Old Apr 19, 2011, 11:20 PM
valleypatroll is offline
Find More Posts by valleypatroll
Half a Huck
valleypatroll's Avatar
Joined Feb 2011
Sapac MB-1 Motor and fan combo mounting
How do you guys mount the fan in a foamie? Do you just epoxy it in? Also it has no lip on it, do i need to fabricate one or just roll with it?
Jimmy
valleypatroll is offline Find More Posts by valleypatroll
Old Apr 20, 2011, 05:31 AM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Most foamys have a cover that screws down to clamp the housing. If you use glue you'll have a hard time removing the fan when the motor burns up.
For a foamy fan try tub and tile silicone, not a lot just enough. I do dots and stuff the housing in to squeeze it. A gentile constant tug gets it out. Silicone also help with blocking noise transfer.
ApexAero is offline Find More Posts by ApexAero
Old Apr 20, 2011, 03:18 PM
Half a Huck
Joined Feb 2011
Old Apr 22, 2011, 05:20 AM
ColoradoHeliNut is offline
Find More Posts by ColoradoHeliNut
United States, CO, Lakewood
Joined Mar 2007
I used hot glue on my T-50's. Only on one side. If I need to take it out I use lighter fluid to break the hot glue loose. I takes about 5 to 10 minutes to break the bond enought to pull it out.
As fas as no ring I guess it depends on the jet & what's molded into the foam. The MB-1 mounts just perfect in the T-50.
ColoradoHeliNut is offline Find More Posts by ColoradoHeliNut
Old Apr 22, 2011, 12:10 PM
restlessswind is offline
Find More Posts by restlessswind
restlessswind's Avatar
United States, CA, Sacramento
Joined Jan 2010
Jimmy
Interesting, my MB-1 was received with 4 lips in an "X" pattern. I just cut slits into the foam where the lips met foam. I also cut off the front intake ring so I was able to mount it without digging the foam out to make room for the ring.
restlessswind is offline Find More Posts by restlessswind
Old Apr 22, 2011, 12:22 PM
smkn951 is offline
Find More Posts by smkn951
smkn951's Avatar
United States, HI, Kapolei
Joined Jan 2007
what about double sided tape?
smkn951 is offline Find More Posts by smkn951
Old Apr 22, 2011, 12:36 PM
Half a Huck
Joined Feb 2011
That's an idea
Old Apr 22, 2011, 12:37 PM
Half a Huck
Joined Feb 2011
Dumb question but which side is the exhaust side
Old Apr 22, 2011, 01:12 PM
crypto666 is offline
Find More Posts by crypto666
USA, NV, Caliente
Joined Mar 2009
That would be the part where the air comes out and you typically want it pointing towards the rear of the plane.
crypto666 is offline Find More Posts by crypto666
Old Apr 22, 2011, 01:25 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Usually I will epoxy hardwood or plywood rails to the airframe. This makes the fan easily removable. If the fan does not have mtg tabs, make some.
Other times (as in the last pic) I will attach the fan with RTV silicone adhesive at three points. removal is easy with one slice with a knive at the joints.
This method is supporting a fan with 6.5lbs thrust.
Hope that helps.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Apr 22, 2011, 02:27 PM
Half a Huck
Joined Feb 2011
Thanks. But is it the motor side 4 the exhaust
Old Apr 22, 2011, 02:38 PM
efflux RC's Avatar
Joined Aug 2009
In a SAPAC fan, yes.
Site Sponsor
Old Apr 22, 2011, 03:01 PM
Half a Huck
Joined Feb 2011
Thank you I appreciate it
Old Apr 22, 2011, 06:38 PM
Half a Huck
Joined Feb 2011
What is the recomened timing for 5 s
Old Apr 22, 2011, 11:32 PM
T-CAT is offline
Find More Posts by T-CAT
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
I would highly recommend low timing (mid timing at the most). With low timing, the motor will stay much cooler and draw less amps. The increase in timing won't be worth the extra heat, amp draw, and power production. Also, the Hobbywing (and every vendor that carries Hobbywing ESC's under a different name such as Turnigy Plush) ESC's tend to stutter on 5S with low timing (so high timing must be used on 5S, but that causes high amp draw and heat). However, on 4S, all timing settings seem to work fine for me.
When going 5S with this motor, low timing seems to work fine on Castle ESC's.
T-CAT is offline Find More Posts by T-CAT
Sold NIB Sapac Viper MKII w/ New Fan and Motor badbill Aircraft - Electric - Jets (FS/W) 2 Mar 28, 2011 09:09 PM
Sold SAPAC MB-1/FAN/HET Housing Rpotter90 Aircraft - Electric - Jets (FS/W) 3 Nov 30, 2010 08:17 AM
For Sale sapac mb-1 esc combo Tamiya tony Aircraft - Electric - Jets (FS/W) 2 Sep 07, 2010 10:02 AM
Discussion Stryker and Sapac MB-1 motor Sapacbill Flying Wings 24 Sep 04, 2010 09:44 PM
Discussion SAPAC MB-1 motor help cableguy351 Electric Ducted Fan Jet Talk 10 Aug 13, 2010 08:33 PM
