think I've ever seen a plastic yoke and your's is a good reason to not want to.
Leadchucker is offline Find More Posts by Leadchucker
Old Apr 21, 2011, 07:22 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Is that the one for graupner props? If so, they are designed for 2.3mm shafts (i.e. "Speed 400" motors) and the power they can put out (100W or so)..
..a
Old Apr 21, 2011, 05:45 PM
Kenny Sharp is online now
Find More Posts by Kenny Sharp
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
Nice to see your fuse didn't rip completely apart....nice that you found the pieces and discovered the cause.
Kenny Sharp is online now Find More Posts by Kenny Sharp
Old May 01, 2011, 10:34 PM
mred3 is offline
Find More Posts by mred3
OK,so what's the speed of dark
mred3's Avatar
Glenwood,GA
Joined Aug 2006
I was told never to use a plastic yoke, so the only thing I buy is metal. Then I forgot to put locktite on the nut and it threw a blade one day because the nut came off. The nose on my Vista didn't come out looking quite as good as yours did.
Ed
mred3 is offline Find More Posts by mred3
Old May 01, 2011, 11:34 PM
Thermal Hobby is offline
Find More Posts by Thermal Hobby
Thermal Hobby's Avatar
Joined Dec 2010
..a
Noooo they are not dude.......
Thermal Hobby is offline Find More Posts by Thermal Hobby
Old May 02, 2011, 07:07 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
You're right:
8x4.5 CAM Folding Prop, 3.2mm shaft, 38mm spinner, 6mm yoke. The CAM Folding Prop series is for electric airplanes using SPEED 280, 400, 480, 500 and 600 motors, both geared and direct drive.
..a
Discussion Very low climb rate at full throttle with Blade 400 silentwarrior Beginner Training Area (Heli-Electric) 7 Mar 22, 2011 02:20 PM
Question what causes pitching down a full throttle glen_j Flying Wings 11 Mar 15, 2011 10:30 PM
Discussion yoke for fold prop that has full yoke-width taper barb wire Electric Sailplanes 7 Sep 26, 2010 09:09 AM
Discussion Hanger 9 F22 full throttle dive, elevon failure = new hole in the lawn. bastian74 Fuel Plane Talk 1 Sep 13, 2010 08:01 AM
Full Throttle Failure polamnus Power Systems 11 Oct 10, 2002 08:01 PM
