This thread is privately moderated by pd1, who may elect to delete unwanted replies.
Old Apr 19, 2011, 08:02 AM
pd1 is online now
pd1
Find More Posts by pd1
pd1
United States, MA, Haverhill
Joined Jun 2006
Mini-HowTo
Covering with tissue..open structure, Sparky
I covered the wing using Japanese Tissue.
I covered the wet method of covering in the Shoestring thread.
http://www.wattflyer.com/forums/showthread.php?t=23572
Sparky build thread:
http://www.wattflyer.com/forums/showthread.php?t=42422
Here's the dry method.
1. Cut tissue. Grain goes lengthwise, not chord wise.
Tear a corner to check grain direction.
Cut tissue about 1 inch over sized.
2. Adhere tissue to the structure.
This is more personal preference, or what works for you.
I have heard people using thinned out white glue.
Glue sticks.
Cellulose based glue (Ambroid, Duco).
Nitrate dope
Butyrate dope.
And a new possibility, Min Wax and an Iron.
Ron, Skysharkster is using this method on his Waco with a different material.
http://www.wattflyer.com/forums/showthread.php?t=41555
I don't use Nitrate anymore, too flammable for me.
So it's butyrate this time.
3. Prep. At least two coats of clear on the structure with sanding between. I use 50/50 thinned clear.
4. Lay the tissue over the area to be covered. Wet the structure with a fresh coat of dope and lay the tissue on the framework.
Try to get the wrinkles out, but don't go too crazy.
I cover the whole bottom of the wing then the top.
Once the tissue is stuck to the frame, trim the edges and add more dope to the perimeter .
If there are a few big wrinkles on the woodwork, you can flatten them with more dope and your fingers.
Try not to get any dope on the open tissue.
The covering should not be too tight.
Once all the edges are sealed well, I usually give a little more dope to the frame perimeter again.
5. Magic with water.
After the dope is dry, spray the wing with water and soak the paper.
The tissue will really wrinkle and sag now.
If you have a light structure, do top and bottom at the same time.
If you do only one side at a time the surface will twist, a lot.
Let it dry.
It should dry wrinkle free and tight. If not you can shrink again.
Once you're happy with it, a couple of coats of clear dope. Again do the top and the bottom together to prevent twisting.
Now sit back and watch the dope do it's magic.
Over a few hours the dope will shrink the covering even more than the water did.
pd1 is online now Find More Posts by pd1
Article Covering Balsa Models With Tissue Gene Norman Electric Plane Talk 1 Sep 02, 2010 08:48 PM
Covering small models with tissue? j8m8l Scratchbuilt Indoor and Micro Models 14 Aug 27, 2004 07:52 PM
Open-structure Covering Scheme? Seared Ice Thermal 33 May 12, 2004 08:45 PM
covering foam with white glue a tissue dave morris Electric Plane Talk 10 Feb 27, 2004 08:55 AM
Solite Covering - Seams over open structure. edbuell Sport Planes 2 Feb 13, 2004 11:07 PM
